    Assistant Error
    17 Posts 6 Posters 10.4k Views 6 Watching
    • ChrisC Offline
      Chris @shep99
      I am trying to run this module but I am having problems.
      Indeed I installed it by following all your previous indications.
      The mirror is launched correctly and I have the beep module start.
      If I call the module with the keyword, it triggers. I ask my question and I only have a hatched voice in response.
      I did not have any problems of this type with open-jarvis which is also based on snowboy.
      I of course neutralize open jarvis to avoid conflicts on the sound card.
      I think I missed a step on the setup.
      The config.stt.auth.json file is placed in the resources folder or in the MMM-Assistant folder?
      When I go on the google developer console, I see requests for the google assistant API but no requests for Google Cloud Speech API.
      I add my boot log:
      pi@raspberrypi:~/MagicMirror $ npm start dev
      > magicmirror@2.2.1 start /home/pi/MagicMirror
      > sh run-start.sh "dev"
      Starting MagicMirror: v2.2.1
      Loading config ...
      Loading module helpers ...
      No helper found for module: calendar_monthly.
      Module helper loaded: MMM-MyCommute
      Module helper loaded: MMM-Ratp
      Module helper loaded: MMM-SoccerLiveScore
      Module helper loaded: MMM-soccer
      No helper found for module: MMM-Globe.
      Module helper loaded: MMM-Remote-Control
      Module helper loaded: mmm-suncalc
      Module helper loaded: MMM-WunderGround
      Module helper loaded: MMM-NOAA
      No helper found for module: mmm-wu-moonphase.
      Module helper loaded: MMM-Assistant
      Module helper loaded: MMM-Tools
      No helper found for module: MMM-Snow.
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-MyCommute
      ====================== Starting node_helper for module [MMM-MyCommute]
      Connecting socket for: MMM-Ratp
      MMM-Ratp- NodeHelper started
      Connecting socket for: MMM-SoccerLiveScore
      MMM-SoccerLiveScore helper started...
      Connecting socket for: MMM-soccer
      Starting module: MMM-soccer
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: mmm-suncalc
      Starting node_helper for mmm-suncalc:
      Connecting socket for: MMM-WunderGround
      MMM-WunderGround helper started ...
      Connecting socket for: MMM-NOAA
      Starting module: MMM-NOAA
      Connecting socket for: MMM-Assistant
      Connecting socket for: MMM-Tools
      Starting module: newsfeed
      Launching application.
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXX/private-XXX/basic.ics - Interval: 300000
      Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
      GET_WUNDERGROUND
      [ASSTNT] Snowboy Activated
      Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
      [ASSTNT] Assistant Activated
      [ASSTNT] GA Transcription:  don't wanna meet you to do now
      as well as my config file:
      			module: "MMM-Assistant",
      				assistant: {
      				auth: {
      				keyFilePath: "secret.json", //When you want to change the location of this file, set this.
      				savedTokensPath: "resources/tokens.js" //When you want to change the location of this file, set this.
      			audio: {
      			encodingIn: "LINEAR16", //Ignore this. I think you don't need to change this.
      			sampleRateOut: 16000 //Ignore this. I think you don't need to change this.
      			snowboy: {
      			models: [
      			file: "resources/miroir.pmdl",
      			sensitivity: 0.5,
      			hotwords : "MIRROR" //One of models should be "MIRROR"
      			file: "resources/Ok Google.pmdl",
      			sensitivity: 0.5,
      			hotwords : "ASSISTANT" //One of models should be "ASSISTANT"
      			record: {
      			threshold: 0, //Ignore this. I think you don't need to change this.
      			verbose:false, //true for checking recording status.
      			recordProgram: "arecord", //You can use "rec", "sox". But I recommend use "arecord".
      			silence: 2.0 //Ignore this. I think you don't need to change this.
      			stt: {
      			auth: [{
      			projectId: "my-project-1505046981535", //ProjectId from Google Console
      			keyFilename: "config.stt.auth.json"
      			}], //You can use multi accounts for saving money.
      			request: {
      			encoding: "LINEAR16", //Ignore this. I think you don't need to change this.
      			sampleRateHertz: 16000, //Ignore this. I think you don't need to change this.
      			languageCode: "fr-FR" //See https://cloud.google.com/speech/docs/languages
      			speak: {
      			useAlert: true, //If you want to show the text of speech, set this true. But It could be ignored by command of modules directly.
      			language: "fr-FR", //If you want to set the default language of speech of command result, set this.
      			alias: [
      			"help :command" : ["teach me :command", "what is :command"]
      			] // You can use aliases for difficult pronunciation or easy using.
      Hoping you can help me,
      Regards,
        shep99
        @sean is it possible you can elaborate on these settings in config? I only want to use Google assistant, so have commented out the “MIRROR” hotword, but sometime the MIC picks up on words that are not like my trained model, and sits on the assistant logo waiting for something, and there’s no way to get out of it without restarting the mirror. ie, these settings in particular:
        sensitivity:
                  file: "resources/google.pmdl",
                  sensitivity: 0.7,
        silence and verbose:
            record: {
              recordProgram: 'arecord', //You can use 'rec', 'sox'. But I recommend use 'arecord'.
        Thanks again!
        • ChrisC Offline
          Chris @shep99
          @shep99 said in Assistant Error:
          Just wanted to repost here, @sean thanks and got it going. This is an INCREDIBLE module and thank you. My problem was with my MIC after setup. If anyone else is coming across this, this link here helped to get my MIC setup properly:
          https://snowboy.kitt.ai/docs
          Great module @sean absolutely incredible! Thanks
          I still have problems to use despite several unsuccessful attempts.
          Could you detail the installation procedure you used?
          Thank you in advance,
            A Former User @shep99
            @shep99
            Frankly, I have also pmdl problem. When I use umdl, everything is ok. But, pmdl is not worked properly, I don’t know why.
            • E Offline
              E3V3A @shep99
              @shep99 Can you please post your ALSA config?
              cat ~/.asoundrc
              cat /proc/asound/modules
              cat /proc/asound/devices
              Thanks.
              “Everything I do (here) is for free – altruism is the way!”
              • E Offline
                E3V3A
                Just want to tell everyone that this module works very well.
                I had some initial compile issues and trying to get the correct GA authentication, but after that it worked.
                Now, I’m looking at Alexa, since I’d like both Alexa and GA + MM working.
                Please see the github issue for solution in case you missed it.
                • W Offline
                  wonjerry
                  • W Offline
                    wonjerry
                    • W Offline
                      wonjerry
                      • W Offline
                        wonjerry @Guest
                        @sean @shep99 @acogkenf
                        Hello I have solved this problem this way.
                        “npm install --runtime=electron --target=YOUR_ELECTRON_VERSION”
                        Specify the environment and version and you can load grpc in proper way
