    Email
    92 Posts 36 Posters 146.3k Views 39 Watching
      Peter_van_Evert @zman3
      @zman3 I got the same problem and only one solution, till now. Press CTRL(STRG) and R to restart the magic mirror client. After that the emails are ok, till 2-3 hours… :)
        ronny3050 Module Developer @Peter_van_Evert
        @Peter_van_Evert This is really strange. I have not faced this myself.
        I think it is because your email client stops responding after 2-3 hours due to security reasons, perhaps :/
          ronny3050 Module Developer @Guest
          @wjdw87 This usually happens due to two reasons:
          1. Connection to your mail client is not possible - try the two-factor authentication mentioned before for using Gmail, or your credentials are wrong.
          2. Try restarting mirror.
          • E Offline
            edsulst
            Is it possible to sroll the subject instead of putting a limit to the number of characters ?
              pepemujica
              Hi! is it possible to use it in emails requesting 2nd factor?
                davidrq7
                Hi guys can any 1 help me? Email module shows all the time no new emails, and the console looks like this: 0_1491837734246_17857461_1549238255109393_1377519403_n.jpg
                Edit: Solved. Just added “subjectlength: 50” at the end of script and works fine :)
                • G Offline
                  Gungnir83
                  I refer to the possibility of a multiaccount module.
                  I tried to make 2 directories email_a and email_b, uninstalled the module, customized the mail.js und installed it again.
                  In the “global” config I added both modules into the array with their new names (email_a email_b) with all the other neccessary information like the auth…
                  But when I start the mirror app, nothing happens. I see, that the helpers start, but no tries to fetch mails.
                  And no errors.
                  Any suggestions?
                    apm1007 @ronny3050
                    @ronny3050 i would like to display only unread emails. thank you.
                    • G Offline
                      gismo2006
                      I use this modul for a long time. but now I have a little question,
                      is it possible to set a intervall to check new emails?? Like every 10 Minutes for example.
                      And if it isn´t possible can I easy put this option in any way?
                      I have to say my coding experencie isn´t very good, so because there is a easy way. :-)
                      greets gismo
                        Updated email module.
                        Now supports:
                        • Multiple email accounts
                        • Will not crash on too many unread emails
                        • Better fetching of recent and unread emails
                          ronny3050 Module Developer @eugenelai
                          @eugenelai @apm1007 @Gungnir83 Please update. :)
                            Preve
                            Done the update and now email is “Loading”. Nothing more than this.
                            Anyone knows why?
                            The bottom error I got after the “npm install”.
                              ronny3050 Module Developer @Preve
                              @Preve Thanks for the heads up. The bottom parts are warnings and have nothing to do with the module not working. Loading for a long time indicates problem with communicating with your email service.
                                rodofrn @ronny3050
                                @ronny3050 I have the same problem as Preve, I have tried multiple email accts, and nothing. Happened after I updated MM. Any ideas?
                                  stephenmelody
                                  Hey @ronny3050, is there a way to only show the sender’s name and not their email address?
                                    MSimonart @davidrq7
                                    @davidrq7 Do you remember what you did to solve this? cause I have the same problem
                                      MSimonart
                                      Hi, when starting up the Mirror, email shows loading…
                                      in my terminal i see the following:
                                      NEW MAIL
                                      NEW MAIL
                                      NEW MAIL
                                      Email notifier error: { Error: Timed out while autenticating with server at Timeout._onTimeout (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection
                                      my config looks good,
                                      Accounts: [
                                      user: ‘XX@hotmail.com’,
                                      password: ‘’,
                                      host: ‘imap-mail.outlook.com’,
                                      port: 993,
                                      tls: true,
                                      authTimeout: 10000,
                                      numberOfEmails: 5
                                      fade: true,
                                      maxCharacters: 30
                                        MSimonart
                                        ok, it works, now for the css of the .address text, the text is not well readable on the mirror, there is like some sort of gradient or something effect on the font/text. How do I disable this?
                                        • strawberry 3.141S Offline
                                          strawberry 3.141 Project Sponsor Module Developer @MSimonart
                                          @MSimonart here is no gradient effect, probably you mean the default magicmirror class dimmed, you can overwrite it for that module in the custom css
                                          .email .dimmed {
                                            color: #aaa;
                                          • G Offline
                                            Gxnfr Ali @apm1007
                                            @apm1007 hello
                                            • 3 / 5
