    V2.4.0 Update
    Scheduled Pinned Locked Moved MagicMirror
    2 Posts 1 Posters 10.5k Views 3 Watching
    • MichMichM Offline
      MichMich
      MagicMirror² V2.4.0 was just released.
      Please read the release notes carefully since this update requires adjustments to your Raspberry Pi configuration!
      https://github.com/MichMich/MagicMirror/releases/tag/v2.4.0
      [2.4.0] - 2018-07-01
      ⚠️ Warning: This release includes an updated version of Electron. This requires a Raspberry Pi configuration change to allow the best performance and prevent the CPU from overheating. Please read the information on the MagicMirror Wiki.
      ℹ️ Note: This update uses new dependencies. Please update using the following command: git pull && npm install
      Added
      • Enabled translation of feelsLike for module currentweather
      • Added support for on-going calendar events
      • Added scroll up in fullscreen newsfeed article view
      • Changed fullscreen newsfeed width from 100% to 100vw (better results)
      • Added option to calendar module that colors only the symbol instead of the whole line
      • Added option for new display format in the calendar module with date headers with times/events below.
      • Ability to fetch compliments from a remote server
      • Add regex filtering to calendar module
      • Customize classes for table
      • Added option to newsfeed module to only log error parsing a news article if enabled
      • Add update translations for Português Brasileiro
      Changed
      • Upgrade to Electron 2.0.0.
      • Remove yarn-or-npm which breaks production builds.
      • Invoke module suspend even if no dom content. #1308
      Fixed
      • Fixed issue where wind chill could not be displayed in Fahrenheit. #1247
      • Fixed issues where a module crashes when it tries to dismiss a non existing alert. #1240
      • In default module currentWeather/currentWeather.js line 296, 300, self.config.animationSpeed can not be found because the notificationReceived function does not have “self” variable.
      • Fixed browser-side code to work on the Midori browser.
      • Fixed issue where heat index was reporting incorrect values in Celsius and Fahrenheit. #1263
      • Fixed weatherforecast to use dt_txt field instead of dt to handle timezones better
      • Newsfeed now remembers to show the description when "ARTICLE_LESS_DETAILS" is called if the user wants to always show the description. #1282
      • clientonly/*.js is now linted, and one linting error is fixed
      • Fix issue #1196 by changing underscore to hyphen in locale id, in align with momentjs.
      • Fixed issue where heat index and wind chill were reporting incorrect values in Kelvin. #1263
      Updated
      • Updated Italian translation
      • Updated German translation
      • Updated Dutch translation
      1 Reply Last reply Reply Quote 4
      • MichMichM Offline
        MichMich
        https://github.com/MichMich/MagicMirror/releases/tag/v2.4.1
        [2.4.1] - 2018-07-04
        Fixed
        • Fix weather parsing issue #1332.2.4.1
        1 Reply Last reply Reply Quote -1
