    Wrong font in newsfeed
    10 Posts 6 Posters 4.2k Views 5 Watching
    • MarosM
      Maros
      Hi all,
      i’ve added some modules to my MM and i see that there is some problem with fonts as you can see some characters have different font. (most visible in newsfeed)
      i’ve edited custom.css and added this lines :
      body {
      @font-face {
      font-family: “Verdana”;
      font-style: normal;
      font-weight: 100;
      src:
      local(“Verdana”),
      url(“/fonts/Verdana.ttf”) format(“truetype”);
      .newsfeed {
      font-family: Verdana;
      i’ve downloaded font Verdana.ttf and copied to MagicMirror/fonts folder
      but it’s not working font is still not ok
      Can you please help me how to solve this problem ?
      • MarosM
        Maros
        i’ve tried also woff font Verdana.woff as mentioned here :
        https://forum.magicmirror.builders/topic/4824/i-need-help-to-change-the-fonts/3
        but it’s also not working at all :(
        • MarosM
          Maros
          Noone any idea?
            davidnesbitt7
            Open up your console in dev tools and see if you’re getting any errors
            Do. Or do not. There is no try
              broberg Project Sponsor @davidnesbitt7
              Folder path is misdirected, try this
              body {
              @font-face {
              font-style: normal;
              font-weight: 100;
              src:
              local(“Verdana”),
              url("../fonts/Verdana.ttf") format(“truetype”);
              .newsfeed {
              • MarosM
                Maros
                @broberg said in Wrong font in newsfeed:
                @font-face {
                font-style: normal;
                font-weight: 100;
                src:
                local(“Verdana”),
                url(“…/fonts/Verdana.ttf”) format(“truetype”);
                .newsfeed {
                i’ve tried but still same
                @davidnesbitt7 i’ve checked error log on pm2 but there nothing mentioned about rss feed font error
                  cabott
                  @maros Did you fix this issue? I’ve encountered the same with Polish news…
                  edit:
                  solved by installing Roboto fonts into Raspbian (found somewhere here at the forum or in the Internet).
                    radokristof @cabott
                    @cabott I have the same problems. Some characters are not showing properly only on the newsfeed module.
                    I have tried installing roboto fonts with apt, how did you installed it? (And which package).
                      cabott @radokristof
                      @radokristof sorry for late answer, I completely missed this topic. For those who still had this issue:
                      I just installed the fonts with
                      sudo apt-get update
                      sudo apt-get install fonts-roboto
                      then
                      fc-cache -fv
                      pm2 restart MagicMirror
                      and voila… works for me.
                      • F
                        Fifin404
                        Work for me. Thank you
