    Email
    92 Posts 36 Posters 149.1k Views 39 Watching
      ronny3050 Module Developer @Neokamikaze
      @Neokamikaze Thanks for your kind words!
      It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
      Thanks once more :D
        pietrodona
        Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
        I managed the security and everything, it is a Gmail account.
        Any idea of what’s going on?
          pietrodona
          Sorry for double posting. Now it works, but I did nothing but rebooting.
            ronny3050 Module Developer @pietrodona
            @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
            Hopefully, all is well now.
            • K
              KirAsh4 Moderator
              When in doubt, pull the plug.
              • E
                eugenelai
                Is it possible to add two email addresses? Kindly please advice @ronny3050
                • strawberry 3.141S
                  multiple adresses are currently not possible
                  • N
                    Neokamikaze
                    Hi @ronny3050,
                    I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                    • cowboysdudeC
                      cowboysdude Module Developer @ronny3050
                      @ronny3050 said in Email:
                      @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                      @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                      Suggestions?
                        samydp
                        you can adjust the size of the email?
                        at too long email that goes module over the entire screen
                        • H
                          Hacksaw @samydp
                          @samydp
                          email.js
                          search line 59:
                          var subject = mailObj.subject.replace(/[['“]]+/g,”");
                          among them include:
                          var subject = subject.substring(0,30); //This limit of 30 characters
                            robertdempsey
                            So far it’s working like a charm! Thanks for creating this module.
                              robertdempsey @pietrodona
                              @pietrodona be sure to install the dependencies per the README. I skipped that part and MM stopped at a white screen. Once the deps were installed everything worked well.
                                samydp
                                thx, but dont have the line :/
                                this is in the email.js file :
                                defaults : {
                                    user: 'a@b.com',
                                    password: 'xxx',
                                    host: 'jjj.kkk.com',
                                    port: 993,
                                    tls: true,
                                    authTimeout: 10000,
                                    numberOfEmails: 5,
                                    fade: true
                                payload: [],
                                start : function(){
                                    console.log("Email module started!");
                                    this.sendSocketNotification('LISTEN_EMAIL',{config: this.config, payload: this.payload, loaded: this.loaded});
                                    this.loaded = false;
                                socketNotificationReceived: function(notification, payload){
                                    if (notification === 'EMAIL_RESPONSE'){
                                        if(payload){
                                            this.loaded = true;
                                            var that = this;
                                            console.log("NEW PAYLOAD: ", payload);
                                            payload.forEach(function(m){
                                                if(that.payload.indexOf(m.id) == -1)
                                                    that.payload.push(m);
                                            this.payload.sort(function(a,b) {return b.id - a.id; });
                                            this.updateDom(2000);
                                // Define required scripts.
                                getStyles: function() {
                                    return ["email.css", "font-awesome.css"];
                                getDom: function(){
                                    var wrapper = document.createElement("table");
                                    wrapper.className = "small";
                                    var that =this;
                                    if(this.payload.length > 0)
                                        var count = 0;
                                        this.payload.slice(0,this.config.numberOfEmails).forEach(function (mailObj) {
                                            var name = mailObj.sender[0].name.replace(/['"]+/g,"");
                                            var subject = mailObj.subject.replace(/[\['"\]]+/g,"");
                                            var emailWrapper = document.createElement("tr");
                                            emailWrapper.className = "normal";
                                            var senderWrapper = document.createElement("tr");
                                            senderWrapper.className = "normal";
                                            var nameWrapper = document.createElement("td");
                                            nameWrapper.className = "bright";
                                            nameWrapper.innerHTML = name;
                                            senderWrapper.appendChild(nameWrapper);
                                            var addressWrapper = document.createElement("td");
                                            addressWrapper.className = "address xsmall thin dimmed";
                                            addressWrapper.innerHTML = mailObj.sender[0].address;
                                            senderWrapper.appendChild(addressWrapper);
                                            emailWrapper.appendChild(senderWrapper);
                                            var subjectWrapper = document.createElement("tr");
                                            subjectWrapper.className = "light";
                                            subjectWrapper.innerHTML = subject;
                                            emailWrapper.appendChild(subjectWrapper);
                                            wrapper.appendChild(emailWrapper);
                                            // Create fade effect.
                                            if (that.config.fade) {
                                                var startingPoint = that.payload.slice(0,that.config.numberOfEmails).length * 0.25;
                                                var steps = that.payload.slice(0,that.config.numberOfEmails).length - startingPoint;
                                                if (count >= startingPoint) {
                                                    var currentStep = count - startingPoint;
                                                    emailWrapper.style.opacity = 1 - (1 / steps * currentStep);
                                            count++;
                                    else{
                                        wrapper.innerHTML = (this.loaded) ? "No new mails" : this.translate("LOADING");
                                        wrapper.className = "small dimmed";
                                        return wrapper;
                                    return wrapper;
                                • H
                                  Hacksaw
                                          var subject = mailObj.subject.replace(/[\['"\]]+/g,"");    <----- **Here this line**
                                          var subject = subject.substring(0,30);  <----- **New Line**
                                    samydp
                                    perfekt it works !!
                                    but I’d love that is hidden, the email address and the mail before each a symbol appears is that possible?
                                      samydp
                                      hello, thank you to help me by the email module !!
                                      but I have a question
                                      you can insert a symbol in front of the email?
                                      so i have think tis symbol
                                        A Former User
                                        said in Email:
                                        Link to module
                                        Just getting : Loading
                                        Any tips on resolving? Thx
                                          A Former User
                                          Errors
                                          Email notifier error: { Error: read ECONNRESET
                                          at exports._errnoException (util.js:1026:11)
                                          at TCP.onread (net.js:564:26)
                                          code: ‘ECONNRESET’,
                                          errno: ‘ECONNRESET’,
                                          syscall: ‘read’,
                                          source: ‘socket’ }
                                          code: ‘ECONNRESET’,
                                          syscall: ‘read’,
                                          source: ‘socket’ }
                                          code: ‘ECONNRESET’,
                                          syscall: ‘read’,
                                          source: ‘socket’ }
                                          code: ‘ECONNRESET’,
                                          syscall: ‘read’,
                                          source: ‘socket’ }
                                          code: ‘ECONNRESET’,
                                          syscall: ‘read’,
                                          source: ‘socket’ }
                                            Peter_van_Evert
                                            Hello ronny3050, the module is great, but after a while the module stands still. On my Mobilphone there are messages about new emails but your email Module does nothing. After a restart from the raspberry pi, everything is ok again, but after a few hours the same… Could you help me ?
                                            Yours Peter van Evert
                                            • 2 / 5
