    27" Mirror with selfmade frame
    27 Posts 14 Posters 27.5k Views 16 Watching
      MadScientist
      Thank you very much. I saw they are also in Germany. I will call them up tomorrow and ask for prices for the mirror and for shipping. If it’s really that cheap I will order one with 12% and with 20% transmission and see which one fits best.
        maxbachmann
        How far does your radar detector detect through the glass?
        kruemelK 1 Reply Last reply Reply Quote 0
          bhepler Module Developer
          Excellent work. That looks great!
          • kruemelK Offline
            kruemel @maxbachmann
            @maxbachmann
            Its in the middle behind the thick wood and it detects at least 4m. (would be more if there would be no wood, just the glass :-)
            Due to the position across from my wardrobe thats fine but if the range is too faar for detection it would be possible to reduce it with a resistor.
            https://github.com/jdesbonnet/RCWL-0516
              maxbachmann
              @kruemel ty for the info
                soul
                great job, looks great full height!
                  PhilReis
                  Nice work, i see you used a radar sensor.
                  How and where exactly did you attach this?
                    Arjen
                    Very nice mirror. Looks great.
                    I am also curious about the prices of the mirror and shipping costs.
                      MadScientist
                      FYI: Glastroesch.de doesn’t ship their mirrors. They also do not directly sell to private people but give you a contact that does. Apparently they are around Ulm (for those that live close enough).
                      • O Offline
                        onkelbobby
                        Hi kruemel,
                        good job… looks very professional.
                        Since I’m using the same RCWL0516 motion sensor I have also some questions:
                        • How did you mount it that it is working through the glass?
                          I tried id with my Mirropane Chrome Spy 4mm but there was no detection trough the glass at all.
                        • Maybe you can share some pictures especially of the motion sensor?
                        Thanks, onkelbobby
                          jersam
                          which router bits did you use on the 2x4s?
                          • kruemelK Offline
                            kruemel
                            Ah sorry i did not get any notifications about new posts :-)
                            I will answer all the questions this week
                            • kruemelK Offline
                              kruemel @jersam
                              @jersam said in 27" Mirror with selfmade frame:
                              Sorry i dont get your point ^^
                              Do you mean this, maybe?
                              • kruemelK Offline
                                kruemel @onkelbobby
                                @onkelbobby Hi, thank you :-)
                                I just mounted the sensor on a piece of wood behind the glass (to reduce the range a little bit without a tresistor) instead of directly behind the glass.
                                If you need i can make a picture but i think the illustration should do the job ;-)
                                O zdenekZ 2 Replies Last reply Reply Quote 0
                                  jersam @kruemel
                                  @kruemel which bits did you use to cut the wood.
                                  Looks like you started with a 2x4, cut into a L shape with a ledge, put a smaller strip of wood to hold the mirror and display in.
                                  its nicely done so i was curious.
                                  I just picked up a table saw so i can do a datto cut in wood.
                                  • O Offline
                                    onkelbobby @kruemel
                                    @kruemel
                                    thanks… no need to take pictures…
                                    I’m just wondering why my sensor is no working trough the glass wood combination (Mirropane Chrome Spy 4mm + plywood 5mm)
                                    Anyway, I found another way to mount it almost invisible.
                                    • T Offline
                                      teegray1124
                                      does your myweather module still work?
                                      • kruemelK Offline
                                        kruemel @teegray1124
                                        @teegray1124 Yes but i think you mean the “rainfall” amount, when you ask like this ^^
                                        I noticed that it states “nullmm” instead of a number, since a couple weeks.
                                        • kruemelK Offline
                                          kruemel
                                          @jersam Aaaah, now i get your point :D
                                          I started with 2
                                          Douglas Wood 4,5 cm x 200 cm x 7 cm
                                          https://www.obi.ch/terrassendielen/unterkonstruktion-douglasie-4-5-cm-x-200-cm-x-7-cm/p/3434313
                                          Cut in the half and to my needed length.
                                          Get rid of the wood i dont need with a wood milling, like this:
                                          alt text
                                          …with two different positions to get a “stairway” :-)
                                            max86
                                            Hello @kruemel , is that possible to have the outline dimensions, i’m thinking about building almost the same ? Actually, i don’t know what should be the size of overflow for the mirror, to keep it strong.
                                            Really nice setup :)
