    Assistant Error
    17 Posts 6 Posters 10.7k Views 6 Watching
    • A
      acogkenf
      Starting MagicMirror: v2.1.3
      Loading config ...
      Loading module helpers ...
      Initializing mm-music-player module helper ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/electron-v1.7-linux-arm-glibc/grpc_node.node'
      App threw an error during load
          at Module._resolveFilename (module.js:470:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:418:25)
          at Module.require (module.js:498:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/grpc_extension.js:30:15)
          at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/grpc_extension.js:34:3)
          at Module._compile (module.js:571:32)
          at Object.Module._extensions..js (module.js:580:10)
          at Module.load (module.js:488:32)
      { Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/electron-v1.7-linux-arm-glibc/grpc_node.node'
          at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
      Launching application.
        shep99
        I am also getting this error unfortunately… I beleive it might be due to this:
        “Currently under Electron 1.7, there might be non-compatible issues of grpc. I will make a patch for this, but it will take somewhat time. sorry.”
          A Former User
          @shep99 @acogkenf
          If you go to '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/, there might be some weird directory name which has {something}, then change it to electron-v1.7-linux-arm-glibc.
          W 1 Reply Last reply
            shep99
            Thank you @Sean appreciated! I tried that ( also tried the steps outlined here ) : https://github.com/eouia/MMM-Assistant/wiki/Urgent-Issue-on-installation
            And after install Ihad two folders in /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/
            electron-v1.4-linux-arm-{libc}
            and
            node-v48-linux-arm-glibc
            I renamed the folder electron-v1.4-linux-arm-{libc} to electron-v1.7-linux-arm-glibc but when I run
            cd /modules/MMM-Assistant
            node google-auth.js
            I get the following error:
            pi@smartmirror1:~/MagicMirror/modules/MMM-Assistant $ node google-auth.js
            module.js:597
              return process.dlopen(module, path._makeLong(filename));
            Error: Module version mismatch. Expected 48, got 50.
                at Error (native)
                at Object.Module._extensions..node (module.js:597:18)
                at Module.load (module.js:487:32)
                at tryModuleLoad (module.js:446:12)
                at Function.Module._load (module.js:438:3)
                at Module.require (module.js:497:17)
                at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/grpc_extension.js:38:15)
                at Module._compile (module.js:570:32)
                at Object.Module._extensions..js (module.js:579:10)
            ? 1 Reply Last reply
              A Former User @shep99
              @shep99
              Hmmm… This error might be derived from the various different versions of node.js of MM, Electron, Google API and other dependencies. MMM-Assistant should have many dependencies, so always the version problem makes me crazy. :(
              I’m not sure about your situation, but I think google-auth should be performed before electron-rebuild. because that authentification library uses the different version of modules with other dependencies. I think you’d better try re-install.
                shep99
                Thanks very much @sean appreciated. I did re install, and ran google-auth then electron-rebuild. After that, I did have to rename the folders from electron-v1.4-linux-arm-{libc} to electron-v1.4-linux-arm-glibc and everything loaded! :) I created my own models smartmirror.pmdl, and snowboy.pmdl ) with snowboy from the RPI that is running MM with the MIC, and running the following two commands I can record and play back WAV files with arecord:
                arecord --device=plughw:1,0 --format S16_LE --rate 44100 -c1 test.wav
                aplay --device=plughw:0,0 test.wav
                When MM startups up, I can here an initial ding, but cannot trigger any key word detection for some reason? I was wondering if my config might be off? Below is my configuration:
                  module: 'MMM-Assistant',
                  position: 'bottom_left',
                    assistant: {
                      auth: {
                        keyFilePath: "secret.json", //When you want to change the location of this file, set this.
                        savedTokensPath: "resources/tokens.js" //When you want to change the location of this file, set this.
                      audio: {
                        encodingIn: "LINEAR16", //Ignore this. I think you don't need to change this.
                        sampleRateOut: 16000 //Ignore this. I think you don't need to change this.
                    snowboy: {
                      models: [
                          file: "resources/smartmirror.pmdl",
                          sensitivity: 0.5,
                          hotwords : "MIRROR" //One of models should be "MIRROR"
                          file: "resources/snowboy.pmdl",
                          sensitivity: 0.5,
                          hotwords : "ASSISTANT" //One of models should be "ASSISTANT"
                    record: {
                      threshold: 0, //Ignore this. I think you don't need to change this.
                      verbose:false, //true for checking recording status.
                      recordProgram: 'arecord', //You can use 'rec', 'sox'. But I recommend use 'arecord'.
                      silence: 2.0 //Ignore this. I think you don't need to change this.
                    stt: {
                      auth: [{
                        projectId: 'smartmirror-XXXXX-REMOVED', //ProjectId from Google Console
                        keyFilename: 'config.stt.auth.json'
                      }], //You can use multi accounts for saving money.
                      request: {
                        encoding: 'LINEAR16', //Ignore this. I think you don't need to change this.
                        sampleRateHertz: 16000, //Ignore this. I think you don't need to change this.
                        languageCode: 'en-US' //See https://cloud.google.com/speech/docs/languages
                    speak: {
                      useAlert: true, //If you want to show the text of speech, set this true. But It could be ignored by command of modules directly.
                      language: 'en-US', //If you want to set the default language of speech of command result, set this.
                    alias: [
                        "help :command" : ["teach me :command", "what is :command"]
                    ] // You can use aliases for difficult pronunciation or easy using.
                I am trying to activate using snowboy, smartmirror, assistant, google, etc but it never triggers.
                Thanks @sean really appreciated.
                  shep99
                  Just wanted to repost here, @sean thanks and got it going. This is an INCREDIBLE module and thank you. My problem was with my MIC after setup. If anyone else is coming across this, this link here helped to get my MIC setup properly:
                  https://snowboy.kitt.ai/docs
                  Great module @sean absolutely incredible! Thanks
                  ChrisC E 3 Replies Last reply
                  • ChrisC
                    Chris @shep99
                    I am trying to run this module but I am having problems.
                    Indeed I installed it by following all your previous indications.
                    The mirror is launched correctly and I have the beep module start.
                    If I call the module with the keyword, it triggers. I ask my question and I only have a hatched voice in response.
                    I did not have any problems of this type with open-jarvis which is also based on snowboy.
                    I of course neutralize open jarvis to avoid conflicts on the sound card.
                    I think I missed a step on the setup.
                    The config.stt.auth.json file is placed in the resources folder or in the MMM-Assistant folder?
                    When I go on the google developer console, I see requests for the google assistant API but no requests for Google Cloud Speech API.
                    I add my boot log:
                    pi@raspberrypi:~/MagicMirror $ npm start dev
                    > magicmirror@2.2.1 start /home/pi/MagicMirror
                    > sh run-start.sh "dev"
                    Starting MagicMirror: v2.2.1
                    Loading config ...
                    No helper found for module: calendar_monthly.
                    Module helper loaded: MMM-MyCommute
                    Module helper loaded: MMM-Ratp
                    Module helper loaded: MMM-SoccerLiveScore
                    Module helper loaded: MMM-soccer
                    No helper found for module: MMM-Globe.
                    Module helper loaded: MMM-Remote-Control
                    Module helper loaded: mmm-suncalc
                    Module helper loaded: MMM-WunderGround
                    Module helper loaded: MMM-NOAA
                    No helper found for module: mmm-wu-moonphase.
                    Module helper loaded: MMM-Assistant
                    Module helper loaded: MMM-Tools
                    No helper found for module: MMM-Snow.
                    All module helpers loaded.
                    Server started ...
                    Connecting socket for: MMM-MyCommute
                    ====================== Starting node_helper for module [MMM-MyCommute]
                    Connecting socket for: MMM-Ratp
                    MMM-Ratp- NodeHelper started
                    Connecting socket for: MMM-SoccerLiveScore
                    MMM-SoccerLiveScore helper started...
                    Connecting socket for: MMM-soccer
                    Starting module: MMM-soccer
                    Connecting socket for: MMM-Remote-Control
                    Starting node helper for: MMM-Remote-Control
                    Connecting socket for: mmm-suncalc
                    Starting node_helper for mmm-suncalc:
                    Connecting socket for: MMM-WunderGround
                    MMM-WunderGround helper started ...
                    Connecting socket for: MMM-NOAA
                    Starting module: MMM-NOAA
                    Connecting socket for: MMM-Assistant
                    Connecting socket for: MMM-Tools
                    Starting module: newsfeed
                    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXX/private-XXX/basic.ics - Interval: 300000
                    Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
                    GET_WUNDERGROUND
                    [ASSTNT] Snowboy Activated
                    Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
                    [ASSTNT] Assistant Activated
                    [ASSTNT] GA Transcription:  don't wanna meet you to do now
                    as well as my config file:
                    			module: "MMM-Assistant",
                    				assistant: {
                    				auth: {
                    			audio: {
                    			snowboy: {
                    			models: [
                    			file: "resources/miroir.pmdl",
                    			sensitivity: 0.5,
                    			file: "resources/Ok Google.pmdl",
                    			sensitivity: 0.5,
                    			record: {
                    			recordProgram: "arecord", //You can use "rec", "sox". But I recommend use "arecord".
                    			stt: {
                    			auth: [{
                    			projectId: "my-project-1505046981535", //ProjectId from Google Console
                    			keyFilename: "config.stt.auth.json"
                    			request: {
                    			encoding: "LINEAR16", //Ignore this. I think you don't need to change this.
                    			languageCode: "fr-FR" //See https://cloud.google.com/speech/docs/languages
                    			speak: {
                    			language: "fr-FR", //If you want to set the default language of speech of command result, set this.
                    			alias: [
                    Hoping you can help me,
                    Regards,
                      shep99
                      @sean is it possible you can elaborate on these settings in config? I only want to use Google assistant, so have commented out the “MIRROR” hotword, but sometime the MIC picks up on words that are not like my trained model, and sits on the assistant logo waiting for something, and there’s no way to get out of it without restarting the mirror. ie, these settings in particular:
                      sensitivity:
                                file: "resources/google.pmdl",
                                sensitivity: 0.7,
                      silence and verbose:
                          record: {
                      Thanks again!
                      • ChrisC
                        Chris @shep99
                        @shep99 said in Assistant Error:
                        I still have problems to use despite several unsuccessful attempts.
                        Could you detail the installation procedure you used?
                        Thank you in advance,
                          @shep99
                          Frankly, I have also pmdl problem. When I use umdl, everything is ok. But, pmdl is not worked properly, I don’t know why.
                          • E
                            E3V3A @shep99
                            @shep99 Can you please post your ALSA config?
                            cat ~/.asoundrc
                            cat /proc/asound/modules
                            cat /proc/asound/devices
                            Thanks.
                            “Everything I do (here) is for free – altruism is the way!”
                            • E
                              E3V3A
                              Just want to tell everyone that this module works very well.
                              I had some initial compile issues and trying to get the correct GA authentication, but after that it worked.
                              Now, I’m looking at Alexa, since I’d like both Alexa and GA + MM working.
                              Please see the github issue for solution in case you missed it.
                              • W
                                wonjerry
                                • W
                                  wonjerry
                                  • W
                                    wonjerry
                                    • W
                                      wonjerry @Guest
                                      @sean @shep99 @acogkenf
                                      Hello I have solved this problem this way.
                                      “npm install --runtime=electron --target=YOUR_ELECTRON_VERSION”
                                      Specify the environment and version and you can load grpc in proper way
