    Problem with Mi Gateway token
    6 Posts 4 Posters 4.4k Views 4 Watching
      shgmongohh
      Hi all,
      I have still some problems to get the token from my gateway. When I try to find the gateway I get the following:
      pi@raspberrypi:~/MagicMirror/modules/MMM-xiaomi $ miio discover sync
       INFO  Discovering devices. Press Ctrl+C to stop.
      Device ID: 78336602
      Model info: Unknown
      Address: 192.168.1.114
      Token: ???
      Support: Unknown
      When I try to get the token with the software it doesn´t work also.
      Has anybody an idea what could help?
      Sebastian
      • A Online
        Albert2002
        Is USB debug enabled on your Mobile? You only need to hit the Button “Token auslesen”
        I remember that I had this error as well, but I can not remember what I did to solve it. But usually i would try this:
        A different version of Mi Home, or / and a different device.
        I’ve tried it right now and it was working for me with Java 8 Update 151 MiToolkit 1.5, Mi Home 4.3.15 ( Yes i know its outdated but the 5.x I don’t like) on a Samsung with Android 6.0.1
          shgmongohh @Albert2002
          @Albert2002
          Thanks for your help. I have done it this way.
          It works for IOS also for Android.
          Sebastian
            rama3124 @shgmongohh
            @shgmongohh
            I’m also having a similar problem obtaining the Mi Gateway token. How did you end up getting it? I watched the video but it doesn’t show the process of getting the token
              shgmongohh @rama3124
              @rama3124 go to time 1:11. There you can find the tokken in the middle of the display.
                Big_Lynx
                Re: Problem with Mi Gateway token
                I have exactly the same problem with the most recent release of miio and Mi Air Purifier 2S with a recent firmware upgrade. As discovery I received:
                Device ID: 81001836
                Model info: Unknown
                Address: 192.168.1.85
                Token: ???
                Support: Unknown
                For Homebridge gateway I need Token. I see that problem is solved but “this way” explains the issue in German - what I am not familiar with. Could anyone tell me what APP I should use to find out Token value? “Mi Home” app doesn’t show it.
