    CSS-help
    5 Posts 3 Posters 2.0k Views 2 Watching
      jorgeb1502
      I have a problem with the text being bunched together, how do I make it have some spaces between the different elements?
        [[global:former-user]] @jorgeb1502
        @jorgeb1502
        give a padding inside box model.
        .your_target_className {
          padding-right:10px;
        just example.
          jorgeb1502
          @sean
          How do I create one and how do I use it? I’m kind of new to this.
          • cowboysdudeC Offline
            @sean said in CSS-help:
            padding-right:10px;
            If all you need is that one entry you can put it in your custom.css file located in the css directory of magicmirror like this…
            .MMM-Whateveryourmodulenameis .your_target_className {
            padding-right:10px;
            OR add this to your module:
                  getStyles: function() {
                   return ["MMM-Whateveryourmodulenameis.css"];
            Then create a css file named like the above and enter your info in that…
            Like I said if you only need that one entry I’d just shove into my custom.css file…
            J 1 Reply Last reply Reply Quote 3
              jorgeb1502 @cowboysdude
              @cowboysdude
              Thanks! Finally did it!
