    27" Mirror with selfmade frame
    27 Posts 14 Posters 28.2k Views 16 Watching
      jersam
      which router bits did you use on the 2x4s?
      kruemelK 1 Reply Last reply Reply Quote 0
      • kruemelK Offline
        kruemel
        Ah sorry i did not get any notifications about new posts :-)
        I will answer all the questions this week
        • kruemelK Offline
          kruemel @jersam
          @jersam said in 27" Mirror with selfmade frame:
          Sorry i dont get your point ^^
          Do you mean this, maybe?
          • kruemelK Offline
            kruemel @onkelbobby
            @onkelbobby Hi, thank you :-)
            I just mounted the sensor on a piece of wood behind the glass (to reduce the range a little bit without a tresistor) instead of directly behind the glass.
            If you need i can make a picture but i think the illustration should do the job ;-)
            O zdenekZ 2 Replies Last reply Reply Quote 0
              jersam @kruemel
              @kruemel which bits did you use to cut the wood.
              Looks like you started with a 2x4, cut into a L shape with a ledge, put a smaller strip of wood to hold the mirror and display in.
              its nicely done so i was curious.
              I just picked up a table saw so i can do a datto cut in wood.
              • O Offline
                onkelbobby @kruemel
                @kruemel
                thanks… no need to take pictures…
                I’m just wondering why my sensor is no working trough the glass wood combination (Mirropane Chrome Spy 4mm + plywood 5mm)
                Anyway, I found another way to mount it almost invisible.
                • T Offline
                  teegray1124
                  does your myweather module still work?
                  • kruemelK Offline
                    kruemel @teegray1124
                    @teegray1124 Yes but i think you mean the “rainfall” amount, when you ask like this ^^
                    I noticed that it states “nullmm” instead of a number, since a couple weeks.
                    • kruemelK Offline
                      kruemel
                      @jersam Aaaah, now i get your point :D
                      I started with 2
                      Douglas Wood 4,5 cm x 200 cm x 7 cm
                      https://www.obi.ch/terrassendielen/unterkonstruktion-douglasie-4-5-cm-x-200-cm-x-7-cm/p/3434313
                      Cut in the half and to my needed length.
                      Get rid of the wood i dont need with a wood milling, like this:
                      alt text
                      …with two different positions to get a “stairway” :-)
                        max86
                        Hello @kruemel , is that possible to have the outline dimensions, i’m thinking about building almost the same ? Actually, i don’t know what should be the size of overflow for the mirror, to keep it strong.
                        Really nice setup :)
                        • kruemelK Offline
                          kruemel @max86
                          @max86 Hi Max, sure :-)
                          Outline is 153cm x 40.3cm for the frame
                          and visable mirror is 34.3cm
                          So the overflow in my case should be about ~1.5 to 1.7cm
                          • H Offline
                            hayman
                            very nice, specialy the price of the mirror hope in NL will have like these …:(
                            • zdenekZ Online
                              zdenek @kruemel
                              @kruemel is it possible to make pic for me? Adn, I’ve never been playing with any HW module - how to connect the module? There are some “cables” or I’ve to “create” them?
                              Thanks, Zdeněk
                              P.S.: nice job…
