    27" Mirror with selfmade frame
    27 Posts 14 Posters 28.8k Views 16 Watching
    • A
      Arjen
      Very nice mirror. Looks great.
      I am also curious about the prices of the mirror and shipping costs.
        MadScientist
        FYI: Glastroesch.de doesn’t ship their mirrors. They also do not directly sell to private people but give you a contact that does. Apparently they are around Ulm (for those that live close enough).
        • O
          onkelbobby
          Hi kruemel,
          good job… looks very professional.
          Since I’m using the same RCWL0516 motion sensor I have also some questions:
          • How did you mount it that it is working through the glass?
            I tried id with my Mirropane Chrome Spy 4mm but there was no detection trough the glass at all.
          • Maybe you can share some pictures especially of the motion sensor?
          Thanks, onkelbobby
          kruemelK 1 Reply Last reply
            jersam
            which router bits did you use on the 2x4s?
            • kruemelK
              kruemel
              Ah sorry i did not get any notifications about new posts :-)
              I will answer all the questions this week
              • kruemelK
                kruemel @jersam
                @jersam said in 27" Mirror with selfmade frame:
                Sorry i dont get your point ^^
                Do you mean this, maybe?
                J 1 Reply Last reply
                • kruemelK
                  kruemel @onkelbobby
                  @onkelbobby Hi, thank you :-)
                  I just mounted the sensor on a piece of wood behind the glass (to reduce the range a little bit without a tresistor) instead of directly behind the glass.
                  If you need i can make a picture but i think the illustration should do the job ;-)
                  O zdenekZ 2 Replies Last reply
                    jersam @kruemel
                    @kruemel which bits did you use to cut the wood.
                    Looks like you started with a 2x4, cut into a L shape with a ledge, put a smaller strip of wood to hold the mirror and display in.
                    its nicely done so i was curious.
                    I just picked up a table saw so i can do a datto cut in wood.
                    • O
                      onkelbobby @kruemel
                      @kruemel
                      thanks… no need to take pictures…
                      I’m just wondering why my sensor is no working trough the glass wood combination (Mirropane Chrome Spy 4mm + plywood 5mm)
                      Anyway, I found another way to mount it almost invisible.
                      • T
                        teegray1124
                        does your myweather module still work?
                        • kruemelK
                          kruemel @teegray1124
                          @teegray1124 Yes but i think you mean the “rainfall” amount, when you ask like this ^^
                          I noticed that it states “nullmm” instead of a number, since a couple weeks.
                          • kruemelK
                            kruemel
                            @jersam Aaaah, now i get your point :D
                            I started with 2
                            Douglas Wood 4,5 cm x 200 cm x 7 cm
                            https://www.obi.ch/terrassendielen/unterkonstruktion-douglasie-4-5-cm-x-200-cm-x-7-cm/p/3434313
                            Cut in the half and to my needed length.
                            Get rid of the wood i dont need with a wood milling, like this:
                            alt text
                            …with two different positions to get a “stairway” :-)
                              max86
                              Hello @kruemel , is that possible to have the outline dimensions, i’m thinking about building almost the same ? Actually, i don’t know what should be the size of overflow for the mirror, to keep it strong.
                              Really nice setup :)
                              • kruemelK
                                kruemel @max86
                                @max86 Hi Max, sure :-)
                                Outline is 153cm x 40.3cm for the frame
                                and visable mirror is 34.3cm
                                So the overflow in my case should be about ~1.5 to 1.7cm
                                • H
                                  hayman
                                  very nice, specialy the price of the mirror hope in NL will have like these …:(
                                  • zdenekZ
                                    zdenek @kruemel
                                    @kruemel is it possible to make pic for me? Adn, I’ve never been playing with any HW module - how to connect the module? There are some “cables” or I’ve to “create” them?
                                    Thanks, Zdeněk
                                    P.S.: nice job…
