MMM-AssistantMk2 problems when using electron-rebuild
40 Posts 6 Posters 17.0k Views 6 Watching
  • X Offline
    Xintium
    When I start my magic mirror I get node version error so I did as the instructions told me and tried using electron-rebuild. But when I use electron-rebuild I get this error:
    make: *** Ingen regel för att skapa målet ”Release/obj.target/grpc/deps/grpc/src/cpp/ext/filters/census/grpc_context.o”, som behövs av ”Release/obj.target/libgrpc.a”.  Stannar.
    make: Lämnar katalogen ”/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build”
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:180:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:12)
    gyp ERR! System Linux 4.14.52-v7+
    gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=2.0.0" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source" "--module_name=grpc_node" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc" "--host=https://node-precompiled-binaries.grpc.io/" "--remote_path={name}/v1.14.0" "--package_name=electron-v2.0-linux-arm-glibc.tar.gz"
    gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc
    gyp ERR! node -v v9.11.2
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    Failed with exit code: 1
        at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:277:84)
        at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:242:16)
        at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:201:26)
        at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
        at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
        at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
        at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
        at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:251:65)
        at SafeSubscriber.__tryOrSetError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:251:16)
        at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:191:27)
    Excuse the Swedish parts.
    What do I do to make it work?
    ? 1 Reply Last reply Aug 12, 2018, 3:19 PM Reply Quote 0
      A Former User @Xintium
      @xintium
      It seems you’ve missed some dependencies or mismatched version (especially node-gyp)
      First, To make things simple, do these before install,
      sudo apt-get update
      sudo apt-get upgrade
      and try rebuilding again.
      If fails, remove whole MMM-AssistantMk2, and resintall from scratch.
      X 1 Reply Last reply Aug 12, 2018, 4:15 PM Reply Quote 0
      • X Offline
        Xintium @Guest
        @sean should I run
        npm install --save-dev electron-rebuild
        ./node_modules/.bin/electron-rebuild
        In MMM-AssistantMk2 or in MagicMirror directory?
        ? 1 Reply Last reply Aug 12, 2018, 4:20 PM Reply Quote 0
          @xintium
          In MMM-AssistankMk2 directory.
          X 2 Replies Last reply Aug 12, 2018, 5:06 PM Reply Quote 0
          • X Offline
            Xintium @Guest
            @sean I get the same error as I shared abow
            • X Offline
              Xintium @Guest
              @sean This is what I get when I run magic mirror
              > magicmirror@2.4.1 start /home/pi/MagicMirror
              > sh run-start.sh
              Starting MagicMirror: v2.4.1
              Loading config ...
              Loading module helpers ...
              No helper found for module: MMM-darksky-hourly.
              Module helper loaded: MMM-MyCalendar
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
              Expected directory: electron-v2.0-linux-arm-glibc
              Found: [node-v59-linux-arm-glibc]
              This problem can often be fixed by running "npm rebuild" on the current system
              Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node'
              App threw an error during load
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
                  at Module._compile (module.js:642:30)
                  at Object.Module._extensions..js (module.js:653:10)
                  at Module.load (module.js:561:32)
                  at tryModuleLoad (module.js:504:12)
                  at Function.Module._load (module.js:496:3)
                  at Module.require (module.js:586:17)
                  at require (internal/module.js:11:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12)
              { Error: Failed to load gRPC binary module because it was not installed for the current system
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12) code: 'MODULE_NOT_FOUND' }
              Launching application.
              ? 1 Reply Last reply Aug 12, 2018, 6:12 PM Reply Quote 0
                @xintium
                You need module to rebuild.
                If you tried already, something was wrong so rebuilding process might have been failed.
                Have you any suspicious messages during your rebuilds?
                X 1 Reply Last reply Aug 12, 2018, 6:46 PM Reply Quote 0
                • X Offline
                  Xintium @Guest
                  @sean I get this message when trying to use electron-rebuild
                  gyp ERR! not ok
                  ? 1 Reply Last reply Aug 12, 2018, 8:20 PM Reply Quote 0
                    @xintium
                    For confirmation,
                    1. Did you update & upgrade dependencies?
                    2. After that, did you remove MMM-AssistantMk2 directory and reinstall again?
                    Your error shows some of your dependencies are not updated to rebuild.
                    In that case, usually above steps are enough to fix.
                    Maybe this might be a help, but not sure.
                    sudo apt-get install build-essential
                    sudo npm install -g node-gyp
                    • L Offline
                      logen563
                      Hello!
                      I have this error, when trying to run the node_auth_test.js
                      Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21’ not found (required by /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/node-v48-linux-arm-glibc/grpc_node.node)
                      Can you give some advise how to solve this?
                      ? 1 Reply Last reply Aug 14, 2018, 7:07 AM Reply Quote 0
                      • 1 / 4
                      1 / 4
