    MMM-Timetable
    43 Posts 12 Posters 21.8k Views 13 Watching
      A Former User
      MMM-Timetable
      Display static structured timetable for school or work.
      Screenshots
      Details
      [card:eouia/MMM-Timetable]
      E zdenekZ 2 Replies Last reply Reply Quote 6
      • E Offline
        erq
        Hi!
        Thanks for a simple and configurable module.
        I have problems showing swedish characters such as å, ä & ö. Any clues where to start look?
        Best regards
          A Former User @erq
          @erq I think that might be font issue. Is there same issue in other module?
            A Former User @erq
            @erq
            https://forum.magicmirror.builders/topic/5406/issue-with-polish-letters-font-missing-diacritical-marks
            This could be a same issue with you.
              maxbachmann
              @Sean really like the design :) (although with my daily schedule this would a pain in the arse to manage lol)
              Might be interesting to combine this with a normal calendar so you just give it a csv file for example it can use, so you do not have to copy the whole calendar into the new format
              N ? 2 Replies Last reply Reply Quote 0
              • N Offline
                ninjabreadman @maxbachmann
                @maxbachmann You could write it in a CSV/tabular format and use a converter to transform it into JSON array format. You can also do it locally if you’re so inclined.
                  maxbachmann
                  Ik I will do that probably ;)
                  Well first I still need to set my calendar up since I want to finally self host it to get away from google and similar stuff there. But converting from cal dav or csv to convert to this format should not be a that big deal.
                  • E Offline
                    erq @Guest
                    @sean
                    No, no problems i any other modules, just this one.
                    • E Offline
                      erq
                      Never mind, it was a user-error! =)
                      For some reason my putty-session did not write å,ä & ö correctly. From a linux-session it worked.
                        A Former User @maxbachmann
                        @maxbachmann
                        I think a structured static timetable is somehow different with schedule of calendar.
                        But Anyway, you can consider this.
                        https://forum.magicmirror.builders/topic/5426/mmm-calendarexttimeline-display-timeline-table
                        [card:eouia/MMM-CalendarExtTimeline]
                        • 1 / 5
