    omxplayer overlay
    19 Posts 4 Posters 10.8k Views 3 Watching
      maxbachmann
      since electron and videos really don´t work well together I want to use a overlay with omxplayer. Is there already a module doing this I just did not find?
      If not my idea was to show a black form with the size of the video on the screen, so the overlay is not above any other stuff. However I did not find out how to get the absolute position of a dom object, so I can give the position to omxplayer
      MrCoffeeM 1 Reply Last reply
      • A
        AxLed Module Developer
        @maxbachmann
        MMM-Podcast is using OMX Player to show videos.
        AxLED
          maxbachmann
          @axled said in omxplayer overlay:
          MMM-Podcast
          Ah thx I think thats exactly what I searched for
            maxbachmann
            oh no thats exactly what I did already achieve. It just overlays omxplayer, without making sure there is nothing below then, so it will hide other informations on the screen.
            Thats what I wanted to achieve but I did not know how to make sure a area is actually clear the way it would be when I just directly show a video in MM2
            I mean for one video I can do it approximately, but would be nice to have a real solution instead of try and error xD
            • evroomE
              evroom
              There is MMM-RTSPStream too.
              Meant to stream video for camera’s, but it works for every RTSP stream.
              You can specify height and width, but the position is determined by the module position.
              Overlaying other modules depends on the position of those modules, but there is nothing that can’t be done using the custom.css.
              And you cannot get away with trial and error.
              It took me a while to get it pixel perfect…
              MagicMirror version: 2.37.0
                maxbachmann
                ok thats what I wanted to know :)
                so there is basically no really nice way to read the pixels you have to do it try an error
                  maxbachmann
                  btw anyone knows how to set loop? I already tried multiple of the node omxplayer applications. They all have a loop function (well using it just stops after one run anyways)
                  • evroomE
                    evroom
                    I just tried MMM-RTSPStream and it loops the video without any extra options.
                    You also could just try to add --loop after the URL of the video.
                    When lucky it will be used as an omxplayer option.
                    As omxplayer uses a fixed position, relative to the position of the module, it might need a bit extra fiddling.
                    But with MMM-RTSPStream and the module options
                    moduleWidth: 900,
                    moduleHeight: 364,
                    and the omxplayer options
                    width: 480,
                    height: 270
                    you have the control over the overlay and overlapping that you need.
                    And with the custom.css you have additional options and control.
                      maxbachmann
                      @evroom
                      Hm i Kind of fail to use it. When I use a config without url (I gave it a path to a local file)
                      showSnapsWhen paused is activated, I get this black window on the screen so the stream does not interfere with anything, however nothing is shown with omxplayer (autostartplay activated)
                      tried with mp4 and mov
                      so how do I properly use a local file then?
                      • evroomE
                        evroom
                        Can you try this config, just to know what works and what not ?
                            module: "MMM-RTSPStream",
                            disabled: false,
                            position: "middle_center",
                            header: "Video",
                              autoStart: true,
                              rotateStreams: false,
                              moduleWidth: 900,
                              moduleHeight: 364,
                              localPlayer: 'omxplayer',
                              remotePlayer: 'none',
                              showSnapWhenPaused: false,
                              remoteSnaps: false,
                              stream1: {
                                name: 'BigBuckBunny Test Stream',
                                url: 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov',
                                width: 480,
                                height: 270
                        Height and width are perhaps a bit odd; is what I use for my camera streams.
                        I will look if streaming a local file is possible; never tried it.
                        • evroomE
                          evroom
                          For me this works:
                          url: '/home/pi/Videos/MoonEclipse.mp4',
                          So no ‘rtsp:’.
                          But I do not know if this sets the right parameters for this purpose, are more suited for CAM streaming I suppose:
                          |mm       | Starting stream stream1 with args: [
                          1|mm       |     "--avdict",
                          1|mm       |     "rtsp_transport:tcp",
                          1|mm       |     "--win",
                          1|mm       |     "33, 620, 513, 890",
                          1|mm       |     "--live",
                          1|mm       |     "--video_queue",
                          1|mm       |     "4",
                          1|mm       |     "--fps",
                          1|mm       |     "30",
                          1|mm       |     "/home/pi/Videos/MoonEclipse.mp4"
                          1|mm       | ]
                          Makes my Pi very slow too, but that is because I put the file on the SD, which is not a fast medium in my case.
                            maxbachmann
                            ty I will try it
                            Ok I tried. Your first config worked perfectly fine when I tried and it showed me the video. However when I just swapped the url with a file path the way you said in your last post the omxplayer does not open it
                            • MrCoffeeM
                              MrCoffee @maxbachmann
                              @maxbachmann
                              I am just wondering…did you downgrade your electron to avoid activating openGL?
                              With openGL activated omxplayer ist not working anymore. Or did I get something wrong.
                              Sorry, it is not an answer for your question.
                              Thx
                              Mr.Coffee
                                maxbachmann
                                Hm no I did not downgrade electron. I am really not that deap in the topic, but why does electron stop omxplayer from working? (at least in my case omxplayer still works, although it kind of does not work with local files for me for whatever reason)
                                • MrCoffeeM
                                  @maxbachmann
                                  Seems like you do not have the latest version of MagicMirror installed.
                                  It is said “The latest versions of electron use an extreme amount of CPU power when no Open GL driver is loaded. This will result in an overheating Raspberry Pi.”
                                  Thats why I had to activate OpenGL which stops the omxplayer from working (it is not the electron).
                                  Enable the Open GL driver to decrease Electron’s CPU usage
                                  But it is off topic. So thank you so far.
                                    maxbachmann
                                    wait they screwed electron even more??
                                    What the heck is wrong with them I am already super annoyed they still use no hardware acceleration for videos
                                    • evroomE
                                      evroom
                                      To be honest, I do run MM 2.4.1, but did not activate OpenGL. That is to say, I commented out
                                      #dtoverlay=vc4-fkms-v3d
                                      The electron processes do not show extreme usage and the temperature is around 48 celsius (25 celsius room temperature).
                                      I have 2 camera streams running.
                                      And I fail to see the difference between streaming via a rtsp url and from the SD card.
                                      It just now pops up in my head; do you have the MPG2 license?
                                      Try this to see if it is enabled:
                                      # vcgencmd codec_enabled MPG2
                                        maxbachmann
                                        When not included by default I will definetly do not have it. Will try it when I am home later today.
                                        And yes I am confused whats the difference aswell. Especially because I can absolutely use omxplayer with a local file from the shell
                                        • evroomE
                                          evroom
                                          The MPG2 license I most probably needed in order to be able to stream the satellite TS stream.
                                          With the codec disabled, I am still able to play the .mov and .mp4 files.
                                          In general the rule applies: when you can play / stream a source using omxplayer from the command-line, you should be able to play that source via MM (as long as the module used passes the right omxplayer parameters).
                                          If you want to pursue the issue further, you can add the --genlog parameter in order to generate the omxplayer.log file:
                                          cd /MagicMirror/modules/MMM-RTSPStream
                                          $ vi node_helper.js
                                          Edit line 113:
                                          args.unshift("--genlog", "--avdict", "rtsp_transport:tcp");
                                          Restart MM.
                                          $ ls -als /home/pi/MagicMirror/omxplayer.log
                                          Perhaps this log will reveal why the file does not play.
