    MMM-GooglePhotos
    294 Posts 56 Posters 389.3k Views 59 Watching
      [[global:former-user]] @kivlow
      @kivlow show me what is seen when you execute node auth_and_test.js. (Do not need to use sudo)
      cd ~/MagicMirror/modules/MMM-GooglePhotos
      • K Offline
        kivlow
          @kivlow
          Hmmm… very weird.
          Could you try this?
          nano test.js
          Then, copy below and paste
          'use strict';
          const request = require('request')
          const Auth = require('./auth.js')
          var authConfig = {
            keyFilePath: "./credentials.json",
            savedTokensPath: "./token.json",
            scope: "https://www.googleapis.com/auth/photoslibrary.readonly"
          const auth = new Auth(authConfig)
          auth.on('ready', (client) => {
            console.log("auth_and_test started.")
            var token = client.credentials.access_token
            console.log("token:", token)
            function getAlbum(client, pageSize=50, pageToken="") {
              var url = 'https://photoslibrary.googleapis.com/v1/albums'
              url = url + "?pageSize=" + pageSize + "&pageToken=" + pageToken
              console.log("url:", url)
              request.get(
                url,
                  json:true,
                  auth: {"bearer": token},
                (err, res, body) => {
                  console.log("response:", body)
                  if (err) {
                    console.log("Error: ", err)
                    process.exit(1);
                  var found = 0
                  for (var i in body.albums) {
                    var album = body.albums[i]
                    console.log (album.title, " : ", album.id)
                    found++;
                  if (body.nextPageToken && found > 0) {
                    getAlbum(client, pageSize, body.nextPageToken)
            getAlbum(client, 50)
          Then, close and save (Ctrl+X and Y and enter)
          Then try.
          node test.js
          And show me the result.
          • K Offline
            kivlow
            :] thx you are the best :]
              @kivlow
              Ok. Now I think I’ve found what’s wrong.
              https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid
              You seem to have missed 4. Search for "Google Photos Library API". Select the correct result and click Enable. (You may need to enable "Google Plus" also.)
              Do 1~4 again.
              You can access your developer console with URL in the screen also.
                • K Offline
                  kivlow
                  Ok i got it.
                  I enable Photos Library at different account (i have two google account) so everything works fine right now :]
                    @kivlow Good to you. It’s my pleasure. Have a nice day.
                    • K Offline
                      kivlow
                      Hello again ;p
                      I have one question - how to show full picture but in spec dimension.
                      I use top_right.
                      I set display 1280x720 and from google 1920x1080.
                      I see picture from google but many is cut :/
                        @kivlow
                        mode:’cover’ will cover your entire target area, but cropped.
                        mode:’contain’ will show entire image but resized(with black borders)
                        • K Offline
                          kivlow
                          :thumbs_up:
                          works fine :]
                            bchabbert
                            i have a problem when i paste my code error message:
                            pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ cat toto.txt
                            pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
                            Opening OAuth URL.(https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary.readonly&response_type=code&client_id=491102864701-4kg1b7lbb90bt2vsc0cuh5af5acefgje.apps.googleusercontent.com&redirect_uri=urn%3Aietf%3Awg%3Aoauth%3A2.0%3Aoob) Return here with your code.
                            Paste your code: 4/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                            (node:3967) UnhandledPromiseRejectionWarning: Error: Error getting tokens:
                            at oauthClient.getToken (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:93:24)
                            at /home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/google-auth-library/build/src/auth/oauth2client.js:158:46
                            at
                            at process._tickCallback (internal/process/next_tick.js:182:7)
                            (node:3967) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                            (node:3967) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                            Can you help me please ?
                            Bérenger.
                              [[global:former-user]] @bchabbert
                              @bchabbert
                              Hmmm… I think, your oAuth was failed. But I cannot figure out what was wrong at that moment. I suggest you to try again from scratch.
                                bchabbert @Guest
                                @sean
                                Hi Sean,
                                From scratch ? i delete module and reinstall it ?
                                Bérenger.
                                ? C 2 Replies Last reply Reply Quote 0
                                  @bchabbert
                                  I think it was not the fault of the module itself. You’d better remove all your current google project and create new one then try again.
                                    bchabbert @Guest
                                    @sean
                                    thank you for your help :)
                                    I have recreate a new google project and it works now :)
                                    Bérenger.
                                      CGaZ3 @bchabbert
                                      @bchabbert
                                      Did you figure this out?
                                        bowlofred
                                        I’m trying to use this module and am having trouble. Right now I don’t see any output from it. No problem with the authentication step. auth_and_test.js gave me the AlbumId. The config I’m using is:
        module: "MMM-GooglePhotos",
        albumId: "A[removed for posting]dj4",
        refreshInterval: 1000*60,
        scanInterval: 1000*60*10,
        sort: "random",
        showWidth: "80%",
        originalWidthPx: 800,
        originalHeightPx: 600,
        mode: "contain"
                                        The album exists and has 2 sample images in it. I don’t see anything relevant in the log:
                                        Loading config ...
                                        Loading module helpers ...
                                        No helper found for module: MMM-GooglePhotos.
                                        All module helpers loaded.
                                        Server started ...
                                        Ready to go! Please point your browser to: http://localhost:8080
                                        System is pi zero running in server_only mode. (I’ve also tried on Windows/server_only as well, same behavior). I didn’t see if there’s a way to make things more verbose to see what the module is doing. I’m sure I’ve got an error, but I can’t see what it is.
                                          [[global:former-user]] @bowlofred
                                          @bowlofred
                                          It’s weird. Because
                                          means you have no node_helper.js in your module directory. Have you removed?
                                            bowlofred @Guest
                                            @sean Nope, just unfamiliar with installation. I thought the npm install took care of the location, and I didn’t have it in the modules directory. Once I put it there, I got log output and tried playing around to make it visible.
                                            My configuration above is still blank, but if I change the position to “fullscreen_below”, it shows the image. It seems that if the position is the same as some other module, it is shown (but very small). if the position is not fullscreen, but different from any other, then it doesn’t appear.
                                            My intent is to have the photos on one side (top to bottom) and have some other items beside it. If I leave it fullscreen and set showWidth to 60%, it almost works. It stays on the left, so I can put other items on the right. But the image isn’t centered vertically. There’s a black bar at the bottom that is never drawn. It seems to be centered vertically within the remaining space.
                                            • 14
                                            • 15
                                            • 2 / 15
