    27" Mirror with selfmade frame
    27 Posts 14 Posters 28.6k Views 16 Watching
    • lavolp3L
      lavolp3 Module Developer
      Would interest me as well.
      Also, your mirror seems very cheap! (and that in SWITZERLAND :-))
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • kruemelK
        kruemel
        Its 12% and 4mm thick
        They have 1, 12, 20, 30 and 40%
        https://www.glastroesch.ch/glas/82-spionspiegel.html
          MadScientist
          Thank you very much. I saw they are also in Germany. I will call them up tomorrow and ask for prices for the mirror and for shipping. If it’s really that cheap I will order one with 12% and with 20% transmission and see which one fits best.
            maxbachmann
            How far does your radar detector detect through the glass?
            kruemelK 1 Reply Last reply Reply Quote 0
              bhepler Module Developer
              Excellent work. That looks great!
              • kruemelK
                kruemel @maxbachmann
                @maxbachmann
                Its in the middle behind the thick wood and it detects at least 4m. (would be more if there would be no wood, just the glass :-)
                Due to the position across from my wardrobe thats fine but if the range is too faar for detection it would be possible to reduce it with a resistor.
                https://github.com/jdesbonnet/RCWL-0516
                  maxbachmann
                  @kruemel ty for the info
                    soul
                    great job, looks great full height!
                      PhilReis
                      Nice work, i see you used a radar sensor.
                      How and where exactly did you attach this?
                      • A
                        Arjen
                        Very nice mirror. Looks great.
                        I am also curious about the prices of the mirror and shipping costs.
                          MadScientist
                          FYI: Glastroesch.de doesn’t ship their mirrors. They also do not directly sell to private people but give you a contact that does. Apparently they are around Ulm (for those that live close enough).
                          • O
                            onkelbobby
                            Hi kruemel,
                            good job… looks very professional.
                            Since I’m using the same RCWL0516 motion sensor I have also some questions:
                            • How did you mount it that it is working through the glass?
                              I tried id with my Mirropane Chrome Spy 4mm but there was no detection trough the glass at all.
                            • Maybe you can share some pictures especially of the motion sensor?
                            Thanks, onkelbobby
                              jersam
                              which router bits did you use on the 2x4s?
                              • kruemelK
                                kruemel
                                Ah sorry i did not get any notifications about new posts :-)
                                I will answer all the questions this week
                                • kruemelK
                                  kruemel @jersam
                                  @jersam said in 27" Mirror with selfmade frame:
                                  Sorry i dont get your point ^^
                                  Do you mean this, maybe?
                                  • kruemelK
                                    kruemel @onkelbobby
                                    @onkelbobby Hi, thank you :-)
                                    I just mounted the sensor on a piece of wood behind the glass (to reduce the range a little bit without a tresistor) instead of directly behind the glass.
                                    If you need i can make a picture but i think the illustration should do the job ;-)
                                    O zdenekZ 2 Replies Last reply Reply Quote 0
                                      jersam @kruemel
                                      @kruemel which bits did you use to cut the wood.
                                      Looks like you started with a 2x4, cut into a L shape with a ledge, put a smaller strip of wood to hold the mirror and display in.
                                      its nicely done so i was curious.
                                      I just picked up a table saw so i can do a datto cut in wood.
                                      • O
                                        onkelbobby @kruemel
                                        @kruemel
                                        thanks… no need to take pictures…
                                        I’m just wondering why my sensor is no working trough the glass wood combination (Mirropane Chrome Spy 4mm + plywood 5mm)
                                        Anyway, I found another way to mount it almost invisible.
                                        • T
                                          teegray1124
                                          does your myweather module still work?
                                          • kruemelK
                                            kruemel @teegray1124
                                            @teegray1124 Yes but i think you mean the “rainfall” amount, when you ask like this ^^
                                            I noticed that it states “nullmm” instead of a number, since a couple weeks.
