    Assistant Error
    17 Posts 6 Posters 10.7k Views 6 Watching
      shep99
      Thanks very much @sean appreciated. I did re install, and ran google-auth then electron-rebuild. After that, I did have to rename the folders from electron-v1.4-linux-arm-{libc} to electron-v1.4-linux-arm-glibc and everything loaded! :) I created my own models smartmirror.pmdl, and snowboy.pmdl ) with snowboy from the RPI that is running MM with the MIC, and running the following two commands I can record and play back WAV files with arecord:
      arecord --device=plughw:1,0 --format S16_LE --rate 44100 -c1 test.wav
      aplay --device=plughw:0,0 test.wav
      When MM startups up, I can here an initial ding, but cannot trigger any key word detection for some reason? I was wondering if my config might be off? Below is my configuration:
        module: 'MMM-Assistant',
        position: 'bottom_left',
          assistant: {
            auth: {
              keyFilePath: "secret.json", //When you want to change the location of this file, set this.
              savedTokensPath: "resources/tokens.js" //When you want to change the location of this file, set this.
            audio: {
              encodingIn: "LINEAR16", //Ignore this. I think you don't need to change this.
              sampleRateOut: 16000 //Ignore this. I think you don't need to change this.
          snowboy: {
            models: [
                file: "resources/smartmirror.pmdl",
                sensitivity: 0.5,
                hotwords : "MIRROR" //One of models should be "MIRROR"
                file: "resources/snowboy.pmdl",
                sensitivity: 0.5,
                hotwords : "ASSISTANT" //One of models should be "ASSISTANT"
          record: {
            threshold: 0, //Ignore this. I think you don't need to change this.
            verbose:false, //true for checking recording status.
            recordProgram: 'arecord', //You can use 'rec', 'sox'. But I recommend use 'arecord'.
            silence: 2.0 //Ignore this. I think you don't need to change this.
          stt: {
            auth: [{
              projectId: 'smartmirror-XXXXX-REMOVED', //ProjectId from Google Console
              keyFilename: 'config.stt.auth.json'
            }], //You can use multi accounts for saving money.
            request: {
              encoding: 'LINEAR16', //Ignore this. I think you don't need to change this.
              sampleRateHertz: 16000, //Ignore this. I think you don't need to change this.
              languageCode: 'en-US' //See https://cloud.google.com/speech/docs/languages
          speak: {
            useAlert: true, //If you want to show the text of speech, set this true. But It could be ignored by command of modules directly.
            language: 'en-US', //If you want to set the default language of speech of command result, set this.
          alias: [
              "help :command" : ["teach me :command", "what is :command"]
          ] // You can use aliases for difficult pronunciation or easy using.
      I am trying to activate using snowboy, smartmirror, assistant, google, etc but it never triggers.
      Thanks @sean really appreciated.
        shep99
        Just wanted to repost here, @sean thanks and got it going. This is an INCREDIBLE module and thank you. My problem was with my MIC after setup. If anyone else is coming across this, this link here helped to get my MIC setup properly:
        https://snowboy.kitt.ai/docs
        Great module @sean absolutely incredible! Thanks
        ChrisC E 3 Replies Last reply
        • ChrisC
          Chris @shep99
          I am trying to run this module but I am having problems.
          Indeed I installed it by following all your previous indications.
          The mirror is launched correctly and I have the beep module start.
          If I call the module with the keyword, it triggers. I ask my question and I only have a hatched voice in response.
          I did not have any problems of this type with open-jarvis which is also based on snowboy.
          I of course neutralize open jarvis to avoid conflicts on the sound card.
          I think I missed a step on the setup.
          The config.stt.auth.json file is placed in the resources folder or in the MMM-Assistant folder?
          When I go on the google developer console, I see requests for the google assistant API but no requests for Google Cloud Speech API.
          I add my boot log:
          pi@raspberrypi:~/MagicMirror $ npm start dev
          > magicmirror@2.2.1 start /home/pi/MagicMirror
          > sh run-start.sh "dev"
          Starting MagicMirror: v2.2.1
          Loading config ...
          Loading module helpers ...
          No helper found for module: calendar_monthly.
          Module helper loaded: MMM-MyCommute
          Module helper loaded: MMM-Ratp
          Module helper loaded: MMM-SoccerLiveScore
          Module helper loaded: MMM-soccer
          No helper found for module: MMM-Globe.
          Module helper loaded: MMM-Remote-Control
          Module helper loaded: mmm-suncalc
          Module helper loaded: MMM-WunderGround
          Module helper loaded: MMM-NOAA
          No helper found for module: mmm-wu-moonphase.
          Module helper loaded: MMM-Assistant
          Module helper loaded: MMM-Tools
          No helper found for module: MMM-Snow.
          All module helpers loaded.
          Server started ...
          Connecting socket for: MMM-MyCommute
          ====================== Starting node_helper for module [MMM-MyCommute]
          Connecting socket for: MMM-Ratp
          MMM-Ratp- NodeHelper started
          Connecting socket for: MMM-SoccerLiveScore
          MMM-SoccerLiveScore helper started...
          Connecting socket for: MMM-soccer
          Starting module: MMM-soccer
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: mmm-suncalc
          Starting node_helper for mmm-suncalc:
          Connecting socket for: MMM-WunderGround
          MMM-WunderGround helper started ...
          Connecting socket for: MMM-NOAA
          Starting module: MMM-NOAA
          Connecting socket for: MMM-Assistant
          Connecting socket for: MMM-Tools
          Starting module: newsfeed
          Launching application.
          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXX/private-XXX/basic.ics - Interval: 300000
          Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
          GET_WUNDERGROUND
          [ASSTNT] Snowboy Activated
          Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
          [ASSTNT] Assistant Activated
          [ASSTNT] GA Transcription:  don't wanna meet you to do now
          as well as my config file:
          			module: "MMM-Assistant",
          				assistant: {
          				auth: {
          			audio: {
          			snowboy: {
          			models: [
          			file: "resources/miroir.pmdl",
          			sensitivity: 0.5,
          			file: "resources/Ok Google.pmdl",
          			sensitivity: 0.5,
          			record: {
          			recordProgram: "arecord", //You can use "rec", "sox". But I recommend use "arecord".
          			stt: {
          			auth: [{
          			projectId: "my-project-1505046981535", //ProjectId from Google Console
          			keyFilename: "config.stt.auth.json"
          			request: {
          			encoding: "LINEAR16", //Ignore this. I think you don't need to change this.
          			languageCode: "fr-FR" //See https://cloud.google.com/speech/docs/languages
          			speak: {
          			language: "fr-FR", //If you want to set the default language of speech of command result, set this.
          			alias: [
          Hoping you can help me,
          Regards,
            shep99
            @sean is it possible you can elaborate on these settings in config? I only want to use Google assistant, so have commented out the “MIRROR” hotword, but sometime the MIC picks up on words that are not like my trained model, and sits on the assistant logo waiting for something, and there’s no way to get out of it without restarting the mirror. ie, these settings in particular:
            sensitivity:
                      file: "resources/google.pmdl",
                      sensitivity: 0.7,
            silence and verbose:
                record: {
            Thanks again!
            ? 1 Reply Last reply
            • ChrisC
              Chris @shep99
              @shep99 said in Assistant Error:
              I still have problems to use despite several unsuccessful attempts.
              Could you detail the installation procedure you used?
              Thank you in advance,
                A Former User @shep99
                @shep99
                Frankly, I have also pmdl problem. When I use umdl, everything is ok. But, pmdl is not worked properly, I don’t know why.
                • E
                  E3V3A @shep99
                  @shep99 Can you please post your ALSA config?
                  cat ~/.asoundrc
                  cat /proc/asound/modules
                  cat /proc/asound/devices
                  Thanks.
                  “Everything I do (here) is for free – altruism is the way!”
                  • E
                    E3V3A
                    Just want to tell everyone that this module works very well.
                    I had some initial compile issues and trying to get the correct GA authentication, but after that it worked.
                    Now, I’m looking at Alexa, since I’d like both Alexa and GA + MM working.
                    Please see the github issue for solution in case you missed it.
                    • W
                      wonjerry
                      • W
                        wonjerry
                        • W
                          wonjerry
                          • W
                            wonjerry @Guest
                            @sean @shep99 @acogkenf
                            Hello I have solved this problem this way.
                            “npm install --runtime=electron --target=YOUR_ELECTRON_VERSION”
                            Specify the environment and version and you can load grpc in proper way
