    MMM-AssistantMk2
    421 Posts 61 Posters 778.9k Views 57 Watching
      mariecbilodeau
      this is part of my rebuild error
      pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm install --save-dev electron-rebuild
      npm WARN MMM-AssistantMk2@1.0.1 No repository field.
      + electron-rebuild@1.8.2
      updated 1 package in 18.167s
      pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ ./node_modules/.bin/electron-rebuild
      ✖ Rebuild Failed
      An unhandled error occurred inside electron-rebuild
      gyp info it worked if it ends with ok
      gyp info using node-gyp@3.8.0
      gyp info using node@9.11.2 | linux | arm
      gyp info spawn /usr/bin/python2
      gyp info spawn args [ '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/gyp/gyp_main.py',
      gyp info spawn args   'binding.gyp',
      gyp info spawn args   '-f',
      gyp info spawn args   'make',
      gyp info spawn args   '-I',
      gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build/config.gypi',
      gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/addon.gypi',
      gyp info spawn args   '/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/common.gypi',
      gyp info spawn args   '-Dlibrary=shared_library',
      gyp info spawn args   '-Dvisibility=default',
      gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0',
      gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp',
      gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/<(target_arch)/iojs.lib',
      gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc',
      gyp info spawn args   '-Dnode_engine=v8',
      gyp info spawn args   '--depth=.',
      gyp info spawn args   '--no-parallel',
      gyp info spawn args   '--generator-output',
      gyp info spawn args   'build',
      gyp info spawn args   '-Goutput_dir=.' ]
      gyp info spawn make
      gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      make : on entre dans le répertoire « /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build »
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/avl/avl.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/backoff/backoff.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_args.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack_builder.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_trace.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channelz.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channelz_registry.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/connected_channel.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker_factory.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker_registry.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/status_util.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression_internal.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/message_compress.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression_gzip.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression_identity.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/stats.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/stats_data.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/format_request.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/httpcli.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/parser.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/call_combiner.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/combiner.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_posix.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_uv.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_windows.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/error.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epoll1_linux.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epollex_linux.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epollsig_linux.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_poll_posix.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_posix.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_windows.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/exec_ctx.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/executor.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/fork_posix.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/fork_windows.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_fallback.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_host_name_max.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_sysconf.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iocp_windows.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_custom.o
        CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_internal.o
        A Former User @mariecbilodeau
        @mariecbilodeau
        “gyp ERR …” lines are needed. Your log is missing those infos.
        • T
          themc
          is there any way to play local stored mp3 files on the raspbery pi using the play … command
          currently when saying prhases like play mp3 it says oke and stops.
          im wondering if it is possible to play music mp3s from the music folder using the built in player of vlc player by sying the google command of a gaction
          would be a nice addition to the plugin
            A Former User @themc
            @themc
            If you have a module to play mp3 and it is able to be activated by notification, it could. But adding some specific job to Assistant itself, I think it is not so good idea, because each circumstance is different.
            So have you a module which can play mp3? I can make gaction sample for it.
              dvbit @Guest
              @sean thanks for all the info.
              Just saw this after sending you request for info.
              will search better / more in the future :-)
                dvbit
                Looking for a solution for my vertical setup and browsing the file system I have seen that the cardsare stored in a temp_screen html file in the plugin folder.
                changing there font size from 40px to 20px makes already a big diff (no scroll bars… in the cards)
                is htere a way I can intercept that file and edit before presentation?
                that would already do a good trick :-)
                  A Former User @dvbit
                  @dvbit
                  I’ve already done that. screenZoom is that.
                  But anyway, That screenOutput was made for SmartTV, so it was optimized for Landscape mode. And unfortunately, the screenOutput is uncontrollable static HTML itself. There is no enough room for control.
                  I wish the next version of Google SDK could provide structured data instead static HTML for screenOutput.
                    dvbit
                    Ok. Tx will use that parameter then :-)
                      mariecbilodeau @Guest
                      @sean here is my complete log
                      https://www.dropbox.com/s/7l4wd8xtb3t9odk/error log?dl=0
                      thank you for your help :)
                        mariecbilodeau
                        I got it working with your solution in the troubleshooting section!!! thx
                        • T
                          ToastedToasty
                          @Sean Hi Sean I’ve been trying to setup MMM-Assistant however after renaming my client-secret.json file to credentials.json and running the auth_and_test.json the OAuth2 page to get my token gives me an error 500, any ideas?
                          ? D 2 Replies Last reply Reply Quote 0
                            A Former User @ToastedToasty
                            @toastedtoasty Usually, 500 error means your google project has something wrong. I suggest you remove your google project and recreate again. (I doubt you might have two or more projects and have some confusing about selecting them)
                              dvbit
                              @Sean
                              I have all setup correctly and no error with the configs.
                              I think I have understood the correct working of transcriptionhook but it does not fire the related actions.
                              Can you confirm it is like this the logic:
                              I setup a keyword in the config (unicorn) in the example you provide.
                              Notification trigger catches the word if it is spoken after the hotword.
                              The related action is fired.
                              Unfortunately nothing is triggered . Also : should I see some feedback in the console windows if the hook triggers ?
                              Thanks as usual for the support
                                dvbit @ToastedToasty
                                @toastedtoasty I think you might have forgot to configure your mail in the oauth tab in google Dev console.
                                This happened to me.
                                  @dvbit You can add
                                  console.log("hook", k)
                                  in line 100 of node_helper.js to check whether hookstring be caught or not.
                                  D 1 Reply Last reply Reply Quote 2
                                    dvbit @Guest
                                    @sean Thanks… guess what? assistant setup in my mother tongue did not catch english hook :-D
                                    • T
                                      teitlebot @Guest
                                      @sean @JRCelis Im having the same issue with the buzz and im also using the HAT. Did you fix the issue? Is there a way to just not use the HAT I have a usb mic but Im new at the whole raspberry thing.
                                      Looks like a great module but im having small hickups along the way.
                                        MarkV
                                        I’ve installed MMM-AssistantMk2 with MMM-Hotword and MMM-NotificationTrigger.
                                        Everything works fine except for the return audio.
                                        It stutters and i’m getting the idea that it isn’t procest quick eneough.
                                        Am i the only one with this problem and if not does somebody have the solution?
                                          A Former User @MarkV
                                          @markv @teitlebot
                                          There could be many reasons for that case.
                                          Maybe too many modules or too many front-end refreshing or animating, too many background process or anything else, even including internet speed.
                                          I cannot point specific reason at this moment.
                                          Anyway in my device, I use BT speaker and I have no problem about that. Sorry.
                                          M T 2 Replies Last reply Reply Quote 0
                                            MarkV @Guest
                                            @sean
                                            Thanks for the reply.
                                            I was scared of something like that. After a clean raspbian image i just installed MagicMirror and after that MMM-AssistantMK2, MMM-Hotword and MMM-TriggerNotification (with all the nmp rebuild errors). I’ve uninstalled the compleet LibreOffice and game packets wich come by default with raspbian.
                                            I allready made a .asoundrc file like you can find around the internet.
                                            aplay && arecord work fine without glitches.
                                            Result .asoundrc
                                            pcm.!default {
                                              type asym
                                              capture.pcm "mic"
                                              playback.pcm "speaker"
                                            ctl.!default {
                                                    type hw
                                                    card 0
                                            pcm.mic {
                                              type plug
                                              slave {
                                                pcm "hw:1,0"
                                            pcm.speaker {
                                              type plug
                                              slave {
                                                pcm "hw:0,0"
                                                rate 18000
                                            Results aplay -l && arecord -l
                                            pi@MagicMirror2:~ $ aplay -l
                                            **** List of PLAYBACK Hardware Devices ****
                                            card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
                                              Subdevices: 7/7
                                              Subdevice #0: subdevice #0
                                              Subdevice #1: subdevice #1
                                              Subdevice #2: subdevice #2
                                              Subdevice #3: subdevice #3
                                              Subdevice #4: subdevice #4
                                              Subdevice #5: subdevice #5
                                              Subdevice #6: subdevice #6
                                            card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
                                              Subdevices: 1/1
                                            pi@MagicMirror2:~ $ arecord -l
                                            **** List of CAPTURE Hardware Devices ****
                                            card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
                                              Subdevices: 1/1
                                            Result lsmod
                                            pi@MagicMirror2:~/MagicMirror $ lsmod
                                            Module                  Size  Used by
                                            fuse                  106496  3
                                            cfg80211              573440  0
                                            rfkill                 28672  2 cfg80211
                                            joydev                 20480  0
                                            ads7846                20480  0
                                            hwmon                  16384  1 ads7846
                                            snd_bcm2835            32768  1
                                            spi_bcm2835            16384  0
                                            i2c_bcm2835            16384  0
                                            fixed                  16384  0
                                            uio_pdrv_genirq        16384  0
                                            uio                    20480  1 uio_pdrv_genirq
                                            evdev                  24576  8
                                            snd_usb_audio         172032  0
                                            snd_hwdep              16384  1 snd_usb_audio
                                            snd_usbmidi_lib        32768  1 snd_usb_audio
                                            snd_rawmidi            32768  1 snd_usbmidi_lib
                                            snd_seq_device         16384  1 snd_rawmidi
                                            snd_pcm                98304  2 snd_usb_audio,snd_bcm2835
                                            snd_timer              32768  1 snd_pcm
                                            snd                    69632  10 snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_bcm2835,snd_pcm
                                            i2c_dev                16384  0
                                            ip_tables              24576  0
                                            x_tables               32768  1 ip_tables
                                            ipv6                  434176  22
                                            What would you suggest doing now? I’m a little stuck now, due to my lack of knowledge of Linux.
                                            • 21
                                            • 22
                                            • 3 / 22
