    MMM-Ruter (for Oslo and Akershus in Norway)
    34 Posts 13 Posters 34.6k Views 13 Watching
      Cato Module Developer @Kimzer
      @Kimzer I’m sorry, but I only make modules I need myself. If I move to Bergen, I let you know… ;-)
      I did though do a quick search and it doesn’t seem that Skyss has any public API. Found a couple of unofficial/depricated onces, but that is not something I would support anyway…
      • A
        amomat @Cato
        Hi @Cato. Did something regarding the time change in the last update? Upgraded today and time format is set to 12 instead of 24 as it was before.
        This is what is in my config file (have not changed that recently)
        language: 'en',
        timeFormat: 24,
        units: 'metric',
          Cato Module Developer @amomat
          @amomat I have done nothing, and I can’t remember noticing that since I only use public transport in the morning. I will take a look tonight to make sure.
            DeeWoo
            Hi @Cato. I’ve just installed your MMM-Ruter module, and I’m having issues with the time, it’s 12-hour…My Pi is 24 hour, my config is 24 hour…but the MMM-Ruter is 12 hour.
            language: "nb",
            timeFormat: 24,
            units: "metric",
            pi@MagicMirror_1:~/MagicMirror/config $ date
            Sun 13 Aug 15:26:42 CEST 2017
            Any idea how to fix this? :)
              Cato Module Developer @DeeWoo
              Think I found the “bug” (oversight from my end). New version is now available.
              D 1 Reply Last reply Reply Quote 2
                DeeWoo @Cato
                @Cato said in MMM-Ruter (for Oslo and Akershus in Norway):
                Just wanted to thank you for the lightning fast response!
                Now it shows 24h time. Cheers :)
                • K
                  kj3rra
                  Hei Cato!
                  Great work with the this module. I have two problems:
                  1. I cant get several stops on Frognerseterbanen (linje 1) to work (Vinderen (3012315), Gaustad (3012320) etc). It stops at ‘Loading’. Im trying in particular to get Vinderen T-bane. I have no other problems getting times from other stops, such as buses etc. Please see picture.
                  2. How do I change the dimmed light on the time-text to be bright. Ive been through alle the files, but I cant find where you can change this. Im really quite new to this, but Ive managed to change text size and ‘dimmness’ on all other modules.
                  Would be glad if you could help with these two! Thanks!
                    jonaslaeret @kj3rra
                    @kj3rra Did you manage to get those stops to work? I’m having the same problem. Some stops are working, but Vogts gate and Torshovparken recently (a couple of months ago) stopped working. Before that they were fine. I checked that the stop ID didn’t change.
                      Jessendelft
                      So, I tried installing this module yesterday evening, upon finding that I got the same ‘Loading…’ message as described by @kj3rra and @jonaslaeret . Today I spend several hours trying to figure out the problem. I ended up running the mirror in server mode, and found to my surprise that on my PC the Ruter information was showing without a problem.
                      This told me that the problem was either with Chromium or with Electron. Running
                      sudo apt-get update chromium-browser
                      didn’t seem to do the trick.
                      I dug into the Electron documentation and found that adding the following to the config.js file makes the Ruter information show in Electron:
                      electronOptions: {
                      		webPreferences: {
                      			webSecurity: false
                      Now, I get data from both Møllefaret and Røa T-bane :D
                        simonhh
                        I intalled this module the other day, but it isn’t removing trains that has left the station.
                        After an hour my whole list is full of
                        13 Oslo S -61 minutter
                        13 Oslo S -31 minutter
                        13 Oslo S -1 minutter
                        13 Oslo S 16:21
                        Has anyone got a solution to this issue?
                          simonhh
                          Forget about this. It looks like it’s one of the other modules that prevents MMM-Ruter to update.
                          • L
                            looolz
                            @Cato is not feeling good these days and is in recovery. (Please get well!)
                            In the mean time, note that the module MMM-Entur does a good job of competing with MMM-Ruter.
                            https://github.com/Arve/MMM-Entur-tavle
                            • O
                              open_book @simonhh
                              @simonhh can you post the Ruter section of your config file?
                              Here’s mine which is working fine for comparisson:
                                                      module: 'MMM-Ruter',
                                                      header: 'Ruter',
                                                      position: 'bottom_left',
                                                              showPlatform: false,
                                                              maxItems: 10,
                                                              stops: [
        stopId: "3010430",
        platforms: [ ],
        timeToThere: 1
                              sudo insert motivational.quote
                                Jessendelft
                                My ruter module recently stopped working.
                                When I try the url manually, I don’t get any response:
                                https://reisapi.ruter.no/StopVisit/GetDepartures/3012594
                                I found this: https://ruter.no/labs/, which tells me that most likely the API has been shut down, as it has been moved to EnTur.
                                Is anybody else experiencing this issue? (should be, if they shut down the API…).
                                Edit: I switched to MMM-Entur, as mentioned by @looolz . It does a very good job in replacing MMM-Ruter. And a more personal note, as always, RTFM (or in this case, the other comments…).
