Magic Mirror not booting up
Guys I’m becoming mad, I have spent last two days configuring my smart mirror with google assistant, Spotify and other. Finally today everything was working more or less (just minor adjustment to be done).
Unfortunately now it doesn’t work anymore, it doesn’t even boot. I can guarantee that before booting I changed just two things:- I removed this line
display_rotate=1
from
/boot/config.txt - I removed
-nocursor
from
xserver-command=X -s 0 -dpms -nocursor
in
/etc/lightdm/lightdm.conf
@lorenzo_zappa
It seems your config.js is missed or have something wrong.stop pm2 and try this and watch which error is shown.
cd ~/MagicMirror npm start devyou can check your configuration with;
npm run config:check -
@sean I cannot start magic mirror using npm start dev because it’s like the graphical environment didn’t load.
My config file is ok, I just checked it -
@lorenzo_zappa
Ok, How about your pm2 log?pm2 logs -
Thanks god I solved it!!!
While exiting from /etc/lightdm/lightdm.conf I pressed inadvertently option+x instead control+x and I added “†” in the file without realising it.
Thank you guys for helping me out
