    27" Mirror with selfmade frame
    27 Posts 14 Posters 28.2k Views 16 Watching
      bhepler Module Developer
      Excellent work. That looks great!
      • kruemelK Offline
        kruemel @maxbachmann
        @maxbachmann
        Its in the middle behind the thick wood and it detects at least 4m. (would be more if there would be no wood, just the glass :-)
        Due to the position across from my wardrobe thats fine but if the range is too faar for detection it would be possible to reduce it with a resistor.
        https://github.com/jdesbonnet/RCWL-0516
          maxbachmann
          @kruemel ty for the info
            soul
            great job, looks great full height!
              PhilReis
              Nice work, i see you used a radar sensor.
              How and where exactly did you attach this?
                Arjen
                Very nice mirror. Looks great.
                I am also curious about the prices of the mirror and shipping costs.
                  MadScientist
                  FYI: Glastroesch.de doesn’t ship their mirrors. They also do not directly sell to private people but give you a contact that does. Apparently they are around Ulm (for those that live close enough).
                  • O Offline
                    onkelbobby
                    Hi kruemel,
                    good job… looks very professional.
                    Since I’m using the same RCWL0516 motion sensor I have also some questions:
                    • How did you mount it that it is working through the glass?
                      I tried id with my Mirropane Chrome Spy 4mm but there was no detection trough the glass at all.
                    • Maybe you can share some pictures especially of the motion sensor?
                    Thanks, onkelbobby
                    kruemelK 1 Reply Last reply Reply Quote 0
                      jersam
                      which router bits did you use on the 2x4s?
                      • kruemelK Offline
                        kruemel
                        Ah sorry i did not get any notifications about new posts :-)
                        I will answer all the questions this week
                        • kruemelK Offline
                          kruemel @jersam
                          @jersam said in 27" Mirror with selfmade frame:
                          Sorry i dont get your point ^^
                          Do you mean this, maybe?
                          • kruemelK Offline
                            kruemel @onkelbobby
                            @onkelbobby Hi, thank you :-)
                            I just mounted the sensor on a piece of wood behind the glass (to reduce the range a little bit without a tresistor) instead of directly behind the glass.
                            If you need i can make a picture but i think the illustration should do the job ;-)
                            O zdenekZ 2 Replies Last reply Reply Quote 0
                              jersam @kruemel
                              @kruemel which bits did you use to cut the wood.
                              Looks like you started with a 2x4, cut into a L shape with a ledge, put a smaller strip of wood to hold the mirror and display in.
                              its nicely done so i was curious.
                              I just picked up a table saw so i can do a datto cut in wood.
                              • O Offline
                                onkelbobby @kruemel
                                @kruemel
                                thanks… no need to take pictures…
                                I’m just wondering why my sensor is no working trough the glass wood combination (Mirropane Chrome Spy 4mm + plywood 5mm)
                                Anyway, I found another way to mount it almost invisible.
                                • T Offline
                                  teegray1124
                                  does your myweather module still work?
                                  • kruemelK Offline
                                    kruemel @teegray1124
                                    @teegray1124 Yes but i think you mean the “rainfall” amount, when you ask like this ^^
                                    I noticed that it states “nullmm” instead of a number, since a couple weeks.
                                    • kruemelK Offline
                                      kruemel
                                      @jersam Aaaah, now i get your point :D
                                      I started with 2
                                      Douglas Wood 4,5 cm x 200 cm x 7 cm
                                      https://www.obi.ch/terrassendielen/unterkonstruktion-douglasie-4-5-cm-x-200-cm-x-7-cm/p/3434313
                                      Cut in the half and to my needed length.
                                      Get rid of the wood i dont need with a wood milling, like this:
                                      alt text
                                      …with two different positions to get a “stairway” :-)
                                        max86
                                        Hello @kruemel , is that possible to have the outline dimensions, i’m thinking about building almost the same ? Actually, i don’t know what should be the size of overflow for the mirror, to keep it strong.
                                        Really nice setup :)
                                        • kruemelK Offline
                                          kruemel @max86
                                          @max86 Hi Max, sure :-)
                                          Outline is 153cm x 40.3cm for the frame
                                          and visable mirror is 34.3cm
                                          So the overflow in my case should be about ~1.5 to 1.7cm
                                          • H Offline
                                            hayman
                                            very nice, specialy the price of the mirror hope in NL will have like these …:(
