MMM-Carousel ignoreModules
5 Posts 3 Posters 4.1k Views 3 Watching
    shgmongohh
    Hi guys,
    I have a problem with the module Carousel to ignore some modules.
    I get the failure message, that something is wrong the the MM config file, when I put in some Modules to ignore.
    Whats wrong with my config file?
    Sebastian
        module: 'MMM-Carousel',
        [clock, calender]
    I 1 Reply Last reply Aug 22, 2016, 11:57 AM Reply Quote 0
      You have to put the Module names in Quotes like ‘clock’
      S 1 Reply Last reply Aug 21, 2016, 5:51 PM Reply Quote 0
        shgmongohh @strawberry 3.141
        @strawberry-3.141
        When I put it in quotes ['clock'] I also get the failure message that something is wrong in my config file.
        • I Offline
          ianperrin @shgmongohh
          @shgmongohh said in MMM-Carousel ignoreModules:
          It looks like you are missing both the quotes around the module names (as @strawberry-3-141 mentioned) and the name of the configuration option (i.e. ignoreModules).
          Try this version:
                  ignoreModules: ['clock', 'calendar']
          You might also want to consider adding 'alert' to the ignoreModules list as pointed out by @barnabycolby in his Configuration Options notes
          "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
          S 1 Reply Last reply Aug 22, 2016, 5:01 PM Reply Quote 2
            shgmongohh @ianperrin
            @ianperrin
            Thanks a lot.
