    MMM-GooglePhotos
    294 Posts 56 Posters 418.1k Views 59 Watching
      richfreeman @richfreeman
      @richfreeman
      DOH
      Remove the <>
      Change “<>” to simply “Album ID”
      No <> needed.
      Photo’s appeared !
      Thanks.
      • K
        kivlow @Guest
        @sean said in MMM-GooglePhotos:
        At your first execution, have you countered allowance process?
        At myr first execution terminal not react over 5min after auth_and_test command and i have info to kill suspended process.
        After that when i wrote auth_and_test i get only info that is started :/
        ? 1 Reply Last reply
          A Former User @kivlow
          @kivlow
          I suspect you have executed node auth_and_test.js in shell terminal on your PC via SSH. right?
          If you run that commands on your RPI directly, it should try to open a browser for authenticating process.
          • K
            kivlow
            @sean
            i power on RPI with raspbian then open from upper taskbar terminal and wrote node auth_and_test.js
            how to wrote it directly ??
              @kivlow
              What kind of RPI do you use? As you said “taskbar”, Is it RPI 2 or 3 with Jessie or Stretch Desktop, right?
              And, Have RPI had any browser (Chromium or Midori?)?
              I’ll change some code for the case of not opening browser automatically, Please wait a while.
              • K
                kivlow
                I use raspberry pi 3b with raspbian borwser chromium.
                cool i wait :] p.s. express response
                  @kivlow
                  I’ve fixed.
                  cd ~/MagicMirror/modules/MMM-GooglePhotos
                  git pull
                  You can see like this image;
                  When the browser is not be opened automatically, copy the url and paste it into your browser manually.
                  K 1 Reply Last reply
                  • N
                    NathTheDude
                    Hi Sean,
                    Firstly thank you for this, it has great potential and is something that has been missing for such a long time compared to the alternative dakboard that I was forced to use to get photos displayed.
                    I have an issue though, I believe I have been through the steps correctly but can not get it to work. When I reboot my RPI2 it looks like the ‘auth_and_test.js’ is ran and this brings up the browser with googlin login and if I follow this through it gives me the code which is the same experience I have when running ‘auth_and_test.js’ in order to get the album id.
                    This then repeats itself every 5mins or so…
                    I have added the album id in the config.js but it does not seem to matter if I put a correct or incorrect one in here the same happens. It does not look like it trys to put images on the desktop so I don’t think the module is getting that far.
                    Any idea what I have done wrong?
                    Nathan
                      A Former User @NathTheDude
                      @naththedude
                      You mean, your MM is trying to re-auth again(every 5 mins.) right?
                      First, you should check whether you have token.json in root directory of MMM-GooglePhotos.
                      cat token.json
                      It should be something similar with this;
                      {"access_token":"...","token_type":"Bearer","scope":"https://www.googleapis.com/auth/photoslibrary.readonly","expiry_date":1533304224450,"refresh_token":"..."}
                      Your simptom would happen when token.json is missed.
                      token.json should be generated as result of auth_and_test.js
                      • N
                        NathTheDude
                        Hey @Sean ,
                        Thank you for your quite reply, you are correct the token.josn file was missing. Looks like I needed to run ‘node auth_and_test’ as sudo for this file to be created. Once I did this the photos started to appear :) just need to configure the size and position now.
                        Thank you again.
                        Regards
                        Nathan
                          @naththedude good to you.
                          The only thing I worry is, if you run as sudo there could be a possibility of a problem to refresh token with proper authority.
                          • K
                            kivlow @Guest
                            @sean
                            hello :]
                            I make git pull but nothing change :/
                            still when i wrote in terminal even sudo node auth_and_test.js i get only info that is started.
                            my chromium not open and i dont have any link it termina to past it in chromium :[.
                              @kivlow show me what is seen when you execute node auth_and_test.js. (Do not need to use sudo)
                              • K
                                kivlow
                                  @kivlow
                                  Hmmm… very weird.
                                  Could you try this?
                                  nano test.js
                                  Then, copy below and paste
                                  'use strict';
                                  const request = require('request')
                                  const Auth = require('./auth.js')
                                  var authConfig = {
                                    keyFilePath: "./credentials.json",
                                    savedTokensPath: "./token.json",
                                    scope: "https://www.googleapis.com/auth/photoslibrary.readonly"
                                  const auth = new Auth(authConfig)
                                  auth.on('ready', (client) => {
                                    console.log("auth_and_test started.")
                                    var token = client.credentials.access_token
                                    console.log("token:", token)
                                    function getAlbum(client, pageSize=50, pageToken="") {
                                      var url = 'https://photoslibrary.googleapis.com/v1/albums'
                                      url = url + "?pageSize=" + pageSize + "&pageToken=" + pageToken
                                      console.log("url:", url)
                                      request.get(
                                        url,
                                          json:true,
                                          auth: {"bearer": token},
                                        (err, res, body) => {
                                          console.log("response:", body)
                                          if (err) {
                                            console.log("Error: ", err)
                                            process.exit(1);
                                          var found = 0
                                          for (var i in body.albums) {
                                            var album = body.albums[i]
                                            console.log (album.title, " : ", album.id)
                                            found++;
                                          if (body.nextPageToken && found > 0) {
                                            getAlbum(client, pageSize, body.nextPageToken)
                                    getAlbum(client, 50)
                                  Then, close and save (Ctrl+X and Y and enter)
                                  Then try.
                                  node test.js
                                  And show me the result.
                                  • K
                                    kivlow
                                    :] thx you are the best :]
                                    ? 2 Replies Last reply
                                      @kivlow
                                      Ok. Now I think I’ve found what’s wrong.
                                      https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid
                                      You seem to have missed 4. Search for "Google Photos Library API". Select the correct result and click Enable. (You may need to enable "Google Plus" also.)
                                      Do 1~4 again.
                                      You can access your developer console with URL in the screen also.
                                        • K
                                          kivlow
                                          Ok i got it.
                                          I enable Photos Library at different account (i have two google account) so everything works fine right now :]
                                            @kivlow Good to you. It’s my pleasure. Have a nice day.
                                            • 14
                                            • 15
                                            • 2 / 15
