    Serveronly Mode Not Running
    4 Posts 2 Posters 2.5k Views 1 Watching
    • K
      kiritowu
      When i write node severonly, it shows error and i don’t know how to solve the problem.
      I’m a complete newbie so can some senpai teach me what to do?
      pi@raspberrypi:~/MagicMirror $ node serveronly
      /home/pi/MagicMirror/js/app.js:260
      process.on(“SIGINT”, () => {
      SyntaxError: Unexpected token )
      at Module._compile (module.js:439:25)
      at Object.Module._extensions…js (module.js:474:10)
      at Module.load (module.js:356:32)
      at Function.Module._load (module.js:312:12)
      at Module.require (module.js:364:17)
      at require (module.js:380:17)
      at Object. (/home/pi/MagicMirror/serveronly/index.js:1:73)
      at Module._compile (module.js:456:26)
      B 1 Reply Last reply
        bhepler Module Developer @kiritowu
        @kiritowu - Does running the Magic Mirror normally work? What happens when you enter npm start?
        K 1 Reply Last reply
        • K
          kiritowu @bhepler
          @bhepler
          Hey there, this is what i got when i write npm start. I’m using a raspberry zero and i’m just following all the step from this tutorials. https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/8
          pi@raspberrypi:~ $ cd MagicMirror
          magicmirror@2.3.1 start /home/pi/MagicMirror
          sh run-start.sh
          run-start.sh: 4: run-start.sh: electron: not found
          npm ERR! magicmirror@2.3.1 start: sh run-start.sh
          npm ERR! Exit status 127
          npm ERR!
          npm ERR! Failed at the magicmirror@2.3.1 start script.
          npm ERR! This is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR! sh run-start.sh
          npm ERR! You can get their info via:
          npm ERR! npm owner ls magicmirror
          npm ERR! System Linux 4.4.11+
          npm ERR! command “/usr/bin/nodejs” “/usr/bin/npm” “start”
          npm ERR! cwd /home/pi/MagicMirror
          npm ERR! node -v v0.10.29
          npm ERR! npm -v 1.4.21
          npm ERR! code ELIFECYCLE
          npm WARN This failure might be due to the use of legacy binary “node”
          npm WARN For further explanations, please read
          /usr/share/doc/nodejs/README.Debian
          npm ERR! Error: EACCES, open ‘npm-debug.log’
          npm ERR! { [Error: EACCES, open ‘npm-debug.log’] errno: 3, code: ‘EACCES’, path: ‘npm-debug.log’ }
          npm ERR!
          npm ERR! Please try running this command again as root/Administrator.
          npm ERR! path npm-debug.log
          npm ERR! code EACCES
          npm ERR! errno 3
          npm ERR! stack Error: EACCES, open ‘npm-debug.log’
          npm ERR!
          npm ERR! Additional logging details can be found in:
          npm ERR! /home/pi/MagicMirror/npm-debug.log
          npm ERR! not ok code 0
            @kiritowu Ah. Pi Zero. Okay, let’s skip the interface and concentrate on the server only stuff. Let’s try to get the application to install. Try this:
            sudo npm install
            This may take a while before it completes. But hopefully it will install all of the necessary software. Give it a go.
