    MMM-AssistantMk2
    421 Posts 61 Posters 797.0k Views 57 Watching
      dvbit
      @Sean
      I have all setup correctly and no error with the configs.
      I think I have understood the correct working of transcriptionhook but it does not fire the related actions.
      Can you confirm it is like this the logic:
      I setup a keyword in the config (unicorn) in the example you provide.
      Notification trigger catches the word if it is spoken after the hotword.
      The related action is fired.
      Unfortunately nothing is triggered . Also : should I see some feedback in the console windows if the hook triggers ?
      Thanks as usual for the support
      ? 1 Reply Last reply
        dvbit @ToastedToasty
        @toastedtoasty I think you might have forgot to configure your mail in the oauth tab in google Dev console.
        This happened to me.
          A Former User @dvbit
          @dvbit You can add
          console.log("hook", k)
          in line 100 of node_helper.js to check whether hookstring be caught or not.
          D 1 Reply Last reply
          Reply Quote 2
            dvbit @Guest
            @sean Thanks… guess what? assistant setup in my mother tongue did not catch english hook :-D
            • T
              teitlebot @Guest
              @sean @JRCelis Im having the same issue with the buzz and im also using the HAT. Did you fix the issue? Is there a way to just not use the HAT I have a usb mic but Im new at the whole raspberry thing.
              Looks like a great module but im having small hickups along the way.
                MarkV
                I’ve installed MMM-AssistantMk2 with MMM-Hotword and MMM-NotificationTrigger.
                Everything works fine except for the return audio.
                It stutters and i’m getting the idea that it isn’t procest quick eneough.
                Am i the only one with this problem and if not does somebody have the solution?
                  A Former User @MarkV
                  @markv @teitlebot
                  There could be many reasons for that case.
                  Maybe too many modules or too many front-end refreshing or animating, too many background process or anything else, even including internet speed.
                  I cannot point specific reason at this moment.
                  Anyway in my device, I use BT speaker and I have no problem about that. Sorry.
                  M T 2 Replies Last reply
                    MarkV @Guest
                    @sean
                    Thanks for the reply.
                    I was scared of something like that. After a clean raspbian image i just installed MagicMirror and after that MMM-AssistantMK2, MMM-Hotword and MMM-TriggerNotification (with all the nmp rebuild errors). I’ve uninstalled the compleet LibreOffice and game packets wich come by default with raspbian.
                    I allready made a .asoundrc file like you can find around the internet.
                    aplay && arecord work fine without glitches.
                    Result .asoundrc
                    pcm.!default {
                      type asym
                      capture.pcm "mic"
                      playback.pcm "speaker"
                    ctl.!default {
                            type hw
                            card 0
                    pcm.mic {
                      type plug
                      slave {
                        pcm "hw:1,0"
                    pcm.speaker {
                      type plug
                      slave {
                        pcm "hw:0,0"
                        rate 18000
                    Results aplay -l && arecord -l
                    pi@MagicMirror2:~ $ aplay -l
                    **** List of PLAYBACK Hardware Devices ****
                    card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
                      Subdevices: 7/7
                      Subdevice #0: subdevice #0
                      Subdevice #1: subdevice #1
                      Subdevice #2: subdevice #2
                      Subdevice #3: subdevice #3
                      Subdevice #4: subdevice #4
                      Subdevice #5: subdevice #5
                      Subdevice #6: subdevice #6
                    card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
                      Subdevices: 1/1
                    pi@MagicMirror2:~ $ arecord -l
                    **** List of CAPTURE Hardware Devices ****
                    card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
                      Subdevices: 1/1
                    Result lsmod
                    pi@MagicMirror2:~/MagicMirror $ lsmod
                    Module                  Size  Used by
                    fuse                  106496  3
                    cfg80211              573440  0
                    rfkill                 28672  2 cfg80211
                    joydev                 20480  0
                    ads7846                20480  0
                    hwmon                  16384  1 ads7846
                    snd_bcm2835            32768  1
                    spi_bcm2835            16384  0
                    i2c_bcm2835            16384  0
                    fixed                  16384  0
                    uio_pdrv_genirq        16384  0
                    uio                    20480  1 uio_pdrv_genirq
                    evdev                  24576  8
                    snd_usb_audio         172032  0
                    snd_hwdep              16384  1 snd_usb_audio
                    snd_usbmidi_lib        32768  1 snd_usb_audio
                    snd_rawmidi            32768  1 snd_usbmidi_lib
                    snd_seq_device         16384  1 snd_rawmidi
                    snd_pcm                98304  2 snd_usb_audio,snd_bcm2835
                    snd_timer              32768  1 snd_pcm
                    snd                    69632  10 snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_bcm2835,snd_pcm
                    i2c_dev                16384  0
                    ip_tables              24576  0
                    x_tables               32768  1 ip_tables
                    ipv6                  434176  22
                    What would you suggest doing now? I’m a little stuck now, due to my lack of knowledge of Linux.
                    • T
                      teitlebot @Guest
                      @sean What are you using for a mic?
                        A Former User @teitlebot
                        @teitlebot
                        I’m using logitech usb cam currently. Before that, Ps3eye, cheap chinese usb mic were tested.
                        M 1 Reply Last reply
                          MarkV @Guest
                          @sean @teitlebot
                          i’m using a cheap chinese usb mic :grinning_face_with_smiling_eyes:
                          T 1 Reply Last reply
                          • T
                            teitlebot
                            just to update and help. I reinstalled everything without the AIY Google HAT and just using a usb mic and the issue of the audio choppiness went away. Still working on other issues like no kiosk mode and learning this complicated google home interface stuff but its really cool.
                            • T
                              teitlebot @MarkV
                              @markv have a look at this if your mic isnt working
                              https://github.com/eouia/MMM-AssistantMk2/issues/16
                              • T
                                teitlebot
                                @jomwells @Module-Developers
                                Did anyone figure out how to add led or sound, like a beep to show when google is listening and speaking. I dont think I’m good enough with linux to do this without a tutorial. Is it something that needs to be implemented in the module or can i learn how to do it from a simple aiy kit?
                                  @teitlebot
                                  https://github.com/eouia/MMM-AssistantMk2#outgoing-notifications-as-assistant-response
                                  Basic notifications will be emitted by its status.
                                  And you can modify module for catching the status to do your specific job.
                                  See https://github.com/eouia/MMM-AssistantMk2/blob/93d7eca6a3995987554d8deb4f4cd76b44e3f096/MMM-AssistantMk2.js#L264
                                  In .socketNotificationReceived(), you can catch each Assistant status.
                                  Anyway, I’m considering to add simple ding-dong waves for convenience in next patch.
                                  V 1 Reply Last reply
                                  • T
                                    teitlebot
                                    @sean I had to leave the assistant action part of the code out because it was causing errors in my config file.
                                      cola0927
                                      Hi, I just tried installing MMM-AssistantMk2 by following the instruction. After saving the config.js (use default configuration) nothing shows up and all I can see is a black screen but a movable mouse pointer. I can’t even quit the mirror. I have no idea what do to now, do I have to start over from the very beginning? :loudly_crying_face:
                                      T ? 2 Replies Last reply
                                      • T
                                        teitlebot @cola0927
                                        @cola0927 many of us had this issue and thats why we run it in servomode
                                        C 1 Reply Last reply
                                        • T
                                          teitlebot
                                          @Module-Developers Why do you set this up as a smart TV. Why cant it be set up as a google assistant with video like the new displays they sell now?
                                            cola0927 @teitlebot
                                            @teitlebot oh, ok, thanks. It’s my first mirror, no relative experience before. I’ll be more careful next time.
                                            • 21
                                            • 22
                                            • 4 / 22
