    Google Assistant
    3 Posts 2 Posters 2.1k Views 2 Watching
      paul.aviles
      Hello, I have tried installing MMM-Assistant and it is failing the npm install part with an error on missing files:
      grpc@1.8.0 install /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc
      > node-pre-gyp install --fallback-to-build --library=static_library
      node-pre-gyp ERR! Tried to download(403): https://storage.googleapis.com/grpc-precompiled-binaries/node/grpc/v1.8.0/node-v64-linux-arm-glibc.tar.gz
      From there on it just a bunch or errors. The following is at the end of the log more or less.
      2085 verbose stack Error: grpc@1.8.0 install: `node-pre-gyp install --fallback-to-build --library=static_library`
      2085 verbose stack Exit status 1
      2085 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:16)
      2085 verbose stack     at EventEmitter.emit (events.js:182:13)
      2085 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      2085 verbose stack     at ChildProcess.emit (events.js:182:13)
      2085 verbose stack     at maybeClose (internal/child_process.js:961:16)
      2085 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:5)
      2086 verbose pkgid grpc@1.8.0
      2087 verbose cwd /home/pi/MagicMirror/modules/MMM-Assistant
      2088 verbose Linux 4.14.49-v7+
      2089 verbose argv "/usr/bin/node" "/usr/bin/npm" "install"
      2090 verbose node v10.4.1
      2091 verbose npm  v6.1.0
      Has anyone tried MMM-Assistant succesfully and if not, is there perhaps a better similar module that give you the ability to show and hide modules , play music, youtube etc?
      Paul
        paul.aviles
        Anyone out there using Google Assistant?
          Peter
          I have MM and Google assistant running on one rpi.
          I used the original Goole AIY kit.
          So I do not use MMM-assistant.
          I can ask questions and get answers, but it is impossible to hide or show modules.
          Peter
