    Double power supply, different output, for RPI and screen controller
    18 Posts 8 Posters 15.5k Views 8 Watching
      ctessier
      Hey
      Thank you so much for your replies! I didn’t think of converters or even that the controller board might do the stuff! I am new to electronics and I guess I am too afraid to blow up stuff, so if I can avoid building things myself, that’s great. Although, where is the fun in that ;)
      I am still waiting for my controller to be delivered, here it is: https://www.ebay.fr/itm/NT68676-HDMI-DVI-VGA-LCD-Screen-Controller-Board-Kit-for-15-4-B154EW04-V-B-VB/122620926961?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
      And the specs sheet I found: http://www.vslcd.com/Specification/M.NT68676.2A.pdf
      Seems like there is a power supply too but it points to nothing on the board. Any thoughts?
      I am though concerned about the intensity for the Raspberry. How can I make sure I much amps I need to power it, from 2.5 to let’s say 4 amps. For now I am not planning on plugging anything to it yet, except maybe for a PIR or some other motion sensor and audio later. Cherry on the cake would me a microphone for voice command. But see… do this mean I may need to rethink the power supply as I upgrade my mirror?
      Thank you for your help!
      Clément
        MadScientist
        The Pi itself doesn’t drain much power. It is suggested to use a 2.5A power supply to utilize the 4 USB ports. A PIR sensor or a microphone consume close to no power. So I am pretty sure 1A should be enough already. I know in my case the Pi drains 560mA at max, running MM (using WIFI, USB keyboard dongle, temperature sensor and PIR sensor).
        I am using a 0,20€ 3A buck converter for my Pi, which is powered by the 12V power supply for my LCD. Runs flawlessly for 3 months now continuously.
        • emloweE Offline
          emlowe Module Developer
          In the spec sheet you posted, see where it says CN3 on page 4 &5. This is an optional connector that may (or may not) be on the board.
          Pins 3 & 4 are 5v and 5 & 6 are GND.
          Note, however, unless you want to do some simple PCB soldering this isn’t the way to go. What I did was attach some header pins to the board, cut one end off a USB cable and attached it to the pins, then plugged it in the normal way into the RPi.
            bhepler Module Developer
            I usually mount a power strip along the inside edge of the frame and run the Pi from there. This one pushes 2.4A on each of 4 USB ports. I use one for the Pi and one for an LED strip light around the frame. Here’s the one I normally order: http://a.co/evJGa7V
            @shbatm - I put one of those USB plugs on my motorcycle and it was insanely easy. They’re compact and push good current. That sounds like a good idea.
              ctessier
              Thank you guys!
              The 5V off the board sounds like a great idea, at least if the model I get has that (the pic on ebay seems to show it).
              But if I power the controller board with 12V 3A like recommended and pull 2 cables for a micro USB plug the 5V output (pins 3 and 5 (gnd) let’s say) for the RPI, how do I know how much amp the RPI could (or will) “suck” from there? Because obviously, the screen will drain some power, how can I know what would be left and won’t it be too much or too little?
              This is probably basic electronics, I will search on that now but if you have a simple answer for me, I’d take it!
              Thank you a lot!
              Clément
              • emloweE Offline
                I used a 12v 5a power supply with the same board - you don’t have to stick with 3a, that’s a minimum recommendation for the controller. So getting a 5a power supply should cover easily the controller and the rpi.
                -Earle
                • emloweE Offline
                  I’m terrible with the soldering iron but here is what I did
                    ctessier
                    Ok awesome thanks! Lucky for you we don’t see the solder on the picture ;) but I get what you did! Thanks a lot for the advise.
                    Will keep the post updated when I get the stuff
                    Clément
                      ctessier
                      I received the monitor controller board way early than expected and got a power supply from Amazon (12V 5A to get enough juice for the board and the RPI as advised):
                      https://www.amazon.fr/gp/product/B01LT77HW6/ref=ox_sc_act_title_1?smid=A30SNSYXWKC8W6&psc=1
                      I am very happy to announce that my old laptop’s screen works!
                      Working monitor controller board
                      And the board has indeed a 5V output which I tested and seems to work fine!
                      Next step: get some header pins and cable to power up the RPI from the controller board!
                      Thank you guys again for your advise.
                      Have a good weekend
                        bachoo786 @ctessier
                        @ctessier hey well done on setting up everything.
                        I want to know how much current are you getting from the board using the 5V pin? Are you getting 1.5Amp as stated in the data sheet or are you getting more than 1.5A because you are using the 12V 5A adapter to power the whole board?
                        Many thanks.
                          bachoo786 @emlowe
                          @emlowe using the 12V 5A how much does the rpi get then? more than the advertised 1.5A or? In the future I would consider using the usb ports of the rpi.
                          Thanks.
                          • H Offline
                            HattyCurll
                            Hi…unless the PSUs are designed to tolerate it, a voltage mismatch (even within the +/- 0.25V tolerance) could destroy one or both PSUs.
                            Just get a decent PSU with adequate output, like the “official” 2.5A, or bigger if required for power-hungry peripherals .
                            printed circuit board
