    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 93.5k Views 14 Watching
      SuperSchenk @bobbythemoh
      @bobbythemoh said in MMM-Loxone:
      @idoodler yes i did reboot. and i just uninstalled xscreensaver (after that i did a reboot) but no change in the behaviour.
      @E3V3A I used “uname -a”:
      Linux MagicMirror 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
      Bobby do you have a solution for this? I’m having the exact same problem since updating my pi to the latest version of rasbian
        bobbythemoh
        no, solution yet unforunately.
        • idoodlerI Offline
          idoodler Module Developer
          I just experienced a similar issue, but It appears not to be caused by MMM-Loxone. I am Invastigating it…
            bobbythemoh
            @idoodler
            I found this passage in your code:
                _togglePresence: function _togglePresence(isPresent) {
                    if (isPresent) {
                        // Check if hdmi output is already on
                        exec("/opt/vc/bin/tvservice -s").stdout.on('data', function(data) {
                            if (data.indexOf("0x120002") !== -1)
                                exec("/opt/vc/bin/tvservice --preferred && chvt 6 && chvt 7", null);
                    } else {
                        exec("/opt/vc/bin/tvservice -o", null);
            So you are using “tvserice -o” which seems not to work for me.
            would this be an alternative? Link
            Executing the commands vom @E3V3A here Link brings the Monitor Signal back, but only 1 time.
            Any idea?
              bobbythemoh
              Hi, using this command brings back the Monitor signal:
              xset -display :0 -dpms
              • idoodlerI Offline
                I just implemented vcgencmd it looks like it is a bit quicker. I will check it out the next few days and will push it if everything works.
                • E Offline
                  E3V3A @idoodler
                  @idoodler said in MMM-Loxone:
                  Yeah, but that only work with Rapsberry Piss , so if you want it to work on other devices, you need to use xset, and if you want to use xset on the Pi, you now also need to tell it that the blank screen should be black, with xsetroot -display :0 -solid black.
                  "Everything I do (here) is for free – altruism is the way!"
                  idoodlerI 1 Reply Last reply Reply Quote 0
                  • idoodlerI Offline
                    idoodler Module Developer @E3V3A
                    @e3v3a I think xset just blanks the screen without powering off the HDMI signal?
                    • idoodlerI Offline
                      @bobbythemoh Can you please post your pm2 log. You can optain it by executing pm2 log MagicMirror if you are using pm2.
                      I just detected some unhandled rejections which may cause the black screen.
                        bobbythemoh
                        pi@MagicMirror:~ $ pm2 log MagicMirror
                        [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                        /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
                        0|MagicMir | [865:0515/052002.614227:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
                        0|MagicMir | #0 0x0000007fd980 <unknown>
                        0|MagicMir | #1 0x000000841db2 <unknown>
                        0|MagicMir | #2 0x0000012700d2 <unknown>
                        0|MagicMir |
                        0|MagicMir | npm ERR! code ELIFECYCLE
                        0|MagicMir | npm ERR! errno 1
                        0|MagicMir | npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                        0|MagicMir | npm ERR! Exit status 1
                        0|MagicMir | npm ERR! Failed at the magicmirror@2.3.1 start script.
                        0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        0|MagicMir |
                        0|MagicMir | npm ERR! A complete log of this run can be found in:
                        0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2018-05-15T05_31_52_606Z-debug.log
                        /home/pi/.pm2/logs/MagicMirror-out-0.log last 15 lines:
                        0|MagicMir | MMM-Loxone Search LightControls and LightV2Controls in room
                        0|MagicMir | MMM-Loxone Found LightControl (Lichtsteuerung) in room OG Bad
                        0|MagicMir | MMM-Loxone NotificationUuid: 0ea3ebd1-008d-029d-ffff390cde3b9b45
                        0|MagicMir | MMM-Loxone Enabling statusupdates
                        0|MagicMir | MMM-Loxone Successfully executed 'dev/sps/enablebinstatusupdate' with code 200 and value 1
                        0|MagicMir | MMM-Loxone Got lightMood change [1]
                        0|MagicMir | MMM-Loxone Got room temperature: 21.8
                        0|MagicMir | MMM-Loxone Got lightMood change [777]
                        0|MagicMir | MMM-Loxone Got lightMood change [778]
                        • 10
                        • 3 / 10
