    Electron CPU usage
    247 Posts 46 Posters 644.3k Views 42 Watching
    • MichMichM Offline
      MichMich @cdelaorden
      @cdelaorden I think you’ve found the issue! Awesome work!
      For others please note that when you start raspi-config and go to “Advanced Options” > “GL Driver”, the top one will always be selected, no matter which one is active. After selecting one of the two top drivers (GL), it might solve the hi CPU load issue …
      It solved it on a clean installed Pi 3 for me.
      • MichMichM Offline
        MichMich
        I added some info about the Open GL driver to the Wiki:
        https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#enable-the-open-gl-driver-to-decrease-electrons-cpu-usage
        H 1 Reply Last reply Reply Quote 3
        • H Offline
          Hein-Jan @MichMich
          @michmich
          I seem to be running into some kind if trouble. My SD card failed, so I had to do a clean install. I decided to immediately go for the full KMS driver.
          “$ tail /boot/config.txt | grep dtoverlay” results in “dtoverlay=vc4-kms-v3d”.
          The CPU usage is alright, but “/home/pi/.pm2/logs/mm-error-o.log” states:
          libGL error: MESA-LOADER: failed to retrieve device information
          I am having trouble with the monitor. I am using MMM-Remote-Control.
          “MONITOROFF” results in “/home/pi/.pm2/logs/mm-error-o.log”:
          Powering off HDMI
          “MONITORON” results in “/home/pi/.pm2/logs/mm-error-o.log”:
          Powering on HDMI with preferred settings
          [E] Failed to power on HDMI with preferred settings
          { Error: Command failed: tvservice --preferred && sudo chvt 6 && sudo chvt 7
              at ChildProcess.exithandler (child_process.js:217:12)
              at emitTwo (events.js:106:13)
              at ChildProcess.emit (events.js:194:7)
              at maybeClose (internal/child_process.js:899:16)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
            killed: true,
            code: null,
            signal: 'SIGTERM',
            cmd: 'tvservice --preferred && sudo chvt 6 && sudo chvt 7' }
          Powering off HDMI
          I may be wrong but I feel this is related to the Full KMS driver.
          Can anyone confirm? Does anyone have a solution?
          I am way out of my depth here…
            Dom1n1c
            @Hein-Jan I got the same issue.
            A few minutes, the monitor could be controlled, but then “tvservice -p” fails to power on the monitor.
              cdelaorden @Hein-Jan
              @hein-jan @Dom1n1c
              Please use the fake kms driver instead “dtoverlay=vc4-fkms-v3d”
              it its known that the full kms driver isnt compatible with tvservice plus other restrictions
              EDIT:
              Also with the fake KMS you can rotate the display from /boot/config.txt so I suggest @michmich using it as the preferred method in the wiki
                schmo90
                @cdelaorden said in Electron CPU usage:
                hy now i use the fake kms driver, everything is working fine and realy fast.
                but i have the problem that the mirror will go to a black screen after some hours.
                only a pm2 restart mm helps in this case -.-
                  cdelaorden @schmo90
                  @schmo90 mmm havent had that problem, everything its working fine
                  Have you deactivated the screensaver as its shown in the wiki?
                  Also, are you using a module like MMM-Remote-Control to turn off the screen?
                  If you see a black screen and the mouse but nothing else you are probably missing “sudo chvt 6 && sudo chvt 7” in your statement after turning hdmi back on. You can test it in ssh after forcing the issue.
                  Also if you are concatenating commands like Hein-Jan did with “tvservice --preferred && sudo chvt 6 && sudo chvt 7” have in mind that commands after && are only executed if no errors are found. So maybe “tvservice -p” its working correctly but its giving some feedback and things after && aren’t executed.
                  You could force it by using ; as a separator instead of && so it doesn’t look for an answear
                    schmo90
                    hy i didnot turn off the hdmi,
                    i will turn off the lcd with the gpio’s
                    screen is turning on normal but electron browser is showing a black screen (mous appears at moving)
                      binderth
                      adding another flavour:
                      As my Foscam FI9900P got an ONVIF-Update lately and is now capable of RTSP-streaming I installed MMM-RTSPStream.
                      • activated fake (or full) OpenGL Desktop driver:
                        omxplayer crashes
                      • activated non-GL desktop driver:
                        omxplayer runs
                      So, as I see it, the omxplayer problem doesn’t concern MagicMirror - is there another way to reduce Electron CPU usage - except using an Open-GL dekstop driver?
                      PS: activating fake KMS reduced CPU usage as recommended in this thread - but I’d like to have the video-stream of my cam on the MM (unfortunately it doesn’t provide MJPEG)
                        cdelaorden @binderth
                        hi @binderth
                        the fake-kms was created for keeping omxplayer compatibility but you need to add the “–no-osd” flag to the omxplayer command line
                        you might want to try it
                        dont bet on it, but changing line 101 of node_helper.js to
                        var args = ["--no-osd", "--live", "--video_queue", "4", "--fps", "30",
                        might do the trick
                        • V Offline
                          vinp Module Developer
                          MM 2.4.1 - if anyone is trying to look for it while searching for forums. Apologies if it has already been stated
                          So i’ve done it both ways:
                          I noticed that my CPU temp is well into the 60-70 degree Celsius with CPU loads mostly in the 1.x, 2.x, and sometimes 3.x ranges
                          When i try the other way :
                          CPU is much lower in temp under 50 degrees Celsius and CPU load rarely goes above 1.x
                          and i am able to use the tvservice -o and tvservice -p to schedule my monitor to go on and off at certain times
                          Hopefully this helps anyone searching for this issue on new installs like myself
                          1 Reply Last reply Reply Quote 4
                            jaffons
                            So i ran into this issue as well. I started MM stuff 2-3 weeks ago.
                            When everything was working my logs show:
                            • I had the previous mm version ( probably 2.3.1)
                            • Enable the Open GL driver, fake KMS (via raspi-config)
                            • Disabling the screensaver https://www.raspberrypi.org/forums/viewtopic.php?t=57552
                            • Autohiding the Mouse Pointer
                            • rotate screen 270deg(CW), display_rotate=3 at /boot/config.txt
                            • I also had the dtoverlay=vc4-fkms-v3d line there
                            • I was getting this error though (thrunpm start ):
                            Anyway I messed something on my modules and had to reinstall the Raspbian. Same as before, Stretch 7/-18
                            • Rotate screen at /boot/config.txt
                            • installed the MM 2.4.1 and tried it straight away default config and modules. It was working alright
                            • I think I added the dtoverlay=vc4-fkms-v3d line…
                              • and boom animations started lagging (+high CPU)
                              • also npm start dev didnt work. It launched but no mirror was shown and if i had mm running it would stop refreshing.
                            Any way I figured out that taking that commenting out that # dtoverlay=vc4-fkms-v3d everything works flawlessy. I dont get the “libGL”-error
                            and I also updated npm 5.6.0 → 6.2.0 sudo npm i -g npm and npm start dev started working (dev or no dev).
                            My Rpi temperature is under 50C when mm is running (no heatsink).
                            Hope this helps out someone!
                            A 1 Reply Last reply Reply Quote 4
                              adamlove86 @jaffons
                              @vinp and @jaffons WOW! Thank you for your comments… Made a huge difference.
                              After some months I needed to reinstall from scratch (now also hosting octoprint and a remote desktop simultaneously). I thought MM animations were just generally slow, but this made a huge difference compared to the more orthodox setup.
                              I don’t see why this configuration shouldn’t be preferred over the normal Pi configuration, and the OpenGL driver was also much trickier to get working.
                              • K Offline
                                Knapoc
                                Is it just me, that after the most recent rpi firmware update display_rotate/display_hdmi_rotate is not working with the fkms driver?
                                I found the following in the official documentation:
                                If using the VC4 FKMS V3D driver (this is the default on the Raspberry Pi 4), then 90 and 270 degree rotations are not supported. The Screen Configuration utility provides display rotations for this driver.
                                Unfortunately I have no clue how to run the screen configuration utility. There’s always a black screen even if I run pm2 stop mm.
                                • 10
                                • 11
                                • 12
                                • 13
                                • 13 / 13
