    Email
    92 Posts 36 Posters 143.7k Views 39 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @MSimonart
      @MSimonart here is no gradient effect, probably you mean the default magicmirror class dimmed, you can overwrite it for that module in the custom css
      .email .dimmed {
        color: #aaa;
      • G Offline
        Gxnfr Ali @apm1007
        @apm1007 hello
          MSimonart @strawberry 3.141
          @strawberry-3.141 Ok i’ll try, thanks
          • G Offline
            Gxnfr Ali @MSimonart
            @MSimonart
            no new email show
              secblizz
              Same problem here. The module recieves the Mails but they weren’t shown in the mirror
              //edit: fixed my problem. Fade has to be false…
              • U Offline
                umairshah
                I have added the module in Default folder named it email
                and added the module in config.js from the Github link followed here
                https://github.com/ronny3050/email-mirror
                but nothing is shown on screen.
                Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                  Mykle1 Project Sponsor Module Developer @umairshah
                  @umairshah
                  The email module folder goes in the modules folder but not inside the default folder
                  U 1 Reply Last reply Reply Quote 0
                  • U Offline
                    umairshah @Mykle1
                    @Mykle1 I have moved it to module but it is not working
                    • E Offline
                      E3V3A @amanzimdwini
                      • U Offline
                        umairshah
                        When I wrote the command npm install
                        it showed error no License and no repository field found
                        then I added repository and license
                        but it shows that email@0.0.1 is not valid license spdx expression
                        “license” : {
                        “type” : “MIT”
                        • I Offline
                          ime90
                          I’m still having trouble.
                          I believe I setup everything correctly. Added the subjectlength at the end, allowed IMAP in my gmail account, but still, after loading the module won’t connect to my mail and doesn’t show anything. Is anyone else having trouble with this?
                          • justjim1220J Offline
                            justjim1220 Module Developer @umairshah
                            @umairshah
                            If you add a module to the default folder, you have to make the necessary changes to the default.js file to include it.
                            It’s just better to put it in the modules folder.
                            Jim Hallock - 1995
                            • U Offline
                              umairshah @justjim1220
                              @justjim1220 said in Email:
                              @justjim
                              It is not in default folder, it is in the module folder.
                              when I download and tried to install it gave error of no repository and license field in package.json, but when I add those fields in package.json then it showed spdx expression error.
                                @umairshah
                                @ime90
                                Can you show your config.js file here?
                                Make sure you hide personal info…
                                Jim Hallock - 1995
                                • I Offline
                                  ime90 @justjim1220
                                  @justjim1220
                                  var config = {
                                  address: “localhost”,
                                  port: 8080,
                                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
                                  language: "en",
                                  timeFormat: 24,
                                  units: "metric",
                                  		module: "alert",
                                  		module: 'email',
                                                  position: 'bottom_left',
                                                  header: 'Email',
                                                      accounts: [
                                                              user: '**@gmail.com',
                                                              password: '**',
                                                              host: 'imap.gmail.com',
                                                              port: 993,
                                                              tls: true,
                                                              authTimeout: 10000,
                                                              numberOfEmails: 2,
                                                      fade: true,
                                                      maxCharacters: 30,
                                  		    subjectLength: 50
                                  		module: "updatenotification",
                                  		position: "top_bar"
                                  		module: "clock",
                                  		position: "top_left"
                                  		header: "US Holidays",
                                  					symbol: "calendar-check-o ",
                                  		module: "compliments",
                                  		position: "lower_third"
                                  		module: "currentweather",
                                  			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                  		module: "weatherforecast",
                                  		header: "Weather Forecast",
                                  			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                  		module: "newsfeed",
                                  		position: "bottom_bar",
                                  			feeds: [
                                  					title: "New York Times",
                                  			showSourceTitle: true,
                                  			showPublishDate: true
                                  if (typeof module !== “undefined”) {module.exports = config;}
                                    justjim1220 Module Developer @ime90
                                    @ime90
                                    Try changing the fade to false.
                                    Make sure your email address and password are case correct (uppercase and lowercase).
                                    Other than that, I don’t see an issue with the syntax.
                                    You did change the config.js.sample to config.js, correct?
                                    Jim Hallock - 1995
                                      @ime90
                                      Also…
                                      I have found that some modules don’t work as well with the single quotes (’ ').
                                      Try changing them all to the double quotes (" ")
                                      Jim Hallock - 1995
                                      • I Offline
                                        ime90 @justjim1220
                                        @justjim1220
                                        Yeah, I changed it of course. I’ll try out the double quotation marks and all you recommended.
                                        Can you just tell me, does this module work for you at this time for Gmail or any other mail?
                                          @ime90
                                          Yes, it works for me with my Gmail, my Hotmail, and my Yahoo mail. But I have since decided to link all three to my Gmail so I use just the one to receive all of them. But, I have tested it with all three and it does work.
                                          Jim Hallock - 1995
                                          I 1 Reply Last reply Reply Quote 1
                                          • I Offline
                                            ime90 @justjim1220
                                            @justjim1220
                                            Tried it all but still getting “No new Mail” text. I dunno where I’m going wrong. Could you please copy your module text (or send me on private) so I can compare them. Also, did you do anything on your own gmail account that could help? I changed the imap settings.
                                            I get this error:
                                            Email notifier error:  { Error: Web login required: https://support.google.com/mail/answer/78754 (Failure)
                                                at Connection._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection.js:1502:11)
                                            at emitOne (events.js:96:13)
                                                at Parser.emit (events.js:191:7)
                                                at Parser._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:175:10)
                                                at Parser._parse (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:139:16)
                                                at Parser._tryread (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:82:15)
                                                at TLSSocket.Parser._cbReadable (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:53:12)
                                                at emitNone (events.js:86:13)
                                                at TLSSocket.emit (events.js:188:7) type: 'no', textCode: 'ALERT', source: 'authentication' }
                                            • 4 / 5
