    Mouse Cursor Visible On Reboot
    6 Posts 3 Posters 11.0k Views 2 Watching
    • O Offline
      olliewarren411
      Hi Guys,
      Any suggestions to make the mouse cursor invisible on reboot?
      I’ve changed all my LXDE settings, meaning when i move the mouse it disappears.
      But when my mirror reboots and there is no mouse movement the cursor sits there right in the middle until I plug in a mouse and move it, then it goes?
      Any help would be greatly appreciated. Thanks
      Ollie
      • G Offline
        gshimself
        @olliewarren411 you sure you have
        "@xset s off
        @xset -dpms
        @xset s noblank
        in /etc/xdg/lxsession/LXDE-pi ? Mine works just fine with those values
        • O Offline
          olliewarren411 @gshimself
          @gshimself
          Thanks for your reply. I do have the LXDE-pi/autostart set correctly as you say as well as the LXDE/autostart.
          The mouse cursor does disappear but only when you try and move it.
          • G Offline
            gshimself @olliewarren411
            @olliewarren411 Okey. Well it was long ago I did install my rasp. so I’ve might forgot how I did it. But do you have “unclutter” installed?
            http://raspberrypi.stackexchange.com/questions/2092/hide-cursor-in-raspbian
            O 1 Reply Last reply Reply Quote 1
            • O Offline
              @gshimself
              That’s worked perfectly thank you.
              • MichMichM Offline
                MichMich
                Additional configuration tips can be found here: https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
