    MMM-Timetable
    43 Posts 12 Posters 27.1k Views 13 Watching
      maxbachmann
      Ik I will do that probably ;)
      Well first I still need to set my calendar up since I want to finally self host it to get away from google and similar stuff there. But converting from cal dav or csv to convert to this format should not be a that big deal.
      • E
        erq @Guest
        @sean
        No, no problems i any other modules, just this one.
        • E
          erq
          Never mind, it was a user-error! =)
          For some reason my putty-session did not write å,ä & ö correctly. From a linux-session it worked.
            A Former User @maxbachmann
            @maxbachmann
            I think a structured static timetable is somehow different with schedule of calendar.
            But Anyway, you can consider this.
            https://forum.magicmirror.builders/topic/5426/mmm-calendarexttimeline-display-timeline-table
            [card:eouia/MMM-CalendarExtTimeline]
              maxbachmann
              @Sean yeah it kind of has the advantage to show multiple events at the same time better. Therefor I prefer this design a lot, so still have to think about which one I will go with. The static structure is not that much of a problem for me then I will just change it to my needs ;) The design part is what I absolutely suck in xD
              • E
                electros Project Sponsor @Guest
                @sean I like your module, the design is fantastic but I could ask you for a change to use a csv or txt file for schedule? I do not really trust to let my daughter change the config.js file while a txt or csv file is not so complicated.
                Thanks again for your work.
                ? 2 Replies Last reply
                  A Former User @electros
                  @electros I’ll consider.
                    @electros
                    I’ve added function of reading schedule from comma(,) separated text file(or csv).
                    E 1 Reply Last reply
                      maxbachmann
                      awesome :)
                      • E
                        @sean Wow, so fast thank you very much. I tested and everything is fine, thank you again for a great work.
                        • zdenekZ
                          zdenek @Guest
                          @sean amazing, thanks. Just a question - my kids have different Timetable for odd and for even week. Is there way how to show them the correct one? Now Iˇve visible in Cal module the number of week and in TimeTable they have 2 rows (odd/even). Or can be still on 2 rows, but use different colors for odd and even?
                          Thanks, Zdeněk
                            A Former User @zdenek
                            @zdenek
                            Wow, It’s a very odd timetable which has never been imagined. :)
                            Do you need the 2 timetables are displayed at the same time always? or Just 1 timetable for the right week at that time?
                              @zdenek
                              0) display 2 timetables together;
                              Hmmm… I think it’s hard. I had considered that case at the development, but gave up. because I thought the screen was too small to display complex timetables.
                              1. display 2 timetables by rotation
                              refreshInterval: 1000*60,
                              schedules: [
                                  title: "Even Weeks",
                                  schedule: [ ... ]
                                  title: "Odd Weeks",
                                  schedule: [ ... ]
                              This would make a rotation of timetables per every 1 minutes.
                              1. Display right timetable of that week.
                                I think it could be done by new feature - reading schedule from file.
                                Prepare 2 csv files, - even.csv, odd.csv
                                And you can add below code into your crontab to change from each .csv to thisweek.csv
                              0 8 * * 6 test $((10#$(date +\%W)\%2)) -eq 1 && cp /your/path/odd.csv /your/paht/thisweek.csv || cp /your/path/even.csv /your/path/thisweek.csv
                              This will copy odd.csv or even.csv to thisweek.csv on each Saturday.
                              The configuration could be like this;
                              schedules: [
                                  title: "My Kids Timetable",
                                  file: "thisweek.csv",
                              I didn’t test but you can catch the idea.
                              Reply Quote 2
                              • V
                                Vauxdvihl
                                @Sean
                                Thanks a lot for this module
                                For testing i have simply copied your example to my config.
                                But i am not able to get it running
                                The screen stays black
                                Any idea
                                Do i have to use the lastest version of the magic mirror sw?
                                Thanks a lot
                                Greetz
                                0|mm       | Shutting down server...
                                0|mm       | > magicmirror@2.4.1 start /home/pi/MagicMirror
                                0|mm       | > sh run-start.sh
                                0|mm       | Starting MagicMirror: v2.4.1
                                0|mm       | Loading config ...
                                0|mm       | Loading module helpers ...
                                0|mm       | No helper found for module: clock.
                                0|mm       | No helper found for module: alert.
                                0|mm       | No helper found for module: MMM-Timetable.
                                0|mm       | All module helpers loaded.
                                0|mm       | Starting server on port 8080 ...
                                0|mm       | Server started ...
                                0|mm       | Sockets connected & modules started ...
                                0|mm       | Launching application.
                                  //disabled:true,
                                  module: "MMM-Timetable",
                                    timeFormat: "hh:mm A",
                                    height: "800px",
                                    width: "150px",
                                    mode: "5days", // "today", "5days", "7days"
                                    displayEndTime:true, //whether display endTime on timeline or not.
                                    schedules: [ //array of schedules
                                        title: "Slytherin 2nd Year",
                                        file: null, // or "test.csv" - comma separated text file. (see `test.csv`)
                                        schedule: [
                                          // [weekday, starttime(24h), endtime(24h), title, subtitle, backgroundColor(optional)]
                                          // weekday : 1 for Monday, 2 for Tuesday, ... 7 for Sunday
                                          [1, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                                          [2, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                                          [3, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                                          [4, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                                          [5, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                                          [1, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                                          [2, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                                          [3, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                                          [4, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                                          [5, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                                          [1, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                                          [2, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                                          [3, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                                          [4, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                                          [5, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                                          [1, "1100", "1145", "Transfiguration", "w/Ravenclaw"],
                                          [1, "1315", "1400", "Charms", "w/Hufflepuff"],
                                          [2, "0915", "1045", "Transfiguration", "w/Ravenclaw"],
                                          [2, "1500", "1630", "Herbology", "w/Ravenclaw"],
                                          [3, "0915", "1045", "Defense Against The Dark Art", "w/Gryffindor", "rgba(255,0,0,0.5)"],
                                          [3, "1100", "1145", "Charms", "w/Hufflepuff"],
                                          [3, "1315", "1445", "History of Magic", "w/Hufflepuff"],
                                          [3, "1500", "1630", "Potions", "w/Gryffindor"],
                                          [4, "1100", "1145", "Defense Against The Dark Art", "w/Gryffindor"],
                                          [5, "1315", "1400", "Potions", "w/Gryffindor"],
                                        title: "Slytherin 2nd Year (only classes)",
                                        schedule: [
                                ? 1 Reply Last reply
                                  A Former User @Vauxdvihl
                                  @vauxdvihl
                                  I have no problem…
                                  Try this;
                                        //disabled:true,
                                          file:"test.csv"
                                  Or just
                                  V 1 Reply Last reply
                                  • V
                                    Vauxdvihl
                                    @sean said in MMM-Timetable:
                                    module: “MMM-Timetable”,
                                    position: “top_right”,
                                    This is strange
                                    No error message and nothing shown on the screen
                                    I have generated a test config file (contains only the timeline)
                                    Hmm i need to check it
                                    • V
                                      Vauxdvihl
                                      • V
                                        Vauxdvihl @Guest
                                        @sean
                                        I have done it
                                        • V
                                          Vauxdvihl @Vauxdvihl
                                          @Sean
                                          Can i change the timeformat to European one?
                                          like 22:30?
                                            @vauxdvihl
                                            Set timeFormat as “HH:mm”
