    Firing off Javascript after getDom elements have drawn on the page
    2 Posts 2 Posters 1.1k Views 2 Watching
      jetnet
      I am using Magic Mirror with bootstrap, jquery, and some custom javascript code to make touchscreen things happen on a module I am working on. If I fire off the javascript init function after the updateDom event, I don’t get an error, but the dom elements I am trying to run my function against are not yet part of the page, so nothing happens. As part of the debug process, I put a console log line in, so I can confirm that the javascript init() function ran. The module displays everything correctly, but the touch screen elements do not work.
      The module functions a lot like the newsfeed, so after 15 seconds, it calls back out to the server for a new update. If I don’t send it a new update (so it doesn’t redraw the html) but the javascript init fires again, now all of the touch screen elements work.
      Basically what I need to know is: where do I need to put the init() function call, in order to let all the dom elements draw on the page, so the javascript can see them? Is there an “afterGetDom” function I can run?
      I know i am not submitting the code along with this question, but the code is fairly length, and I didn’t want to paste it. If you guys need to see it, I can provide chunks of it.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @jetnet
        @jetnet the only hook that I’m aware off is when the getdom function gets executed the first time, then you could work with MODULE_DOM_CREATED or DOM_OBJECTS_CREATED, but for me it sounds like you are looking for something that gets triggered everytime the dom gets updated not just once.
        https://github.com/MichMich/MagicMirror/tree/master/modules#notificationreceivednotification-payload-sender
