    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 107.1k Views 14 Watching
      bobbythemoh
      @idoodler yes i did reboot. and i just uninstalled xscreensaver (after that i did a reboot) but no change in the behaviour.
      @E3V3A I used “uname -a”:
      Linux MagicMirror 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
        SuperSchenk @bobbythemoh
        @bobbythemoh said in MMM-Loxone:
        Bobby do you have a solution for this? I’m having the exact same problem since updating my pi to the latest version of rasbian
          bobbythemoh
          no, solution yet unforunately.
          • idoodlerI Offline
            idoodler Module Developer
            I just experienced a similar issue, but It appears not to be caused by MMM-Loxone. I am Invastigating it…
              bobbythemoh
              @idoodler
              I found this passage in your code:
                  _togglePresence: function _togglePresence(isPresent) {
                      if (isPresent) {
                          // Check if hdmi output is already on
                          exec("/opt/vc/bin/tvservice -s").stdout.on('data', function(data) {
                              if (data.indexOf("0x120002") !== -1)
                                  exec("/opt/vc/bin/tvservice --preferred && chvt 6 && chvt 7", null);
                      } else {
                          exec("/opt/vc/bin/tvservice -o", null);
              So you are using “tvserice -o” which seems not to work for me.
              would this be an alternative? Link
              Executing the commands vom @E3V3A here Link brings the Monitor Signal back, but only 1 time.
              Any idea?
                bobbythemoh
                Hi, using this command brings back the Monitor signal:
                xset -display :0 -dpms
                • idoodlerI Offline
                  I just implemented vcgencmd it looks like it is a bit quicker. I will check it out the next few days and will push it if everything works.
                  • E Offline
                    E3V3A @idoodler
                    @idoodler said in MMM-Loxone:
                    Yeah, but that only work with Rapsberry Piss , so if you want it to work on other devices, you need to use xset, and if you want to use xset on the Pi, you now also need to tell it that the blank screen should be black, with xsetroot -display :0 -solid black.
                    “Everything I do (here) is for free – altruism is the way!”
                    idoodlerI 1 Reply Last reply Reply Quote 0
                    • idoodlerI Offline
                      idoodler Module Developer @E3V3A
                      @e3v3a I think xset just blanks the screen without powering off the HDMI signal?
                      • idoodlerI Offline
                        @bobbythemoh Can you please post your pm2 log. You can optain it by executing pm2 log MagicMirror if you are using pm2.
                        I just detected some unhandled rejections which may cause the black screen.
                          bobbythemoh
                          pi@MagicMirror:~ $ pm2 log MagicMirror
                          [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                          /home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
                          0|MagicMir | [865:0515/052002.614227:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
                          0|MagicMir | #0 0x0000007fd980 <unknown>
                          0|MagicMir | #1 0x000000841db2 <unknown>
                          0|MagicMir | #2 0x0000012700d2 <unknown>
                          0|MagicMir |
                          0|MagicMir | npm ERR! code ELIFECYCLE
                          0|MagicMir | npm ERR! errno 1
                          0|MagicMir | npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                          0|MagicMir | npm ERR! Exit status 1
                          0|MagicMir | npm ERR! Failed at the magicmirror@2.3.1 start script.
                          0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                          0|MagicMir |
                          0|MagicMir | npm ERR! A complete log of this run can be found in:
                          0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2018-05-15T05_31_52_606Z-debug.log
                          /home/pi/.pm2/logs/MagicMirror-out-0.log last 15 lines:
                          0|MagicMir | MMM-Loxone Search LightControls and LightV2Controls in room
                          0|MagicMir | MMM-Loxone Found LightControl (Lichtsteuerung) in room OG Bad
                          0|MagicMir | MMM-Loxone NotificationUuid: 0ea3ebd1-008d-029d-ffff390cde3b9b45
                          0|MagicMir | MMM-Loxone Enabling statusupdates
                          0|MagicMir | MMM-Loxone Successfully executed 'dev/sps/enablebinstatusupdate' with code 200 and value 1
                          0|MagicMir | MMM-Loxone Got lightMood change [1]
                          0|MagicMir | MMM-Loxone Got room temperature: 21.8
                          0|MagicMir | MMM-Loxone Got lightMood change [777]
                          0|MagicMir | MMM-Loxone Got lightMood change [778]
                          • idoodlerI Offline
                            idoodler Module Developer @bobbythemoh
                            @bobbythemoh Ok, thanks. No unhandled rejections.
                              bobbythemoh
                              @idoodler , did “vcgencmd” solve the issue?
                              • idoodlerI Offline
                                @bobbythemoh No. I think there is an issue within the communication module for the Miniserver. If the module crashes when the screen is turned off the screen will never be turned on again and vice versa.
                                  bobbythemoh
                                  @idoodler , i dont think so. Let me explain the behaviour of the Module:
                                  Light in the Room Switched ON, Booting the Mirror gives me the Mirror as it should be
                                  Switching the Light off, switches the Monitor off.
                                  Switchint the Light on again activates the Background light of the Monitor but does not give content
                                  Entering the command “xset -display :0 -dpms” while the light is switched ON brings back the content
                                  in my opinion this is not a miniserver issue since I can observe an reaction (Backlight of the monitor comes alive), this is an issue with the “tvservice”
                                  idoodlerI 2 Replies Last reply Reply Quote 0
                                  • idoodlerI Offline
                                    @bobbythemoh You misunderstoodme. I think the issue is in my code with the communication layer crashing resulting in not receiving any state changes, hence the mirror doesn’t know to enable the display again.
                                    I just found an issue and testing it over the night.
                                    • idoodlerI Offline
                                      @bobbythemoh I just pushed some changes, please update. Don’t forget to execute npm install after updating MMM-Loxone.
                                        bobbythemoh
                                        David, you are my hero, it works!!!
                                        Energy Consumption of RPI + 24" Monitor Powered ON = 56W; 3.4W if no one is present in the room. AWESOME!
                                        Thank you for the efforts!
                                        May I also ask you for the feature request with displaying variables from the Miniserver? Id like to see things like the PV production or an analog value like the level in a tank.
                                        Thank you so much!
                                        idoodlerI 2 Replies Last reply Reply Quote 1
                                        • idoodlerI Offline
                                          @bobbythemoh please create a separate Issue in Github for the power consumption thing.
                                          • idoodlerI Offline
                                            @bobbythemoh Please check the latest version of MMM-Loxone. It’s not possible to display custom states:)
                                            • 2 / 5
