    MMM-AssistantMk2
    421 Posts 61 Posters 796.8k Views 57 Watching
      A Former User @mariecbilodeau
      @mariecbilodeau more details are needed to answer. Error logs or screenshots could be helpful.
        mariecbilodeau
        this is when I load my mirror with just hotword and assistant installed. I’ll try to rebuild electron again to get the log
        > magicmirror@2.4.1 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.4.1
        Loading config ...
        Loading module helpers ...
        Module helper loaded: MMM-Hotword
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
        Expected directory: electron-v2.0-linux-arm-glibc
        Found: [node-v59-linux-arm-glibc]
        This problem can often be fixed by running "npm rebuild" on the current system
        Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node'
        App threw an error during load
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
            at Module._compile (module.js:642:30)
            at Object.Module._extensions..js (module.js:653:10)
            at Module.load (module.js:561:32)
            at tryModuleLoad (module.js:504:12)
            at Function.Module._load (module.js:496:3)
            at Module.require (module.js:586:17)
            at require (internal/module.js:11:18)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12)
        { Error: Failed to load gRPC binary module because it was not installed for the current system
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12) code: 'MODULE_NOT_FOUND' }
        Launching application.
        pi@raspberrypi:~/MagicMirror $
          mariecbilodeau
          this is part of my rebuild error
          pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm install --save-dev electron-rebuild
          npm WARN MMM-AssistantMk2@1.0.1 No repository field.
          + electron-rebuild@1.8.2
          updated 1 package in 18.167s
          pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ ./node_modules/.bin/electron-rebuild
          ✖ Rebuild Failed
          An unhandled error occurred inside electron-rebuild
          gyp info it worked if it ends with ok
          gyp info using node-gyp@3.8.0
          gyp info using node@9.11.2 | linux | arm
          gyp info spawn /usr/bin/python2
          gyp info spawn args [ '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/gyp/gyp_main.py',
          gyp info spawn args   'binding.gyp',
          gyp info spawn args   '-f',
          gyp info spawn args   'make',
          gyp info spawn args   '-I',
          gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build/config.gypi',
          gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/addon.gypi',
          gyp info spawn args   '/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/common.gypi',
          gyp info spawn args   '-Dlibrary=shared_library',
          gyp info spawn args   '-Dvisibility=default',
          gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0',
          gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp',
          gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/<(target_arch)/iojs.lib',
          gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc',
          gyp info spawn args   '-Dnode_engine=v8',
          gyp info spawn args   '--depth=.',
          gyp info spawn args   '--no-parallel',
          gyp info spawn args   '--generator-output',
          gyp info spawn args   'build',
          gyp info spawn args   '-Goutput_dir=.' ]
          gyp info spawn make
          gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
          make : on entre dans le répertoire « /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build »
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/avl/avl.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/backoff/backoff.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_args.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack_builder.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_trace.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channelz.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channelz_registry.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/connected_channel.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker_factory.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker_registry.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/status_util.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression_internal.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/message_compress.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression_gzip.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression_identity.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/stats.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/stats_data.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/format_request.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/httpcli.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/parser.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/call_combiner.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/combiner.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_posix.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_uv.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_windows.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/error.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epoll1_linux.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epollex_linux.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epollsig_linux.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_poll_posix.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_posix.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_windows.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/exec_ctx.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/executor.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/fork_posix.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/fork_windows.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_fallback.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_host_name_max.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_sysconf.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iocp_windows.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_custom.o
            CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_internal.o
          ? 1 Reply Last reply
            @mariecbilodeau
            “gyp ERR …” lines are needed. Your log is missing those infos.
            M 1 Reply Last reply
            • T
              themc
              is there any way to play local stored mp3 files on the raspbery pi using the play … command
              currently when saying prhases like play mp3 it says oke and stops.
              im wondering if it is possible to play music mp3s from the music folder using the built in player of vlc player by sying the google command of a gaction
              would be a nice addition to the plugin
                A Former User @themc
                @themc
                If you have a module to play mp3 and it is able to be activated by notification, it could. But adding some specific job to Assistant itself, I think it is not so good idea, because each circumstance is different.
                So have you a module which can play mp3? I can make gaction sample for it.
                  dvbit @Guest
                  @sean thanks for all the info.
                  Just saw this after sending you request for info.
                  will search better / more in the future :-)
                    dvbit
                    Looking for a solution for my vertical setup and browsing the file system I have seen that the cardsare stored in a temp_screen html file in the plugin folder.
                    changing there font size from 40px to 20px makes already a big diff (no scroll bars… in the cards)
                    is htere a way I can intercept that file and edit before presentation?
                    that would already do a good trick :-)
                      A Former User @dvbit
                      @dvbit
                      I’ve already done that. screenZoom is that.
                      But anyway, That screenOutput was made for SmartTV, so it was optimized for Landscape mode. And unfortunately, the screenOutput is uncontrollable static HTML itself. There is no enough room for control.
                      I wish the next version of Google SDK could provide structured data instead static HTML for screenOutput.
                        dvbit
                        Ok. Tx will use that parameter then :-)
                          mariecbilodeau @Guest
                          @sean here is my complete log
                          https://www.dropbox.com/s/7l4wd8xtb3t9odk/error log?dl=0
                          thank you for your help :)
                            mariecbilodeau
                            I got it working with your solution in the troubleshooting section!!! thx
                            • T
                              ToastedToasty
                              @Sean Hi Sean I’ve been trying to setup MMM-Assistant however after renaming my client-secret.json file to credentials.json and running the auth_and_test.json the OAuth2 page to get my token gives me an error 500, any ideas?
                              ? D 2 Replies Last reply
                                A Former User @ToastedToasty
                                @toastedtoasty Usually, 500 error means your google project has something wrong. I suggest you remove your google project and recreate again. (I doubt you might have two or more projects and have some confusing about selecting them)
                                  dvbit
                                  @Sean
                                  I have all setup correctly and no error with the configs.
                                  I think I have understood the correct working of transcriptionhook but it does not fire the related actions.
                                  Can you confirm it is like this the logic:
                                  I setup a keyword in the config (unicorn) in the example you provide.
                                  Notification trigger catches the word if it is spoken after the hotword.
                                  The related action is fired.
                                  Unfortunately nothing is triggered . Also : should I see some feedback in the console windows if the hook triggers ?
                                  Thanks as usual for the support
                                    dvbit @ToastedToasty
                                    @toastedtoasty I think you might have forgot to configure your mail in the oauth tab in google Dev console.
                                    This happened to me.
                                      @dvbit You can add
                                      console.log("hook", k)
                                      in line 100 of node_helper.js to check whether hookstring be caught or not.
                                      D 1 Reply Last reply
                                      Reply Quote 2
                                        dvbit @Guest
                                        @sean Thanks… guess what? assistant setup in my mother tongue did not catch english hook :-D
                                        • T
                                          teitlebot @Guest
                                          @sean @JRCelis Im having the same issue with the buzz and im also using the HAT. Did you fix the issue? Is there a way to just not use the HAT I have a usb mic but Im new at the whole raspberry thing.
                                          Looks like a great module but im having small hickups along the way.
                                            MarkV
                                            I’ve installed MMM-AssistantMk2 with MMM-Hotword and MMM-NotificationTrigger.
                                            Everything works fine except for the return audio.
                                            It stutters and i’m getting the idea that it isn’t procest quick eneough.
                                            Am i the only one with this problem and if not does somebody have the solution?
                                            • 21
                                            • 22
                                            • 3 / 22
