MMM-RTSPStream issues
13 Posts 3 Posters 6.5k Views 2 Watching
    johnny_swindle
    I have an issue getting MMM-RTSPStream to work. I did the install and ran the configuration tool. But when I include the generated code in my config…MM will not run. I feel like a big dummy since there is a config tool that does all of the hard work.
    Here is the code that I am adding:
        module: "MMM-RTSPStream",
        position: "bottom_left",
            autoStart: true,
            rotateStreams: true,
            rotateStreamTimeout: 30,
            moduleWidth: 354,
            moduleHeight: 240,
            localPlayer: 'omxplayer',
            remotePlayer: 'ffmpeg',
            showSnapWhenPaused: false,
            remoteSnaps: false,
            stream1: {
                url: 'rtsp://Administrator:!Password@192.168.0.31:88/videoMain',
                frameRate: 'undefined',
                width: undefined,
                height: undefined,
    Thanks for any help in advance.
    Johnny
      barnosch
      have you added a , after the last closing tag } ?
      J 1 Reply Last reply Apr 24, 2018, 11:24 AM Reply Quote 0
        johnny_swindle @barnosch
        @barnosch
        I probably did not…let me test that and I will report back.
        Thanks…
        Johnny
          johnny_swindle
          @johnny_swindle said in MMM-RTSPStream issues:
          @barnosch
          Ok…the missing comma was part of the issue. Now MM load and I see a message that says Loading MMM-RTSPStream.
          This camera is wireless…talking to a wirless rPi 3 if that is any help resolving the issue I am seeing.
          J 1 Reply Last reply Apr 24, 2018, 6:16 PM Reply Quote 0
            johnny_swindle @johnny_swindle
            Re: MMM-RTSPStream issues
            OK…this is what is displaying on the terminal when I launch MMM-RTSPStream and it issues and error. How and where do I address this error?
            TypeError: `port` or a `server` must be provided
                at new WebSocketServer (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/node_modules/ws/lib/WebSocketServer.js:44:11)
                at VideoStream.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:32:24)
                at Class.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:49:32)
                at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:257:22)
                at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                at emitTwo (events.js:106:13)
                at Socket.emit (events.js:191:7)
                at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:513:12
                at _combinedTickCallback (internal/process/next_tick.js:67:7)
                at process._tickCallback (internal/process/next_tick.js:98:9)
            Thanks…
            Johnny
              barnosch
              This one i do not clearly understand.
              I guess it is a normal Wlan IP cam and the Rpi3 is your MagicMirror host?
              So it is a common combination (like mine)
              Have you tried to open up the URL in VLC if it plays correctly?
              Maybe play around with it. Try different things, delete this Administrator:!Password@, leave the port blank (:88) and so on.
              My config for the stream looks like this:
              stream1: {
                              	url: 'rtsp://10.30.10.28',
                              	snapshotUrl: '',
                              	snapshotRefresh: 10, // Seconds
                              	frameRate: "30",
                              	port: 9999,
              But if i want to access the stream via webpage, i do need to put in credentials. The module does not need them ;)
              Have you done a “npm install” within the MMM-RTSPStream folder?
              J 2 Replies Last reply Apr 25, 2018, 1:26 PM Reply Quote 0
                @barnosch
                Thanks for your reply.
                Sorry I confused the issue with my description of the camera and rPi 3…yes…it is a normal combination (probably like yours).
                The URL plays correctly in VLC. I will follow your suggestion and try around with setting similar to yours.
                Johnny
                  @barnosch
                  Thanks for all the suggestions.
                  I did in fact do a npm install in the MMM-RTSPStream folder.
                  I played around with the config using your example, but the best I got was a blank frame (that was progress, but that was the best so far.
                  Open to any and all suggestions.
                  Johnny
                    barnosch
                    just for the records. You can not see the overlay (stream) if you check your changes via VNC.
                    You have to sit in front of the mirror to check if it appears.
                    Maybe you should highlight the module developer , he has a huge knowledge of all the stuff.
                    J 1 Reply Last reply Apr 26, 2018, 2:54 PM Reply Quote 0
                      @barnosch
                      Thank you for suggestion. I reached out to the developer and I have been able to resolve 99% of the issues. I will post my config once I have it all working. I was aware that you may not be able to see the changes via VNC. I stop MM via putty, make the changes using Nano (via putty) and then restart.
                      I then walk into the next room to check the results. I will probably have to unearth my laptop and sit in front the MM to make my life easier.
                      Johnny
