    Email
    92 Posts 36 Posters 150.5k Views 39 Watching
    • A
      amanzimdwini @ronny3050
      @ronny3050
      Thx for updating the README.
      Followed instructions (requested app-pwd since I have 2-factor authentication).
      My config.js:
                              module: 'email',
                              position: 'bottom_left',
                              header: 'Email',
                              config:{
                              user: 'XXX@gmail.com',
                              password: '****************',
                              host: 'imap.gmail.com',
                              port: 993,
                              tls: true,
                              authTimeout: 10000,
                              numberOfEmails: 5,
                              fade: true
      Restarted (NOT REBOOTED) Pi.
      Got this:
      0_1469426287738_upload-38a60756-5f8a-4933-b4f3-af564be8f683
      Rebooted (just to be safe) - same result.
      R 1 Reply Last reply
        ronny3050 Module Developer @amanzimdwini
        @amanzimdwini you are missing a ‘}’ which closes the config block. It should look like:
                                module: 'email',
                                header: 'Email',
                                config:{
                                port: 993,
                                tls: true,
                                authTimeout: 10000,
                                numberOfEmails: 5,
                                fade: true
        A 1 Reply Last reply
        • A
          @ronny3050
          Sorry - pasted only partial copy; I had the trailing }.
          My Config.js was correct…
          Just to be on the safe side, I tested it as if config.js had been what I posted - and that failed with a “please create a config file”. As it should have.
          So - I think the problem is elsewhere. Sorry
          R 3 Replies Last reply
            @amanzimdwini Could you please report the logs?
              @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                @amanzimdwini It should be working now?
                • A
                  @ronny3050
                  Just did a clean install on a brand new pi in about 5 minutes flat. COOL MODULE.
                  (still need to work on 2-auth, please. Plus I’ll want to change your config to make the display single line etc. I’ll look at the js file)
                    @amanzimdwini I am working on it. Also, I am finishing up with another module that works in a very similar fashion, where your requests would be required as well. I’ll add them together :D
                    • N
                      Neokamikaze
                      Thanks for this job.
                      It’s possible to add number of email don’t read in the header module ?
                        ronny3050 Module Developer @Neokamikaze
                        @Neokamikaze Thanks for your kind words!
                        It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
                        Thanks once more :D
                          pietrodona
                          Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
                          I managed the security and everything, it is a Gmail account.
                          Any idea of what’s going on?
                            pietrodona
                            Sorry for double posting. Now it works, but I did nothing but rebooting.
                              ronny3050 Module Developer @pietrodona
                              @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
                              Hopefully, all is well now.
                              • KirAsh4K
                                KirAsh4 Moderator
                                When in doubt, pull the plug.
                                • E
                                  eugenelai
                                  Is it possible to add two email addresses? Kindly please advice @ronny3050
                                  • strawberry 3.141S
                                    multiple adresses are currently not possible
                                    • N
                                      Neokamikaze
                                      Hi @ronny3050,
                                      I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                                      • cowboysdudeC
                                        cowboysdude Module Developer @ronny3050
                                        @ronny3050 said in Email:
                                        @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                                        Suggestions?
                                          samydp
                                          you can adjust the size of the email?
                                          at too long email that goes module over the entire screen
                                          H 1 Reply Last reply
                                          • H
                                            Hacksaw @samydp
                                            @samydp
                                            email.js
                                            search line 59:
                                            var subject = mailObj.subject.replace(/[['“]]+/g,”");
                                            among them include:
                                            var subject = subject.substring(0,30); //This limit of 30 characters
                                            • 2 / 5
