    Email
    92 Posts 36 Posters 150.5k Views 39 Watching
      ronny3050 Module Developer @amanzimdwini
      @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
        @amanzimdwini It should be working now?
        A 1 Reply Last reply
        • A
          amanzimdwini @ronny3050
          @ronny3050
          Just did a clean install on a brand new pi in about 5 minutes flat. COOL MODULE.
          (still need to work on 2-auth, please. Plus I’ll want to change your config to make the display single line etc. I’ll look at the js file)
          R 1 Reply Last reply
            @amanzimdwini I am working on it. Also, I am finishing up with another module that works in a very similar fashion, where your requests would be required as well. I’ll add them together :D
            • N
              Neokamikaze
              Thanks for this job.
              It’s possible to add number of email don’t read in the header module ?
                ronny3050 Module Developer @Neokamikaze
                @Neokamikaze Thanks for your kind words!
                It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
                Thanks once more :D
                  pietrodona
                  Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
                  I managed the security and everything, it is a Gmail account.
                  Any idea of what’s going on?
                    pietrodona
                    Sorry for double posting. Now it works, but I did nothing but rebooting.
                      ronny3050 Module Developer @pietrodona
                      @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
                      Hopefully, all is well now.
                      • KirAsh4K
                        KirAsh4 Moderator
                        When in doubt, pull the plug.
                        • E
                          eugenelai
                          Is it possible to add two email addresses? Kindly please advice @ronny3050
                          • strawberry 3.141S
                            multiple adresses are currently not possible
                            • N
                              Neokamikaze
                              Hi @ronny3050,
                              I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                              • cowboysdudeC
                                cowboysdude Module Developer @ronny3050
                                @ronny3050 said in Email:
                                @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                                Suggestions?
                                  samydp
                                  you can adjust the size of the email?
                                  at too long email that goes module over the entire screen
                                  H 1 Reply Last reply
                                  • H
                                    Hacksaw @samydp
                                    @samydp
                                    email.js
                                    search line 59:
                                    var subject = mailObj.subject.replace(/[['“]]+/g,”");
                                    among them include:
                                    var subject = subject.substring(0,30); //This limit of 30 characters
                                      robertdempsey
                                      So far it’s working like a charm! Thanks for creating this module.
                                        robertdempsey @pietrodona
                                        @pietrodona be sure to install the dependencies per the README. I skipped that part and MM stopped at a white screen. Once the deps were installed everything worked well.
                                        Reply Quote 2
                                          samydp
                                          thx, but dont have the line :/
                                          this is in the email.js file :
                                          defaults : {
                                              user: 'a@b.com',
                                              password: 'xxx',
                                              host: 'jjj.kkk.com',
                                              port: 993,
                                              tls: true,
                                              authTimeout: 10000,
                                              numberOfEmails: 5,
                                              fade: true
                                          payload: [],
                                          start : function(){
                                              console.log("Email module started!");
                                              this.sendSocketNotification('LISTEN_EMAIL',{config: this.config, payload: this.payload, loaded: this.loaded});
                                              this.loaded = false;
                                          socketNotificationReceived: function(notification, payload){
                                              if (notification === 'EMAIL_RESPONSE'){
                                                  if(payload){
                                                      this.loaded = true;
                                                      var that = this;
                                                      console.log("NEW PAYLOAD: ", payload);
                                                      payload.forEach(function(m){
                                                          if(that.payload.indexOf(m.id) == -1)
                                                              that.payload.push(m);
                                                      this.payload.sort(function(a,b) {return b.id - a.id; });
                                                      this.updateDom(2000);
                                          // Define required scripts.
                                          getStyles: function() {
                                              return ["email.css", "font-awesome.css"];
                                          getDom: function(){
                                              var wrapper = document.createElement("table");
                                              wrapper.className = "small";
                                              var that =this;
                                              if(this.payload.length > 0)
                                                  var count = 0;
                                                  this.payload.slice(0,this.config.numberOfEmails).forEach(function (mailObj) {
                                                      var name = mailObj.sender[0].name.replace(/['"]+/g,"");
                                                      var subject = mailObj.subject.replace(/[\['"\]]+/g,"");
                                                      var emailWrapper = document.createElement("tr");
                                                      emailWrapper.className = "normal";
                                                      var senderWrapper = document.createElement("tr");
                                                      senderWrapper.className = "normal";
                                                      var nameWrapper = document.createElement("td");
                                                      nameWrapper.className = "bright";
                                                      nameWrapper.innerHTML = name;
                                                      senderWrapper.appendChild(nameWrapper);
                                                      var addressWrapper = document.createElement("td");
                                                      addressWrapper.className = "address xsmall thin dimmed";
                                                      addressWrapper.innerHTML = mailObj.sender[0].address;
                                                      senderWrapper.appendChild(addressWrapper);
                                                      emailWrapper.appendChild(senderWrapper);
                                                      var subjectWrapper = document.createElement("tr");
                                                      subjectWrapper.className = "light";
                                                      subjectWrapper.innerHTML = subject;
                                                      emailWrapper.appendChild(subjectWrapper);
                                                      wrapper.appendChild(emailWrapper);
                                                      // Create fade effect.
                                                      if (that.config.fade) {
                                                          var startingPoint = that.payload.slice(0,that.config.numberOfEmails).length * 0.25;
                                                          var steps = that.payload.slice(0,that.config.numberOfEmails).length - startingPoint;
                                                          if (count >= startingPoint) {
                                                              var currentStep = count - startingPoint;
                                                              emailWrapper.style.opacity = 1 - (1 / steps * currentStep);
                                                      count++;
                                              else{
                                                  wrapper.innerHTML = (this.loaded) ? "No new mails" : this.translate("LOADING");
                                                  wrapper.className = "small dimmed";
                                                  return wrapper;
                                              return wrapper;
                                          • H
                                            Hacksaw
                                                    var subject = mailObj.subject.replace(/[\['"\]]+/g,"");    <----- **Here this line**
                                                    var subject = subject.substring(0,30);  <----- **New Line**
                                            • 2 / 5
