    MMM-GooglePhotos
    294 Posts 56 Posters 391.6k Views 59 Watching
      A Former User @NathTheDude
      @naththedude good to you.
      The only thing I worry is, if you run as sudo there could be a possibility of a problem to refresh token with proper authority.
      • K Offline
        kivlow @Guest
        @sean
        hello :]
        I make git pull but nothing change :/
        still when i wrote in terminal even sudo node auth_and_test.js i get only info that is started.
        my chromium not open and i dont have any link it termina to past it in chromium :[.
          A Former User @kivlow
          @kivlow show me what is seen when you execute node auth_and_test.js. (Do not need to use sudo)
          cd ~/MagicMirror/modules/MMM-GooglePhotos
          • K Offline
            kivlow
              @kivlow
              Hmmm… very weird.
              Could you try this?
              nano test.js
              Then, copy below and paste
              'use strict';
              const request = require('request')
              const Auth = require('./auth.js')
              var authConfig = {
                keyFilePath: "./credentials.json",
                savedTokensPath: "./token.json",
                scope: "https://www.googleapis.com/auth/photoslibrary.readonly"
              const auth = new Auth(authConfig)
              auth.on('ready', (client) => {
                console.log("auth_and_test started.")
                var token = client.credentials.access_token
                console.log("token:", token)
                function getAlbum(client, pageSize=50, pageToken="") {
                  var url = 'https://photoslibrary.googleapis.com/v1/albums'
                  url = url + "?pageSize=" + pageSize + "&pageToken=" + pageToken
                  console.log("url:", url)
                  request.get(
                    url,
                      json:true,
                      auth: {"bearer": token},
                    (err, res, body) => {
                      console.log("response:", body)
                      if (err) {
                        console.log("Error: ", err)
                        process.exit(1);
                      var found = 0
                      for (var i in body.albums) {
                        var album = body.albums[i]
                        console.log (album.title, " : ", album.id)
                        found++;
                      if (body.nextPageToken && found > 0) {
                        getAlbum(client, pageSize, body.nextPageToken)
                getAlbum(client, 50)
              Then, close and save (Ctrl+X and Y and enter)
              Then try.
              node test.js
              And show me the result.
              • K Offline
                kivlow
                :] thx you are the best :]
                  @kivlow
                  Ok. Now I think I’ve found what’s wrong.
                  https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid
                  You seem to have missed 4. Search for "Google Photos Library API". Select the correct result and click Enable. (You may need to enable "Google Plus" also.)
                  Do 1~4 again.
                  You can access your developer console with URL in the screen also.
                    • K Offline
                      kivlow
                      Ok i got it.
                      I enable Photos Library at different account (i have two google account) so everything works fine right now :]
                        @kivlow Good to you. It’s my pleasure. Have a nice day.
                        • K Offline
                          kivlow
                          Hello again ;p
                          I have one question - how to show full picture but in spec dimension.
                          I use top_right.
                          I set display 1280x720 and from google 1920x1080.
                          I see picture from google but many is cut :/
                            @kivlow
                            mode:’cover’ will cover your entire target area, but cropped.
                            mode:’contain’ will show entire image but resized(with black borders)
                            • K Offline
                              kivlow
                              :thumbs_up:
                              works fine :]
                                bchabbert
                                i have a problem when i paste my code error message:
                                pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ cat toto.txt
                                pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
                                Opening OAuth URL.(https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary.readonly&response_type=code&client_id=491102864701-4kg1b7lbb90bt2vsc0cuh5af5acefgje.apps.googleusercontent.com&redirect_uri=urn%3Aietf%3Awg%3Aoauth%3A2.0%3Aoob) Return here with your code.
                                Paste your code: 4/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                (node:3967) UnhandledPromiseRejectionWarning: Error: Error getting tokens:
                                at oauthClient.getToken (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:93:24)
                                at /home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/google-auth-library/build/src/auth/oauth2client.js:158:46
                                at
                                at process._tickCallback (internal/process/next_tick.js:182:7)
                                (node:3967) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                                (node:3967) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                Can you help me please ?
                                Bérenger.
                                  A Former User @bchabbert
                                  @bchabbert
                                  Hmmm… I think, your oAuth was failed. But I cannot figure out what was wrong at that moment. I suggest you to try again from scratch.
                                    bchabbert @Guest
                                    @sean
                                    Hi Sean,
                                    From scratch ? i delete module and reinstall it ?
                                    Bérenger.
                                    ? C 2 Replies Last reply Reply Quote 0
                                      @bchabbert
                                      I think it was not the fault of the module itself. You’d better remove all your current google project and create new one then try again.
                                        bchabbert @Guest
                                        @sean
                                        thank you for your help :)
                                        I have recreate a new google project and it works now :)
                                        Bérenger.
                                          CGaZ3 @bchabbert
                                          @bchabbert
                                          Did you figure this out?
                                            bowlofred
                                            I’m trying to use this module and am having trouble. Right now I don’t see any output from it. No problem with the authentication step. auth_and_test.js gave me the AlbumId. The config I’m using is:
        module: "MMM-GooglePhotos",
        albumId: "A[removed for posting]dj4",
        refreshInterval: 1000*60,
        scanInterval: 1000*60*10,
        sort: "random",
        showWidth: "80%",
        originalWidthPx: 800,
        originalHeightPx: 600,
        mode: "contain"
                                            The album exists and has 2 sample images in it. I don’t see anything relevant in the log:
                                            Loading config ...
                                            Loading module helpers ...
                                            No helper found for module: MMM-GooglePhotos.
                                            All module helpers loaded.
                                            Server started ...
                                            Ready to go! Please point your browser to: http://localhost:8080
                                            System is pi zero running in server_only mode. (I’ve also tried on Windows/server_only as well, same behavior). I didn’t see if there’s a way to make things more verbose to see what the module is doing. I’m sure I’ve got an error, but I can’t see what it is.
                                            • 14
                                            • 15
                                            • 2 / 15
