    MMM-GooglePhotos
    294 Posts 56 Posters 332.9k Views 59 Watching
      A Former User @NathTheDude
      @naththedude good to you.
      The only thing I worry is, if you run as sudo there could be a possibility of a problem to refresh token with proper authority.
      • K Offline
        kivlow @Guest
        @sean
        hello :]
        I make git pull but nothing change :/
        still when i wrote in terminal even sudo node auth_and_test.js i get only info that is started.
        my chromium not open and i dont have any link it termina to past it in chromium :[.
          A Former User @kivlow
          @kivlow show me what is seen when you execute node auth_and_test.js. (Do not need to use sudo)
          cd ~/MagicMirror/modules/MMM-GooglePhotos
          • K Offline
            kivlow
              @kivlow
              Hmmm… very weird.
              Could you try this?
              nano test.js
              Then, copy below and paste
              'use strict';
              const request = require('request')
              const Auth = require('./auth.js')
              var authConfig = {
                keyFilePath: "./credentials.json",
                savedTokensPath: "./token.json",
                scope: "https://www.googleapis.com/auth/photoslibrary.readonly"
              const auth = new Auth(authConfig)
              auth.on('ready', (client) => {
                console.log("auth_and_test started.")
                var token = client.credentials.access_token
                console.log("token:", token)
                function getAlbum(client, pageSize=50, pageToken="") {
                  var url = 'https://photoslibrary.googleapis.com/v1/albums'
                  url = url + "?pageSize=" + pageSize + "&pageToken=" + pageToken
                  console.log("url:", url)
                  request.get(
                    url,
                      json:true,
                      auth: {"bearer": token},
                    (err, res, body) => {
                      console.log("response:", body)
                      if (err) {
                        console.log("Error: ", err)
                        process.exit(1);
                      var found = 0
                      for (var i in body.albums) {
                        var album = body.albums[i]
                        console.log (album.title, " : ", album.id)
                        found++;
                      if (body.nextPageToken && found > 0) {
                        getAlbum(client, pageSize, body.nextPageToken)
                getAlbum(client, 50)
              Then, close and save (Ctrl+X and Y and enter)
              Then try.
              node test.js
              And show me the result.
              • K Offline
                kivlow
                :] thx you are the best :]
                  @kivlow
                  Ok. Now I think I’ve found what’s wrong.
                  https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid
                  You seem to have missed 4. Search for "Google Photos Library API". Select the correct result and click Enable. (You may need to enable "Google Plus" also.)
                  Do 1~4 again.
                  You can access your developer console with URL in the screen also.
                    • K Offline
                      kivlow
                      Ok i got it.
                      I enable Photos Library at different account (i have two google account) so everything works fine right now :]
                        @kivlow Good to you. It’s my pleasure. Have a nice day.
                        • 29
                        • 30
                        • 3 / 30
