    MMM-GooglePhotos
    294 Posts 56 Posters 415.9k Views 59 Watching
      A Former User @kivlow
      @kivlow
      What kind of RPI do you use? As you said “taskbar”, Is it RPI 2 or 3 with Jessie or Stretch Desktop, right?
      And, Have RPI had any browser (Chromium or Midori?)?
      I’ll change some code for the case of not opening browser automatically, Please wait a while.
      • K
        kivlow
        I use raspberry pi 3b with raspbian borwser chromium.
        cool i wait :] p.s. express response
        ? 1 Reply Last reply
          @kivlow
          I’ve fixed.
          cd ~/MagicMirror/modules/MMM-GooglePhotos
          git pull
          node auth_and_test.js
          You can see like this image;
          When the browser is not be opened automatically, copy the url and paste it into your browser manually.
          K 1 Reply Last reply
          • N
            NathTheDude
            Hi Sean,
            Firstly thank you for this, it has great potential and is something that has been missing for such a long time compared to the alternative dakboard that I was forced to use to get photos displayed.
            I have an issue though, I believe I have been through the steps correctly but can not get it to work. When I reboot my RPI2 it looks like the ‘auth_and_test.js’ is ran and this brings up the browser with googlin login and if I follow this through it gives me the code which is the same experience I have when running ‘auth_and_test.js’ in order to get the album id.
            This then repeats itself every 5mins or so…
            I have added the album id in the config.js but it does not seem to matter if I put a correct or incorrect one in here the same happens. It does not look like it trys to put images on the desktop so I don’t think the module is getting that far.
            Any idea what I have done wrong?
            Nathan
              A Former User @NathTheDude
              @naththedude
              You mean, your MM is trying to re-auth again(every 5 mins.) right?
              First, you should check whether you have token.json in root directory of MMM-GooglePhotos.
              cat token.json
              It should be something similar with this;
              {"access_token":"...","token_type":"Bearer","scope":"https://www.googleapis.com/auth/photoslibrary.readonly","expiry_date":1533304224450,"refresh_token":"..."}
              Your simptom would happen when token.json is missed.
              token.json should be generated as result of auth_and_test.js
              • N
                NathTheDude
                Hey @Sean ,
                Thank you for your quite reply, you are correct the token.josn file was missing. Looks like I needed to run ‘node auth_and_test’ as sudo for this file to be created. Once I did this the photos started to appear :) just need to configure the size and position now.
                Thank you again.
                Regards
                Nathan
                  @naththedude good to you.
                  The only thing I worry is, if you run as sudo there could be a possibility of a problem to refresh token with proper authority.
                  • K
                    kivlow @Guest
                    @sean
                    hello :]
                    I make git pull but nothing change :/
                    still when i wrote in terminal even sudo node auth_and_test.js i get only info that is started.
                    my chromium not open and i dont have any link it termina to past it in chromium :[.
                      @kivlow show me what is seen when you execute node auth_and_test.js. (Do not need to use sudo)
                      • K
                        kivlow
                          @kivlow
                          Hmmm… very weird.
                          Could you try this?
                          nano test.js
                          Then, copy below and paste
                          'use strict';
                          const request = require('request')
                          const Auth = require('./auth.js')
                          var authConfig = {
                            keyFilePath: "./credentials.json",
                            savedTokensPath: "./token.json",
                            scope: "https://www.googleapis.com/auth/photoslibrary.readonly"
                          const auth = new Auth(authConfig)
                          auth.on('ready', (client) => {
                            console.log("auth_and_test started.")
                            var token = client.credentials.access_token
                            console.log("token:", token)
                            function getAlbum(client, pageSize=50, pageToken="") {
                              var url = 'https://photoslibrary.googleapis.com/v1/albums'
                              url = url + "?pageSize=" + pageSize + "&pageToken=" + pageToken
                              console.log("url:", url)
                              request.get(
                                url,
                                  json:true,
                                  auth: {"bearer": token},
                                (err, res, body) => {
                                  console.log("response:", body)
                                  if (err) {
                                    console.log("Error: ", err)
                                    process.exit(1);
                                  var found = 0
                                  for (var i in body.albums) {
                                    var album = body.albums[i]
                                    console.log (album.title, " : ", album.id)
                                    found++;
                                  if (body.nextPageToken && found > 0) {
                                    getAlbum(client, pageSize, body.nextPageToken)
                            getAlbum(client, 50)
                          Then, close and save (Ctrl+X and Y and enter)
                          Then try.
                          node test.js
                          And show me the result.
                          • K
                            kivlow
                            :] thx you are the best :]
                            ? 2 Replies Last reply
                              @kivlow
                              Ok. Now I think I’ve found what’s wrong.
                              https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid
                              You seem to have missed 4. Search for "Google Photos Library API". Select the correct result and click Enable. (You may need to enable "Google Plus" also.)
                              Do 1~4 again.
                              You can access your developer console with URL in the screen also.
                                • K
                                  kivlow
                                  Ok i got it.
                                  I enable Photos Library at different account (i have two google account) so everything works fine right now :]
                                    @kivlow Good to you. It’s my pleasure. Have a nice day.
                                    • K
                                      kivlow
                                      Hello again ;p
                                      I have one question - how to show full picture but in spec dimension.
                                      I use top_right.
                                      I set display 1280x720 and from google 1920x1080.
                                      I see picture from google but many is cut :/
                                        @kivlow
                                        mode:’cover’ will cover your entire target area, but cropped.
                                        mode:’contain’ will show entire image but resized(with black borders)
                                        • K
                                          kivlow
                                          :thumbs_up:
                                          works fine :]
                                            bchabbert
                                            i have a problem when i paste my code error message:
                                            pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ cat toto.txt
                                            pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
                                            Opening OAuth URL.(https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary.readonly&response_type=code&client_id=491102864701-4kg1b7lbb90bt2vsc0cuh5af5acefgje.apps.googleusercontent.com&redirect_uri=urn%3Aietf%3Awg%3Aoauth%3A2.0%3Aoob) Return here with your code.
                                            Paste your code: 4/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                            (node:3967) UnhandledPromiseRejectionWarning: Error: Error getting tokens:
                                            at oauthClient.getToken (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:93:24)
                                            at /home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/google-auth-library/build/src/auth/oauth2client.js:158:46
                                            at
                                            at process._tickCallback (internal/process/next_tick.js:182:7)
                                            (node:3967) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                                            (node:3967) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                            Can you help me please ?
                                            Bérenger.
                                            • 14
                                            • 15
                                            • 2 / 15
