    help ! My MM² don't start after reboot rasbian'system.
    6 Posts 3 Posters 2.1k Views 2 Watching
      rmbeau
      Sorry for my english…
      my magic mirror is well installed on my rasbian system and works properly with the PM2 startup during the first installation but as soon as I reboot my system and I restart magicmirror with the command:
      “pm2 start MagicMirror”
      my control panel confirms the launch but nothing happens.
      thank you in advance
      en francais:
      mon magic mirror est bien installer sur mon systeme rasbian et fonctionne correctement avec le démarrage pm2 lors de la premier installation mais dès que je reboot mon systeme et que je relance magicmirror avec la commande:
      mon panneau de commande confirme le lancement mais rien ne se passe.
      merci d’avance
      B 1 Reply Last reply
        bhepler Module Developer @rmbeau
        @rmbeau - Your English is better than my French.
        • Reboot your Pi
        • After you see the desktop, wait 30 seconds
        • If the interface does not appear, open a terminal window.
        • Type pm2 status all and look for the MagicMirror entry. There should be only one entry!
        • If it looks normal but you still do not have the interface, type pm2 log MagicMirror and let us know what it says.
          rmbeau
          thanks for your answer,
          after having followed your operating mode here is the result of the command: “pm2 log MagicMirror”:
          PM2 ERROR No fole to stream for app MagicMirror, exiting
            @rmbeau - It sounds like pm2 is not able to create the log file.
            Let’s try running the pm2 startup command again. Type pm2 startup and wait for it to finish. At the end, it will give you a command that you need to enter. Copy & paste that command into the command line and run it.
            Once that is complete, try the pm2 log MagicMirror process again. Let us know what it says.
              bjoern
              SyntaxError: Unexpected token )
                  at new Script (vm.js:51:7)
                  at NativeCompileCache._moduleCompile (/usr/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:226:18)
                  at Module._compile (/usr/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:172:36)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
                  at Module.load (internal/modules/cjs/loader.js:566:32)
                  at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
                  at Function.Module._load (internal/modules/cjs/loader.js:498:3)
                  at Module.require (internal/modules/cjs/loader.js:598:17)
                  at require (/usr/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:159:20)
                  at Object. (/usr/lib/node_modules/pm2/node_modules/chalk/index.js:4:21)
                rmbeau
                hey,
                I followed your instructions and when I enter the last command I have a set of error message:
                error:
                • at new Script (vm.js:51:7)
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:665:10)
