    Email
    92 Posts 36 Posters 146.4k Views 39 Watching
      rodofrn @ronny3050
      @ronny3050 I have the same problem as Preve, I have tried multiple email accts, and nothing. Happened after I updated MM. Any ideas?
        stephenmelody
        Hey @ronny3050, is there a way to only show the sender’s name and not their email address?
          MSimonart @davidrq7
          @davidrq7 Do you remember what you did to solve this? cause I have the same problem
            MSimonart
            Hi, when starting up the Mirror, email shows loading…
            in my terminal i see the following:
            NEW MAIL
            NEW MAIL
            NEW MAIL
            Email notifier error: { Error: Timed out while autenticating with server at Timeout._onTimeout (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection
            my config looks good,
            Accounts: [
            user: ‘XX@hotmail.com’,
            password: ‘’,
            host: ‘imap-mail.outlook.com’,
            port: 993,
            tls: true,
            authTimeout: 10000,
            numberOfEmails: 5
            fade: true,
            maxCharacters: 30
              MSimonart
              ok, it works, now for the css of the .address text, the text is not well readable on the mirror, there is like some sort of gradient or something effect on the font/text. How do I disable this?
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @MSimonart
                @MSimonart here is no gradient effect, probably you mean the default magicmirror class dimmed, you can overwrite it for that module in the custom css
                .email .dimmed {
                  color: #aaa;
                • G Offline
                  Gxnfr Ali @apm1007
                  @apm1007 hello
                    MSimonart @strawberry 3.141
                    @strawberry-3.141 Ok i’ll try, thanks
                    • G Offline
                      Gxnfr Ali @MSimonart
                      @MSimonart
                      no new email show
                        secblizz
                        Same problem here. The module recieves the Mails but they weren’t shown in the mirror
                        //edit: fixed my problem. Fade has to be false…
                        • U Offline
                          umairshah
                          I have added the module in Default folder named it email
                          and added the module in config.js from the Github link followed here
                          https://github.com/ronny3050/email-mirror
                          but nothing is shown on screen.
                          Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                            Mykle1 Project Sponsor Module Developer @umairshah
                            @umairshah
                            The email module folder goes in the modules folder but not inside the default folder
                            U 1 Reply Last reply Reply Quote 0
                            • U Offline
                              umairshah @Mykle1
                              @Mykle1 I have moved it to module but it is not working
                              • E Offline
                                E3V3A @amanzimdwini
                                • U Offline
                                  umairshah
                                  When I wrote the command npm install
                                  it showed error no License and no repository field found
                                  then I added repository and license
                                  but it shows that email@0.0.1 is not valid license spdx expression
                                  “license” : {
                                  “type” : “MIT”
                                  • I Offline
                                    ime90
                                    I’m still having trouble.
                                    I believe I setup everything correctly. Added the subjectlength at the end, allowed IMAP in my gmail account, but still, after loading the module won’t connect to my mail and doesn’t show anything. Is anyone else having trouble with this?
                                    • justjim1220J Offline
                                      justjim1220 Module Developer @umairshah
                                      @umairshah
                                      If you add a module to the default folder, you have to make the necessary changes to the default.js file to include it.
                                      It’s just better to put it in the modules folder.
                                      Jim Hallock - 1995
                                      • U Offline
                                        umairshah @justjim1220
                                        @justjim1220 said in Email:
                                        @justjim
                                        It is not in default folder, it is in the module folder.
                                        when I download and tried to install it gave error of no repository and license field in package.json, but when I add those fields in package.json then it showed spdx expression error.
                                          @umairshah
                                          @ime90
                                          Can you show your config.js file here?
                                          Make sure you hide personal info…
                                          Jim Hallock - 1995
                                          • I Offline
                                            ime90 @justjim1220
                                            @justjim1220
                                            var config = {
                                            address: “localhost”,
                                            port: 8080,
                                            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
                                            language: "en",
                                            timeFormat: 24,
                                            units: "metric",
                                            		module: "alert",
                                            		module: 'email',
                                                            position: 'bottom_left',
                                                            header: 'Email',
        accounts: [
        user: '**@gmail.com',
        password: '**',
        host: 'imap.gmail.com',
        port: 993,
        tls: true,
        authTimeout: 10000,
        numberOfEmails: 2,
        fade: true,
        maxCharacters: 30,
                                            		    subjectLength: 50
                                            		module: "updatenotification",
                                            		position: "top_bar"
                                            		module: "clock",
                                            		position: "top_left"
                                            		header: "US Holidays",
                                            					symbol: "calendar-check-o ",
                                            		module: "compliments",
                                            		position: "lower_third"
                                            		module: "currentweather",
                                            			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            		module: "weatherforecast",
                                            		header: "Weather Forecast",
                                            			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            		module: "newsfeed",
                                            		position: "bottom_bar",
                                            			feeds: [
                                            					title: "New York Times",
                                            			showSourceTitle: true,
                                            			showPublishDate: true
                                            if (typeof module !== “undefined”) {module.exports = config;}
                                            • 4 / 5
