    Email
    92 Posts 36 Posters 150.5k Views 39 Watching
      pietrodona
      Sorry for double posting. Now it works, but I did nothing but rebooting.
      R 1 Reply Last reply
        ronny3050 Module Developer @pietrodona
        @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
        Hopefully, all is well now.
        • KirAsh4K
          KirAsh4 Moderator
          When in doubt, pull the plug.
          • E
            eugenelai
            Is it possible to add two email addresses? Kindly please advice @ronny3050
            • strawberry 3.141S
              multiple adresses are currently not possible
              • N
                Neokamikaze
                Hi @ronny3050,
                I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                • cowboysdudeC
                  cowboysdude Module Developer @ronny3050
                  @ronny3050 said in Email:
                  @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                  @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                  Suggestions?
                    samydp
                    you can adjust the size of the email?
                    at too long email that goes module over the entire screen
                    H 1 Reply Last reply
                    • H
                      Hacksaw @samydp
                      @samydp
                      email.js
                      search line 59:
                      var subject = mailObj.subject.replace(/[['“]]+/g,”");
                      among them include:
                      var subject = subject.substring(0,30); //This limit of 30 characters
                        robertdempsey
                        So far it’s working like a charm! Thanks for creating this module.
                          robertdempsey @pietrodona
                          @pietrodona be sure to install the dependencies per the README. I skipped that part and MM stopped at a white screen. Once the deps were installed everything worked well.
                          Reply Quote 2
                            samydp
                            thx, but dont have the line :/
                            this is in the email.js file :
                            defaults : {
                                user: 'a@b.com',
                                password: 'xxx',
                                host: 'jjj.kkk.com',
                                port: 993,
                                tls: true,
                                authTimeout: 10000,
                                numberOfEmails: 5,
                                fade: true
                            payload: [],
                            start : function(){
                                console.log("Email module started!");
                                this.sendSocketNotification('LISTEN_EMAIL',{config: this.config, payload: this.payload, loaded: this.loaded});
                                this.loaded = false;
                            socketNotificationReceived: function(notification, payload){
                                if (notification === 'EMAIL_RESPONSE'){
                                    if(payload){
                                        this.loaded = true;
                                        var that = this;
                                        console.log("NEW PAYLOAD: ", payload);
                                        payload.forEach(function(m){
                                            if(that.payload.indexOf(m.id) == -1)
                                                that.payload.push(m);
                                        this.payload.sort(function(a,b) {return b.id - a.id; });
                                        this.updateDom(2000);
                            // Define required scripts.
                            getStyles: function() {
                                return ["email.css", "font-awesome.css"];
                            getDom: function(){
                                var wrapper = document.createElement("table");
                                wrapper.className = "small";
                                var that =this;
                                if(this.payload.length > 0)
                                    var count = 0;
                                    this.payload.slice(0,this.config.numberOfEmails).forEach(function (mailObj) {
                                        var name = mailObj.sender[0].name.replace(/['"]+/g,"");
                                        var subject = mailObj.subject.replace(/[\['"\]]+/g,"");
                                        var emailWrapper = document.createElement("tr");
                                        emailWrapper.className = "normal";
                                        var senderWrapper = document.createElement("tr");
                                        senderWrapper.className = "normal";
                                        var nameWrapper = document.createElement("td");
                                        nameWrapper.className = "bright";
                                        nameWrapper.innerHTML = name;
                                        senderWrapper.appendChild(nameWrapper);
                                        var addressWrapper = document.createElement("td");
                                        addressWrapper.className = "address xsmall thin dimmed";
                                        addressWrapper.innerHTML = mailObj.sender[0].address;
                                        senderWrapper.appendChild(addressWrapper);
                                        emailWrapper.appendChild(senderWrapper);
                                        var subjectWrapper = document.createElement("tr");
                                        subjectWrapper.className = "light";
                                        subjectWrapper.innerHTML = subject;
                                        emailWrapper.appendChild(subjectWrapper);
                                        wrapper.appendChild(emailWrapper);
                                        // Create fade effect.
                                        if (that.config.fade) {
                                            var startingPoint = that.payload.slice(0,that.config.numberOfEmails).length * 0.25;
                                            var steps = that.payload.slice(0,that.config.numberOfEmails).length - startingPoint;
                                            if (count >= startingPoint) {
                                                var currentStep = count - startingPoint;
                                                emailWrapper.style.opacity = 1 - (1 / steps * currentStep);
                                        count++;
                                else{
                                    wrapper.innerHTML = (this.loaded) ? "No new mails" : this.translate("LOADING");
                                    wrapper.className = "small dimmed";
                                    return wrapper;
                                return wrapper;
                            • H
                              Hacksaw
                                      var subject = mailObj.subject.replace(/[\['"\]]+/g,"");    <----- **Here this line**
                                      var subject = subject.substring(0,30);  <----- **New Line**
                                samydp
                                perfekt it works !!
                                but I’d love that is hidden, the email address and the mail before each a symbol appears is that possible?
                                  samydp
                                  hello, thank you to help me by the email module !!
                                  but I have a question
                                  you can insert a symbol in front of the email?
                                  so i have think tis symbol
                                    A Former User
                                    said in Email:
                                    Link to module
                                    Just getting : Loading
                                    Any tips on resolving? Thx
                                      A Former User
                                      Errors
                                      Email notifier error: { Error: read ECONNRESET
                                      at exports._errnoException (util.js:1026:11)
                                      at TCP.onread (net.js:564:26)
                                      code: ‘ECONNRESET’,
                                      errno: ‘ECONNRESET’,
                                      syscall: ‘read’,
                                      source: ‘socket’ }
                                      code: ‘ECONNRESET’,
                                      syscall: ‘read’,
                                      source: ‘socket’ }
                                      code: ‘ECONNRESET’,
                                      syscall: ‘read’,
                                      source: ‘socket’ }
                                      code: ‘ECONNRESET’,
                                      syscall: ‘read’,
                                      source: ‘socket’ }
                                      code: ‘ECONNRESET’,
                                      syscall: ‘read’,
                                      source: ‘socket’ }
                                        Peter_van_Evert
                                        Hello ronny3050, the module is great, but after a while the module stands still. On my Mobilphone there are messages about new emails but your email Module does nothing. After a restart from the raspberry pi, everything is ok again, but after a few hours the same… Could you help me ?
                                        Yours Peter van Evert
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @Peter_van_Evert
                                          @Peter_van_Evert hes offline since two months, you probably have more success with open an issue on github
                                            ronny3050 Module Developer @strawberry 3.141
                                            @strawberry-3.141 @Peter_van_Evert I apologize for not being able to get back to you sooner - been busy with grad school. :( I replied on the issue on github. Thanks! :)
                                            • 2 / 5
