    MagicMirror freezes my pi
    7 Posts 3 Posters 3.0k Views 3 Watching
      mariecbilodeau
      I was doing my setup for my Mirror and suddenly the mirror stopped loading. Everything freezes… I have to kill electron in the task manager to unfreeze my pi.
      So I tried reverting to my previous magic mirror setting that was ok before. Same bug. I updated rasbian, erased all magic mirror and reinstalled again, same bug.
      Every time I have to kill the 4 electron task in my task manager. No error shows up when I do the npm start. How can I solve this?
        Charley Module Developer @mariecbilodeau
        @mariecbilodeau what do you see on the screen if it freezes. A blank screen or a screen that isn’t updating?
        Mine went blank but was due to the screensaver. It should be disabled.
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          mariecbilodeau
          Magic mirror doesn’t even load… I tried to erase everything and do the complete setup tutorial on the forum, it still does the same. I have to do ctrl+alt+del and kill electron for it to unfreeze
          0_1533775715948_Capture d’écran 2018-08-08 à 20.47.32.png image url)
            mariecbilodeau
            This is the error log I have
            1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
            2 info using npm@6.3.0
            3 info using node@v9.11.2
            4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
            5 info lifecycle magicmirror@2.4.1~prestart: magicmirror@2.4.1
            6 info lifecycle magicmirror@2.4.1~start: magicmirror@2.4.1
            7 verbose lifecycle magicmirror@2.4.1~start: unsafe-perm in lifecycle true
            8 verbose lifecycle magicmirror@2.4.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
            9 verbose lifecycle magicmirror@2.4.1~start: CWD: /home/pi/MagicMirror
            10 silly lifecycle magicmirror@2.4.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
            11 silly lifecycle magicmirror@2.4.1~start: Returned: code: 137 signal: null
            12 info lifecycle magicmirror@2.4.1~start: Failed to exec start script
            13 verbose stack Error: magicmirror@2.4.1 start: sh run-start.sh
            13 verbose stack Exit status 137
            13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:16)
            13 verbose stack at EventEmitter.emit (events.js:180:13)
            13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
            13 verbose stack at ChildProcess.emit (events.js:180:13)
            13 verbose stack at maybeClose (internal/child_process.js:936:16)
            13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
            14 verbose pkgid magicmirror@2.4.1
            15 verbose cwd /home/pi/MagicMirror
            16 verbose Linux 4.14.61-v7+
            17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
            18 verbose node v9.11.2
            19 verbose npm v6.3.0
            20 error code ELIFECYCLE
            21 error errno 137
            22 error magicmirror@2.4.1 start: sh run-start.sh
            22 error Exit status 137
            23 error Failed at the magicmirror@2.4.1 start script.
            23 error This is probably not a problem with npm. There is likely additional logging output above.
            24 verbose exit [ 137, true ]
              mariecbilodeau
              I reinstalled raspbian and now everything works
                A Former User
                How did you do that? I have the same Problem.
                  mariecbilodeau
                  I reinstall with the restore mode at startup and I reinstall all my mirror from scratch
