    Error starting MagicMirror after an update
    3 Posts 2 Posters 2.2k Views 1 Watching
      Major
      I ran an update on my Magic Mirror last night and now it will not launch. :/
      I get the following error:
      pi@raspi-calendar:~/MagicMirror $ npm start
      magicmirror@2.4.1 start /home/pi/MagicMirror
      sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.4.1 start: sh run-start.sh
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.4.1 start script.
      npm ERR! /home/pi/.npm/_logs/2018-07-18T01_07_05_492Z-debug.log
      And in the debug.log:
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@5.6.0
      3 info using node@v10.1.0
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.4.1~prestart: magicmirror@2.4.1
      6 info lifecycle magicmirror@2.4.1~start: magicmirror@2.4.1
      7 verbose lifecycle magicmirror@2.4.1~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.4.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.4.1~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.4.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
      11 info lifecycle magicmirror@2.4.1~start: Failed to exec start script
      12 verbose stack Error: magicmirror@2.4.1 start: sh run-start.sh
      12 verbose stack spawn ENOENT
      12 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
      12 verbose stack at ChildProcess.emit (events.js:182:13)
      12 verbose stack at maybeClose (internal/child_process.js:957:16)
      12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:246:5)
      13 verbose pkgid magicmirror@2.4.1
      14 verbose cwd /home/pi/MagicMirror
      15 verbose Linux 4.9.70-v7+
      16 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
      17 verbose node v10.1.0
      18 verbose npm v5.6.0
      19 error file sh
      20 error code ELIFECYCLE
      21 error errno ENOENT
      22 error syscall spawn
      23 error magicmirror@2.4.1 start: sh run-start.sh
      23 error spawn ENOENT
      24 error Failed at the magicmirror@2.4.1 start script.
      24 error This is probably not a problem with npm. There is likely additional logging output above.
      25 verbose exit [ 1, true ]
      Please help!
      Thank you,
      Major
      bheplerB 1 Reply Last reply
      • bheplerB
        bhepler Module Developer @Major
        @major - It looks like electron didn’t install properly.
        If you run npm install from inside the /home/pi/MagicMirror folder, it should automatically install electron. If that doesn’t work, you can install electron specifically by typing sudo npm install electron@2.0.0
          Major
          I’m sorry, I didn’t report back.
          Running npm install did the trick!
          Thank you!
