Multiples of same module?
6 Posts 4 Posters 2.2k Views 4 Watching
  • I Offline
    isabellaalstrom
    I’m trying to have multiple modules of the same kind, but it doesn’t seem to work. What I’ve tried with is MMM-homeassistant-sensors and MMM-SL-PublicTransport. No error messages, just that the second module doesn’t work. Is this not possible?
    ? 1 Reply Last reply Aug 8, 2018, 9:20 AM Reply Quote 0
      A Former User @isabellaalstrom
      @isabellaalstrom
      Some modules cannot work with multiple instances.
      Usually, If the module has node_helper.js, that kind of module wouldn’t work normally.
      Besides, If the module is using a unique DOM id or using singleton pattern in its code, that kind also has the possibility of not working properly.
      I 1 Reply Last reply Aug 8, 2018, 9:34 AM Reply Quote 0
      • I Offline
        isabellaalstrom @Guest
        @sean Alright, thank you! Both of these has node_helper.js, so I guess it’s that then!
          doubleT Module Developer
          If you want a quick and dirty solution, copy the module folder, rename the copy and then change the module’s name to match the new module/folder name in all occurances (file names and within the code).
          I 1 Reply Last reply Aug 8, 2018, 1:34 PM Reply Quote 1
            maxbachmann
            Haha yeah thats the solution I use aswell ;)
            • I Offline
              isabellaalstrom @doubleT
              @doublet I will try this! I really want them on several places in the mirror :)
