    27" Mirror with selfmade frame
    27 Posts 14 Posters 26.7k Views 16 Watching
    • kruemelK Offline
      kruemel
      Its 12% and 4mm thick
      They have 1, 12, 20, 30 and 40%
      https://www.glastroesch.ch/glas/82-spionspiegel.html
        MadScientist
        Thank you very much. I saw they are also in Germany. I will call them up tomorrow and ask for prices for the mirror and for shipping. If it’s really that cheap I will order one with 12% and with 20% transmission and see which one fits best.
          maxbachmann
          How far does your radar detector detect through the glass?
          kruemelK 1 Reply Last reply Reply Quote 0
          • bheplerB Offline
            bhepler Module Developer
            Excellent work. That looks great!
            • kruemelK Offline
              kruemel @maxbachmann
              @maxbachmann
              Its in the middle behind the thick wood and it detects at least 4m. (would be more if there would be no wood, just the glass :-)
              Due to the position across from my wardrobe thats fine but if the range is too faar for detection it would be possible to reduce it with a resistor.
              https://github.com/jdesbonnet/RCWL-0516
                maxbachmann
                @kruemel ty for the info
                  soul
                  great job, looks great full height!
                    PhilReis
                    Nice work, i see you used a radar sensor.
                    How and where exactly did you attach this?
                      Arjen
                      Very nice mirror. Looks great.
                      I am also curious about the prices of the mirror and shipping costs.
                        MadScientist
                        FYI: Glastroesch.de doesn’t ship their mirrors. They also do not directly sell to private people but give you a contact that does. Apparently they are around Ulm (for those that live close enough).
                        • O Offline
                          onkelbobby
                          Hi kruemel,
                          good job… looks very professional.
                          Since I’m using the same RCWL0516 motion sensor I have also some questions:
                          • How did you mount it that it is working through the glass?
                            I tried id with my Mirropane Chrome Spy 4mm but there was no detection trough the glass at all.
                          • Maybe you can share some pictures especially of the motion sensor?
                          Thanks, onkelbobby
                            jersam
                            which router bits did you use on the 2x4s?
                            • kruemelK Offline
                              kruemel
                              Ah sorry i did not get any notifications about new posts :-)
                              I will answer all the questions this week
                              • kruemelK Offline
                                kruemel @jersam
                                @jersam said in 27" Mirror with selfmade frame:
                                Sorry i dont get your point ^^
                                Do you mean this, maybe?
                                • kruemelK Offline
                                  kruemel @onkelbobby
                                  @onkelbobby Hi, thank you :-)
                                  I just mounted the sensor on a piece of wood behind the glass (to reduce the range a little bit without a tresistor) instead of directly behind the glass.
                                  If you need i can make a picture but i think the illustration should do the job ;-)
                                  O zdenekZ 2 Replies Last reply Reply Quote 0
                                    jersam @kruemel
                                    @kruemel which bits did you use to cut the wood.
                                    Looks like you started with a 2x4, cut into a L shape with a ledge, put a smaller strip of wood to hold the mirror and display in.
                                    its nicely done so i was curious.
                                    I just picked up a table saw so i can do a datto cut in wood.
                                    • O Offline
                                      onkelbobby @kruemel
                                      @kruemel
                                      thanks… no need to take pictures…
                                      I’m just wondering why my sensor is no working trough the glass wood combination (Mirropane Chrome Spy 4mm + plywood 5mm)
                                      Anyway, I found another way to mount it almost invisible.
                                      • T Offline
                                        teegray1124
                                        does your myweather module still work?
                                        • kruemelK Offline
                                          kruemel @teegray1124
                                          @teegray1124 Yes but i think you mean the “rainfall” amount, when you ask like this ^^
                                          I noticed that it states “nullmm” instead of a number, since a couple weeks.
                                          • kruemelK Offline
                                            kruemel
                                            @jersam Aaaah, now i get your point :D
                                            I started with 2
                                            Douglas Wood 4,5 cm x 200 cm x 7 cm
                                            https://www.obi.ch/terrassendielen/unterkonstruktion-douglasie-4-5-cm-x-200-cm-x-7-cm/p/3434313
                                            Cut in the half and to my needed length.
                                            Get rid of the wood i dont need with a wood milling, like this:
                                            alt text
                                            …with two different positions to get a “stairway” :-)
