    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 112.1k Views 14 Watching
      bobbythemoh
      no, solution yet unforunately.
      • idoodlerI
        idoodler Module Developer
        I just experienced a similar issue, but It appears not to be caused by MMM-Loxone. I am Invastigating it…
          bobbythemoh
          @idoodler
          I found this passage in your code:
              _togglePresence: function _togglePresence(isPresent) {
                  if (isPresent) {
                      // Check if hdmi output is already on
                      exec("/opt/vc/bin/tvservice -s").stdout.on('data', function(data) {
                          if (data.indexOf("0x120002") !== -1)
                              exec("/opt/vc/bin/tvservice --preferred && chvt 6 && chvt 7", null);
                  } else {
                      exec("/opt/vc/bin/tvservice -o", null);
          So you are using “tvserice -o” which seems not to work for me.
          would this be an alternative? Link
          Executing the commands vom @E3V3A here Link brings the Monitor Signal back, but only 1 time.
          Any idea?
            bobbythemoh
            Hi, using this command brings back the Monitor signal:
            xset -display :0 -dpms
            • idoodlerI
              I just implemented vcgencmd it looks like it is a bit quicker. I will check it out the next few days and will push it if everything works.
              E 1 Reply Last reply
              • E
                E3V3A @idoodler
                @idoodler said in MMM-Loxone:
                Yeah, but that only work with Rapsberry Piss , so if you want it to work on other devices, you need to use xset, and if you want to use xset on the Pi, you now also need to tell it that the blank screen should be black, with xsetroot -display :0 -solid black.
                “Everything I do (here) is for free – altruism is the way!”
                idoodlerI 1 Reply Last reply
                • idoodlerI
                  idoodler Module Developer @E3V3A
                  @e3v3a I think xset just blanks the screen without powering off the HDMI signal?
                  • idoodlerI
                    @bobbythemoh Can you please post your pm2 log. You can optain it by executing pm2 log MagicMirror if you are using pm2.
                    I just detected some unhandled rejections which may cause the black screen.
                      bobbythemoh
                      pi@MagicMirror:~ $ pm2 log MagicMirror
                      [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                      /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
                      0|MagicMir | [865:0515/052002.614227:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
                      0|MagicMir | #0 0x0000007fd980 <unknown>
                      0|MagicMir | #1 0x000000841db2 <unknown>
                      0|MagicMir | #2 0x0000012700d2 <unknown>
                      0|MagicMir |
                      0|MagicMir | npm ERR! code ELIFECYCLE
                      0|MagicMir | npm ERR! errno 1
                      0|MagicMir | npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                      0|MagicMir | npm ERR! Exit status 1
                      0|MagicMir | npm ERR! Failed at the magicmirror@2.3.1 start script.
                      0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      0|MagicMir |
                      0|MagicMir | npm ERR! A complete log of this run can be found in:
                      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2018-05-15T05_31_52_606Z-debug.log
                      /home/pi/.pm2/logs/MagicMirror-out-0.log last 15 lines:
                      0|MagicMir | MMM-Loxone Search LightControls and LightV2Controls in room
                      0|MagicMir | MMM-Loxone Found LightControl (Lichtsteuerung) in room OG Bad
                      0|MagicMir | MMM-Loxone NotificationUuid: 0ea3ebd1-008d-029d-ffff390cde3b9b45
                      0|MagicMir | MMM-Loxone Enabling statusupdates
                      0|MagicMir | MMM-Loxone Successfully executed 'dev/sps/enablebinstatusupdate' with code 200 and value 1
                      0|MagicMir | MMM-Loxone Got lightMood change [1]
                      0|MagicMir | MMM-Loxone Got room temperature: 21.8
                      0|MagicMir | MMM-Loxone Got lightMood change [777]
                      0|MagicMir | MMM-Loxone Got lightMood change [778]
                      • idoodlerI
                        idoodler Module Developer @bobbythemoh
                        @bobbythemoh Ok, thanks. No unhandled rejections.
                          bobbythemoh
                          @idoodler , did “vcgencmd” solve the issue?
                          • idoodlerI
                            @bobbythemoh No. I think there is an issue within the communication module for the Miniserver. If the module crashes when the screen is turned off the screen will never be turned on again and vice versa.
                              bobbythemoh
                              @idoodler , i dont think so. Let me explain the behaviour of the Module:
                              Light in the Room Switched ON, Booting the Mirror gives me the Mirror as it should be
                              Switching the Light off, switches the Monitor off.
                              Switchint the Light on again activates the Background light of the Monitor but does not give content
                              Entering the command “xset -display :0 -dpms” while the light is switched ON brings back the content
                              in my opinion this is not a miniserver issue since I can observe an reaction (Backlight of the monitor comes alive), this is an issue with the “tvservice”
                              idoodlerI 2 Replies Last reply
                              • idoodlerI
                                @bobbythemoh You misunderstoodme. I think the issue is in my code with the communication layer crashing resulting in not receiving any state changes, hence the mirror doesn’t know to enable the display again.
                                I just found an issue and testing it over the night.
                                • idoodlerI
                                  @bobbythemoh I just pushed some changes, please update. Don’t forget to execute npm install after updating MMM-Loxone.
                                    bobbythemoh
                                    David, you are my hero, it works!!!
                                    Energy Consumption of RPI + 24" Monitor Powered ON = 56W; 3.4W if no one is present in the room. AWESOME!
                                    Thank you for the efforts!
                                    May I also ask you for the feature request with displaying variables from the Miniserver? Id like to see things like the PV production or an analog value like the level in a tank.
                                    Thank you so much!
                                    • idoodlerI
                                      @bobbythemoh please create a separate Issue in Github for the power consumption thing.
                                      • idoodlerI
                                        @bobbythemoh Please check the latest version of MMM-Loxone. It’s not possible to display custom states:)
                                          bobbythemoh
                                          Hi @idoodler ,
                                          I have just tried to get the “observingUuids” working.
                                          I dont get anything on the MM. My question: Is there a way to test if I did something wrong with “ALERT” or with “MMM-Loxone”
                                                              module: "alert",
        //display_time: "3500",
        //alert_effect: "jelly",
        //effect: "slide",
        //position: "center"
                                          MMM-Loxone:
                                                              module: "MMM-Loxone",
                                                              //position: "top_right", //macht keinen Sinn, ga kein GUI
        host: "192.168.0.200",
        user: "XXX",
        pwd: "XXX",
        presence: "true",
        //roomUuid: "0ea3ebd1-00eb-0517-ffff390cde3b9b45", //Arbeitszimmer
        roomUuid: "0ea3ebd1-00eb-04ef-ffff390cde3b9b45", //Badezimmer
        showInfoNotifications: "true",
        showErrorNotifications: "true",
        showSystemNotifications: "true",
        observingUuids:[
        "103d9aaf-0037-597e-ffff390cde3b9b45",//Bad Luftfeuchte
        "11aee03b-01ea-a7bb-ffff390cde3b9b45"
                                          Furthermore, i found and interesting module called “mmm-openhabfloorplan”. I have seen it is using a HTTP server on the MagicMirror, would it be possible to adapt it for Loxone aswell?
                                          Regading displaying Charts: I found an extension called “MMM-ImagePhotos” Do you have any Idea, how the “Energy-Monitor” data can be exported on regular basis, like every minute? I was thinking of making a python skript that creates a picture every X Minutes and puts it to the display with the MMM-ImagePhotos. Do you have any suggestions?
                                          Thank you in advance.
                                          Robert
                                          • idoodlerI
                                            @bobbythemoh If you use the the observingUuids you need to add the module position.
                                            The alert module config looks good, what notifications do you want to display?
                                            The mmm-openhabfloorplan module looks cool. I will definetly look into it :thumbs_up:
                                            You can create a python periodicaly fetches the statistic files from your Miniserver (http://192.168.0.200/stats) and creates an image from it, saves in the directory the MMM-ImagePhotos module listens to.
                                            • 2 / 5
