    MagicMirror freezes my pi
    7 Posts 3 Posters 2.8k Views 3 Watching
      mariecbilodeau
      Magic mirror doesn’t even load… I tried to erase everything and do the complete setup tutorial on the forum, it still does the same. I have to do ctrl+alt+del and kill electron for it to unfreeze
      0_1533775715948_Capture d’écran 2018-08-08 à 20.47.32.png image url)
        mariecbilodeau
        This is the error log I have
        1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
        2 info using npm@6.3.0
        3 info using node@v9.11.2
        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
        5 info lifecycle magicmirror@2.4.1~prestart: magicmirror@2.4.1
        6 info lifecycle magicmirror@2.4.1~start: magicmirror@2.4.1
        7 verbose lifecycle magicmirror@2.4.1~start: unsafe-perm in lifecycle true
        8 verbose lifecycle magicmirror@2.4.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
        9 verbose lifecycle magicmirror@2.4.1~start: CWD: /home/pi/MagicMirror
        10 silly lifecycle magicmirror@2.4.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
        11 silly lifecycle magicmirror@2.4.1~start: Returned: code: 137 signal: null
        12 info lifecycle magicmirror@2.4.1~start: Failed to exec start script
        13 verbose stack Error: magicmirror@2.4.1 start: sh run-start.sh
        13 verbose stack Exit status 137
        13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:16)
        13 verbose stack at EventEmitter.emit (events.js:180:13)
        13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
        13 verbose stack at ChildProcess.emit (events.js:180:13)
        13 verbose stack at maybeClose (internal/child_process.js:936:16)
        13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
        14 verbose pkgid magicmirror@2.4.1
        15 verbose cwd /home/pi/MagicMirror
        16 verbose Linux 4.14.61-v7+
        17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
        18 verbose node v9.11.2
        19 verbose npm v6.3.0
        20 error code ELIFECYCLE
        21 error errno 137
        22 error magicmirror@2.4.1 start: sh run-start.sh
        22 error Exit status 137
        23 error Failed at the magicmirror@2.4.1 start script.
        23 error This is probably not a problem with npm. There is likely additional logging output above.
        24 verbose exit [ 137, true ]
          mariecbilodeau
          I reinstalled raspbian and now everything works
            A Former User
            How did you do that? I have the same Problem.
              mariecbilodeau
              I reinstall with the restore mode at startup and I reinstall all my mirror from scratch
